A833 stamping ID numbers #3039223
05/02/22 11:27 PM
05/02/22 11:27 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OA186100...............partial VIN, any way to tell what car this came out of ?
PP833 3084 231..................These are the other numbers, I know what those are.
Re: A833 stamping ID numbers [Re: hemienvy] #3039231
05/03/22 12:11 AM
05/03/22 12:11 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
18 or 23-spline?
it is from a 1970 Lynch Rd. Plymouth B-body that was "scheduled" 12/19/69
if the stamping is accurate "3084" is 1/6/70 - work - the car was built a little LATE
Re: A833 stamping ID numbers [Re: 6bblgt] #3039273
05/03/22 08:45 AM
05/03/22 08:45 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks 6BBL, it's a 23-spl.
Re: A833 stamping ID numbers [Re: hemienvy] #3039941
05/05/22 11:31 AM
05/05/22 11:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does it have a big block size bearing retainer or small block ?
Re: A833 stamping ID numbers [Re: JohnRR] #3039952
05/05/22 12:45 PM
05/05/22 12:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there are NOT any 318 4-speed or 340 4-speed B-bodies for 1970 - from a 383HP car
Re: A833 stamping ID numbers [Re: JohnRR] #3040004
05/05/22 03:46 PM
05/05/22 03:46 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
It is indeed big block.
Re: A833 stamping ID numbers [Re: hemienvy] #3040011
05/05/22 03:52 PM
05/05/22 03:52 PM
1970 was the first year that Mopar had N.P. change the tail shaft housing to dual shifter mounts to fit both the B and E bodies: up: scope:
Re: A833 stamping ID numbers [Re: 6bblgt] #3040215
05/06/22 08:35 AM
05/06/22 08:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for the info , wasn't sure if it was still a thing for 70. What about 383-2 bbl , did they carry over to 1970?
With this in mind it's from a 70 Roadrunner, or lower models that were available with a 383 .
