flat tappet cam assembly lube #3040095
05/05/22 08:55 PM
05/05/22 08:55 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
What are you guys using now a days?
Re: flat tappet cam assembly lube [Re: mgoblue9798] #3040112
05/05/22 09:44 PM
05/05/22 09:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used the lube that came with my Howards cam. I also used the additive for the oil that they supplied with the cam kit. So far so good shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: flat tappet cam assembly lube [Re: mgoblue9798] #3040119
05/05/22 10:03 PM
05/05/22 10:03 PM
The use the cam lube that the cam and lifters come with up
Re: flat tappet cam assembly lube [Re: Cab_Burge] #3040157
05/05/22 11:45 PM
05/05/22 11:45 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
After lubing it up correctly during install - The biggest favor you can do to keep your flat tappet cam healthy is to run an oil with zinc or use a zinc additive at each oil change.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: flat tappet cam assembly lube [Re: BigDaddy440] #3040210
05/06/22 08:18 AM
05/06/22 08:18 AM
an8sec70cuda Offline
I've used ARP moly lube and the red stuff that comes w/ the Comp Cams. I've been using the Driven break in oil also. No issues.
CHIP
'06 GMC 2500HD LBZ Duramax
