5,9 magnum hard crusties in the thermostat housing?
#3040803
05/08/22 05:51 PM
05/08/22 05:51 PM
Andrewh
so I decided to take apart the coolant system on a 5.9 magnum in my 65 coronet. I kept finding coolant in my drip tray in front. so I wind up adding water periodically when I take it out. about half a gallon each time to top off the radiator. The overflow tank is always empty. but I have changed the coolant a few times over the last 4 or 5 years due to fan issues, making me pull the rad out.
It has been a few years since I changed the hoses out, and I cobbled the hoses to make it fit, so it couldn't hurt to replace some of the ends with the silicone replacement elbows I have been seeing, for a better fit. i have some of those steel accordioned tubing to make some odd runs. I noticed the insides of them were rust colored even though the coolant is green. even when I watch it circulate.
I pulled the top hose off and noticed inside the thermostat housing some weird build up. like I would call it piles of stuff on the side walls of the tube. I went to pull them off but they were hard crusts, and eventually broke off, but in doing so, crumbled up.
I haven't pulled the zinc anode I installed yet. But was wondering if I should be checking something else?
Coolant came out orange when it started at the low point drain, but went green really fast.
Re: 5,9 magnum hard crusties in the thermostat housing?
[Re: Andrewh]
#3040839
05/08/22 08:38 PM
05/08/22 08:38 PM
Posts: 16,147 Mesa, Arizona
dart4forte
Mesa, Arizona
Coolant came out orange when it started at the low point drain, but went green really fast. Where do you live?
Abe Lincoln
[Re: 1969ronnie]
#3040895
05/09/22 06:43 AM
05/09/22 06:43 AM
Posts: 984 rust belt
Moparite
rust belt
I meant when I first opened the drain, it looked orange. then quickly went green as it was draining. Rust (brown) mixed with green can look that way when draining. I bought my truck from a dealer and i know it had a leaking freeze plug that either the previous owner or the dealer put in stop leak. After i got it home i pulled the lower freeze plugs on both sides of the block. I then put some brass fittings together(so i could position the nozzle) to pressure wash out the block. You would be amazed at the curd at the bottom of the block. Since this is a Texas truck it may have been run with out antifreeze at some point. This may be something you could consider if you see rust coming out when you flush it.
[Re: Andrewh]
#3040930
05/09/22 09:48 AM
05/09/22 09:48 AM
dart4forte
Mesa, Arizona
Lots of minerals in the water. Corrodes aluminum workin overtime. Best to use distilled water.
Abe Lincoln
