I swapped my seat in my 2011 with a seat from a 2012, the 2012 has side airbags mine does not so there are two yellow plugs hanging from the seat un used. There is another plug with two green wires I assumed was for the seat belts, they both plug in the same so I figured I would be good to go. Now I have a SRS light on and seatbelt light on along with the annoying dinging sound all the time, there was no SRS light before and the seat belt light and noise went off when wearing my belt. Is there a module inside the seat that needs to be swapped also?
