Pretty sure my converter died
#3041026
05/09/22 05:48 PM
05/09/22 05:48 PM
Posts: 3,306 Pa
Hot 340
Pa
No movement in any gear. Linkage ok. Just stopped moving when I went to turn around. No bang. No noises. Fluid moves on the stick when comparing in neutral to checking with engine shut off, so it's prob not the pump. Fluid nice and pink. Converter is an old 10" tci super street fighter that's been behind 5 or 6 of my motors. 5300 flash behind this engine...Alot hate on tci, but I loved it. My question is, Can a converter company rebuild this core?
Re: Pretty sure my converter died
[Re: rickraw]
#3041054
05/09/22 07:50 PM
05/09/22 07:50 PM
Posts: 3,306 Pa
Hot 340
Pa
They would have to open it up first. Check line pressure. Check the stator splines too. ok..thanks Rick
[Re: dvw]
#3041055
05/09/22 07:51 PM
05/09/22 07:51 PM
Posts: 3,306 Pa
Hot 340
Pa
I doubt it's the converter. My bet is it broke the input shaft clutch hub. Doug Doug, is that common? I didn't think I needed a billet one at 600ish level
[Re: Hot 340]
#3041083
05/09/22 09:36 PM
05/09/22 09:36 PM
Posts: 8,915 MI, usa
dvw
MI, usa
I doubt it's the converter. My bet is it broke the input shaft clutch hub. Doug Doug, is that common? I didn't think I needed a billet one at 600ish level I've never broke one. We run the stock one to 800-900hp. But for a converter to flat fail is unusual. The fluid changes level so it should have pump pressure. If it stripped the front planet it would still have reverse. Suppose it could've broke an output shaft. But that's even rarer. So with no gears I surmise the input hub. Doug
[Re: dvw]
#3041084
05/09/22 09:38 PM
05/09/22 09:38 PM
Posts: 5,972 Melbourne , Australia
LA360
If it's broken anything in the transmission, I'd have the convertor gone through regardless.
Alan Jones
[Re: Hot 340]
#3041085
05/09/22 09:38 PM
05/09/22 09:38 PM
Posts: 4,216 Moved to N.E. Tennessee
GomangoCuda
10" tci super street fighter that flashes to 5300? Did you mean 3500?
[Re: Hot 340]
#3041093
05/09/22 10:09 PM
05/09/22 10:09 PM
Posts: 2,511 Michigan
Transman
No movement in any gear. Linkage ok. Just stopped moving when I went to turn around. No bang. No noises. Fluid moves on the stick when comparing in neutral to checking with engine shut off, so it's prob not the pump. Fluid nice and pink. Converter is an old 10" tci super street fighter that's been behind 5 or 6 of my motors. 5300 flash behind this engine...Alot hate on tci, but I loved it. My question is, Can a converter company rebuild this core? What kind of power you making ? To get that kind of stall with a 10” it must be a bunch.
[Re: Transman]
#3041109
05/09/22 11:47 PM
05/09/22 11:47 PM
GomangoCuda
He said 600ish. Tci says that converter is about 3500. I suspect he just transposed the 3 and the 5.
[Re: GomangoCuda]
#3041112
05/10/22 12:16 AM
05/10/22 12:16 AM
Posts: 3,306 Pa
Hot 340
Pa
10" tci super street fighter that flashes to 5300? Did you mean 3500? It's a *super* street fighter. It would flash to 44~4500 behind the mild smallblocks I had. This new one has more torque hence the higher flash.
[Re: Transman]
#3041113
05/10/22 12:18 AM
05/10/22 12:18 AM
Posts: 3,306 Pa
Hot 340
Pa
No movement in any gear. Linkage ok. Just stopped moving when I went to turn around. No bang. No noises. Fluid moves on the stick when comparing in neutral to checking with engine shut off, so it's prob not the pump. Fluid nice and pink. Converter is an old 10" tci super street fighter that's been behind 5 or 6 of my motors. 5300 flash behind this engine...Alot hate on tci, but I loved it. My question is, Can a converter company rebuild this core? What kind of power you making ? To get that kind of stall with a 10” it must be a bunch. Pump gas, .600 flat tappet stuff. Bro has the same converter and does the same thing. They are loose for 10"s I agree
[Re: Hot 340]
#3041195
05/10/22 12:57 PM
05/10/22 12:57 PM
Posts: 738 WA
JD Dart
WA
Check line pressure fast and easy to do. Moves fluid yea, but what is the pressure?
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: Hot 340]
#3041855
05/12/22 07:10 PM
05/12/22 07:10 PM
Posts: 3,306 Pa
Hot 340
Pa
Hold on. Plumbed the wrong port
