Re: Vin# numbers on a 1968 Coronet.
[Re: A12]
#3038967
05/02/22 12:33 AM
05/02/22 12:33 AM
Posts: 21,637 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
The number your friend needs in on the missing fender tag lower right of the tag if I not mistaken............and I think on a broadcast sheet or sales order??? Edit: just read your other thread about the Charger clip to a Coronet..........why would this question of "numbers" even matter because in our state we have to have vehicles verified to be issued titles. They have a pink slip from out of state, so the car will need inspection by DMV/CHP. I think 1968 vin is not on the body parts, or is it? I don't believe the vin number that is on the dash is the same as the numbers on the body and that changed in 69'?
[Re: migsBIG]
#3038969
05/02/22 12:53 AM
05/02/22 12:53 AM
Posts: 21,497 N.E. OHIO, USA
A12
N.E. OHIO, USA
The number your friend needs in on the missing fender tag lower right of the tag if I not mistaken............and I think on a broadcast sheet or sales order??? Edit: just read your other thread about the Charger clip to a Coronet..........why would this question of "numbers" even matter because in our state we have to have vehicles verified to be issued titles. They have a pink slip from out of state, so the car will need inspection by DMV/CHP. I think 1968 vin is not on the body parts, or is it? I don't believe the vin number that is on the dash is the same as the numbers on the body and that changed in 69'? Correct, as I mentioned in my post/reply above. The numbers on the radiator support and trunk drip rail match the bottom line, far right numbers of the fender tag.
[Re: migsBIG]
#3039046
05/02/22 11:35 AM
05/02/22 11:35 AM
Posts: 15,720 Jefferson State
srt
ESYC
ESYC
Jefferson State
.........I think 1968 vin is not on the body parts, or is it? I don't believe the vin number that is on the dash is the same as the numbers on the body and that changed in 69'? Correct: vin is not on 68 sheet metal Recommend making dmv appt as they are more likely to focus on numbers. Recommend not investing much until after transfer.
[Re: srt]
#3039167
05/02/22 06:26 PM
05/02/22 06:26 PM
migsBIG
San Jose,CA
