Re: MoPowered 27 T
[Re: Sniper]
#3044754
05/24/22 06:04 AM
05/24/22 06:04 AM
Posts: 2,345 west palm beach, florida
modelmakerinc
Thanks Sniper, you know the saying Great minds think alike i have one made just need to install nutserts and bolt it up, the pics give the impression that the tube is much closer as well. I have worked on several A body big blocks where the header tube is much closer and more confined area and never experienced an issue. I expect the i wont have trouble here since i will have the header and exhaust tubes Jet-Hot coated. still needs the O2 sensor installed and i dont plan to coat until getting ready for final assembly
Re: MoPowered 27 T
[Re: modelmakerinc]
#3050400
06/14/22 09:11 AM
06/14/22 09:11 AM
modelmakerinc
Body setting in its location to rough in the seating position, steering column and assessing what i will do for mounts and floor structure. had my Dad (83) sit cause we are about the same size. Made seat tabs and risers, seats are the narrowest I could find out of a KIA Rio, removed the arm rests, lumbar handles and the base tilt option, modified the tracks for mounting.
There are so many small modifications and changes that must get addressed, in the overall build they are never even considered when all said and done.
Re: MoPowered 27 T
[Re: modelmakerinc]
#3050407
06/14/22 09:17 AM
06/14/22 09:17 AM
modelmakerinc
Removed body off chassis to start body floor structure, did plenty of planning for mounts and to maintain as much original steel in the car. I used 1x3 rectangular tube for cross bracing that doubles as body mounts and nests into the modified original steel. 1" square tube and 1/2" square tube make the trans tunnel and firewall support. I had considered using only sheetmetal for the floor structure but for ease of fabrication I chose this route
This is the layout for flooring, you can clearly see the seat tabs and original body mount holes. I will address the trans tunnel when I get the shifter and I mount the body back onto the chassis.
