Re: Rocker Shaft
[Re: 71birdJ68]
#3038382
04/29/22 09:58 PM
04/29/22 09:58 PM
Posts: 8,193 fredericksburg,va
cudaman1969
fredericksburg,va
But the hole ends up wrong and if turned around groove is on the wrong end. That’s why I put them together on the head, with rocker on the valves.Exaust Rocker lays up against the stand, then the spring, then stand, rocker, spring. Stands on the pins then snug bolt, instake goes spring then rocker working out. Very hard working from either end, stands are tight
Re: Rocker Shaft
[Re: 71birdJ68]
#3038460
04/30/22 12:06 PM
04/30/22 12:06 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
The FSM has this information in it. Perhaps someone has it digitally stored and can post it.
On R & RB motors, the holes are positioned at the bottom to feed oil to the highest load area on the rocker arm, and if your holes are offset from the hold down bolt holes on the shaft, make sure to orient the small oil feed holes toward the side that best locates these holes closest to the center of the highest load bearing surface (fulcrum) position inside the rocker arm's. On B & RB motors the holes are offset to feed oil to the center of the loaded area of the rocker arm itself, and that translates into pointing the oil holes towards the exhaust side and note the intake side.
In other words, the oil hole goes at the bottom and in the middle of the rocker arm's sweep pattern on the shaft.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Rocker Shaft
[Re: jbc426]
#3040667
05/07/22 08:19 PM
05/07/22 08:19 PM
Posts: 2,603 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
No. On a Hemi, the groove goes on the bottom and the hole on the top. Don't force anything. The #2 & #4 rocker stand supply oil so the dowel pins are in a different location to keep you from assembling wrong. Take your time.
2011 Drag Pak Challenger
Re: Rocker Shaft
[Re: rickseeman]
#3040703
05/07/22 11:53 PM
05/07/22 11:53 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
No. On a Hemi, the groove goes on the bottom and the hole on the top. Don't force anything. The #2 & #4 rocker stand supply oil so the dowel pins are in a different location to keep you from assembling wrong. Take your time. i seen stock Hemi rocker arm stands that had only one oil hole in one stand, not two like the later street hemi motors had two, in #2 and #4 stands so they could be installed on either head Make sure the oil hole in the stand is installed over the oil hole in the head, #4 (between cylinders #5&7 on the driver side and between #6 &8 cylinders on the passenger side) stand on both sides
Re: Rocker Shaft
[Re: Cab_Burge]
#3040722
05/08/22 08:53 AM
05/08/22 08:53 AM
rickseeman
Stuttgart, Arkansas
To the OP: If you haven't figured it out yet give me a call at 501-519-7425 and we will face time. I will lay the parts on the table and we will assemble them together. After you learn it it's easy-peasy.
