Voltage regulator questions #3039105
05/02/22 02:47 PM
05/02/22 02:47 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I have a new voltage regulator (pre-70 style) I bought for my 69 Dart a few years back as I am also converting the car to electronic ignition. I just want to be sure it is in fact an electronic unit so I'd like to ask how do you tell the difference between an electronic and a standard regulator? The electronic unit does look different on the backside from my original regulator. My original is on the left in the pics.
I would also like to ask, although the connections look the same, is there anything I have to modify elsewhere to use the electronic regulator?
Thanks.
Re: Voltage regulator questions [Re: 6PAX] #3039107
05/02/22 02:53 PM
05/02/22 02:53 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Without the resistors I would ASSUME that the regulator is solid state. The only way i know of to verify if it is indeed the solid state version, if there are no part numbers on the regulator, no identification numbers on the packaging, no invoice or receipt for the regulator, would be to remove the can and look inside. Or have it X-rayed. shruggy
If it is the electronic replacement for the OEM regulator it should work with no other changes.
Re: Voltage regulator questions [Re: 6PAX] #3039108
05/02/22 02:54 PM
05/02/22 02:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Electronic regulator replacements on old cases are a straight fit. No mods. That's the purpouse for it.
As far if the one on the right is a correct electronic unit replacement for the old mech reg... it seems to be.
Re: Voltage regulator questions [Re: 6PAX] #3039110
05/02/22 02:58 PM
05/02/22 02:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Take the cover off and look. Solid state/electronic will have a PCB, old style will have points.
Rich H.
Esse Quam Videri
Re: Voltage regulator questions [Re: NachoRT74] #3039111
05/02/22 02:59 PM
05/02/22 02:59 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I would say it looks like the insulation is backwards??
Joe
Re: Voltage regulator questions [Re: jlatessa] #3039127
05/02/22 03:56 PM
05/02/22 03:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The one on the right in the backside view is the electronic.
Plug & play, no worries.
Re: Voltage regulator questions [Re: jlatessa] #3039140
05/02/22 04:32 PM
05/02/22 04:32 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Joe
Good eye , it is .
Re: Voltage regulator questions [Re: topside] #3039152
05/02/22 05:39 PM
05/02/22 05:39 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this,... up
Re: Voltage regulator questions [Re: lewtot184] #3039193
05/02/22 09:07 PM
05/02/22 09:07 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Thanks guys!
Re: Voltage regulator questions [Re: 6PAX] #3039281
05/03/22 09:05 AM
05/03/22 09:05 AM
VA
dragon slayer Offline
VA
No to be funny but changing to electronic ignition is not related to changing to electronic alternator control. Is it? 2 independent issues. Though I can understand wanting better system voltage control.
Re: Voltage regulator questions [Re: dragon slayer] #3039299
05/03/22 09:56 AM
05/03/22 09:56 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm not changing the regulator because of the ignition change. I just mentioned the ignition change to indicate I am upgrading to electronic parts in general.
Re: Voltage regulator questions [Re: dragon slayer] #3039312
05/03/22 10:45 AM
05/03/22 10:45 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just an FYI: It is recommended to do so as the electronic regulators are much more stable voltage wise and the electronic ignitions will perform better due to the constant voltage. wink beer
Re: Voltage regulator questions [Re: TJP] #3039790
05/04/22 07:47 PM
05/04/22 07:47 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Bolt it on your car & try it,if it smokes up it was electronic.
Re: Voltage regulator questions [Re: 71GTX471] #3039845
05/04/22 11:47 PM
05/04/22 11:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Try it and you can tell if it’s electronic by the amp gauge holding steady. A mechanical will bounce around some as it switches. The electronics one will also fail shortly thereafter. That’s another clue. DAMHIK. mad
I want my fair share
Re: Voltage regulator questions [Re: SomeCarGuy] #3039874
05/05/22 07:39 AM
05/05/22 07:39 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
point regulators have the resistor on the back side.
Re: Voltage regulator questions [Re: SomeCarGuy] #3039888
05/05/22 09:08 AM
05/05/22 09:08 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
"Bolt it on your car & try it, if it smokes up it was electronic."
"The electronics one will also fail shortly thereafter."
So, is it not a good idea to use an electronic regulator?
Re: Voltage regulator questions [Re: 6PAX] #3039900
05/05/22 10:02 AM
05/05/22 10:02 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have installed MANY electronic versions on my own and customers cars with no problems over the last 25 years (knock on wood). Wonder if wiring / ground issues could be causing the failures ?
Back in the day Direct connection offered a version as it was recommended with the ignition upgrade THOSE were definitely known to fail. At that time, the parts store ones were all mechanical. Somewhere in the mid to late 80's the parts store electronic versions started appearing. Can't remember ever having a problem with one shruggy twocents beer
Re: Voltage regulator questions [Re: TJP] #3039903
05/05/22 10:15 AM
05/05/22 10:15 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
If your AMP needle isn't bouncing, then its a solid state one. smile
I changed mine over on both of my Darts long ago and it has been a pleasant change. Swapped over my old cover, which is stenciled with date code, so only a careful eye can notice.
Re: Voltage regulator questions [Re: TJP] #3039956
05/05/22 01:05 PM
05/05/22 01:05 PM
SomeCarGuy Offline
SomeCarGuy  Offline
If you know of a good 69 down electronic on the market today, post it up. Mine failed this past fall, no grounding issue, sanded back of mount and even a dedicated ground wire to it. Look alike of a mechanical old school one. Ran for maybe two hours total. I’d like a good electronic one to put on the car and stop the bouncing on the gauge. I just don’t care for that while I’m driving and could use that as my spare to carry.
Even had the 70 up style one fail quickly as a resto look one about 12 years ago. Replaced with an ancient parts store one I had in my stash and that one was still living when I sold the car a couple years later. Didn’t have the detailed look I wanted, but it worked where modern garbage couldn’t cut it.
Re: Voltage regulator questions [Re: SomeCarGuy] #3040076
05/05/22 07:55 PM
05/05/22 07:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
the reason they fail is that there is a small fusible link inside that pops. I've replaced them with a strand of copper wiring and they work. Had the MP one years ago do that to me and that's how I figured out what was wrong.
