fuel tank vent question #3039604
05/04/22 09:02 AM
05/04/22 09:02 AM
Maine
E
exile5700 Offline OP
E
Maine
I have a 73 Challenger and i bought a new tank for it. I do not however have the 4 nipple gas tank vent manifold . How can i bypass this? I have searched for one on line and no luck. i was thinking of plugging the 4 nipples off but i don't know how to vent it if i do. Any help would be appreciated. Pictures would be great also. Thank you.
Re: fuel tank vent question [Re: exile5700] #3039608
05/04/22 09:22 AM
05/04/22 09:22 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Hi
On mine, I just looped two short hoses and clamped them.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: fuel tank vent question [Re: exile5700] #3039626
05/04/22 10:17 AM
05/04/22 10:17 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
you can check out or call Tanks Inc. LINKY TO TANKS
Re: fuel tank vent question [Re: Hrtbkr] #3039661
05/04/22 12:16 PM
05/04/22 12:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Hrtbkr
Hi
How would that address the tank venting the OP was concerned about?
Re: fuel tank vent question [Re: Sniper] #3039692
05/04/22 02:23 PM
05/04/22 02:23 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
He can probably find a vented cap or if that may leak, run one of the outlets
to the atmosphere....
Joe
Re: fuel tank vent question [Re: exile5700] #3039857
05/05/22 01:15 AM
05/05/22 01:15 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
On mine, there are five nipples.
Four go to the tank manifold.
There's a separate nipple that goes to the tank fill.
Re: fuel tank vent question [Re: Hrtbkr] #3039909
05/05/22 10:24 AM
05/05/22 10:24 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
An issue one may encounter when filling a tank with capped off vents is splash back as the air in the tank has nowhere else to go. Filling it slowly MAY alleviate the issue but is a PITA wink
Re: fuel tank vent question [Re: TJP] #3040066
05/05/22 07:29 PM
05/05/22 07:29 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
When converting from internally vented EVAP tank to a vented one you need to have either a vented cap or a vent hose on one of the nipples going up about 12" with some kind of a filter so bugs don't get in,then it should function properly.also the tank will fill properly with a vent hose.
Re: fuel tank vent question [Re: 71GTX471] #3040281
05/06/22 11:28 AM
05/06/22 11:28 AM
Maine
E
E
Maine
Thank you i appreciate your reply.
Re: fuel tank vent question [Re: TJP] #3040282
05/06/22 11:28 AM
05/06/22 11:28 AM
Maine
E
E
Maine
