Re: Muffler Ideas for 505. [Re: INTMD8] #3038835
05/01/22 05:50 PM
05/01/22 05:50 PM
IL
furious70 Offline
furious70  Offline
IL
Originally Posted by INTMD8
The quietest straight through muffler I've found is Pypes race pro. Much quieter than Magnaflow and Ultra Flow.
Edit-carnut beat me to it, agreed smile
are there any dyno tests of these? Don't think they are in any of the Engine Masters shootouts.
We're trying to decide what to put on my brother's Charger, 600hp 493" but want it as quiet as he can without killing 40hp.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Muffler Ideas for 505. [Re: furious70] #3038837
05/01/22 05:53 PM
05/01/22 05:53 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Tack welded up , will do the last of the welding marathon tonight or tomorrow.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038873
05/01/22 07:44 PM
05/01/22 07:44 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The longest case muffler you can fit, straight through. You would be shocked at how quiet a 20 inch case Ultra Flo is compared to the little 14s.
Re: Muffler Ideas for 505. [Re: Uberpube] #3039240
05/03/22 01:31 AM
05/03/22 01:31 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Online content
rumblefish72  Online Content
I wound up running 3-1/2" slip-on collectors with little tabs to bolt to the header collector. Then I welded some 3-1/2" pipe from the slip-ons to a 45* bend. I added a 3-bolt flange before going into a Dr Gas X-Pipe. The X-Pipe is 3-1/2" in and 3" on the outlet. I ran the 3" pipe on the output side of the X-Pipe to a set of Ultra-Flows. I cut up the factory chrome exhaust tips that exited out through the rear valance panel of the 'Cuda and added 3" pipe adapter to the chrome tip. I exited the exhaust just before the back tires. I sent the whole system out to Jet-Hot for satin black coating. I've been happy with this setup with the exception that it's maybe a bit too quiet. I plan to reinstall the Flowmaster original 40's that I had on the 'Cuda back in the 90's. I added 1/2" quick pins that hold the tailpipe hangers to the 2 x 3 box tubing that goes from rocker panel to rocker panel in the floor just behind the front seats. When I go to the track, I slide out the quick pins and undo the 4 bolts so I can easily slide off the exhaust, drop to the ground and slide it under the trailer. I left some torque on the table because I didn't run collector extensions at the track. Engine Masters did an episode that showed pretty impressive gains by running header collector extensions. I'm getting ready to redo this setup since my new headers have 4" collectors. I'll use V-Band connectors on the header flange to exhaust system this time around. And I'll have to long transition from 4" to 3-1/2" to match the size of the X-Pipe inlet. There was a post on here about a month ago where a guy with a really nice Pro-Mod white Duster did a custom exhaust using oval stainless. It was a work of art. You should check that out for inspiration wink
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
