933 valve springs
[Re: moparts]
#3033832
04/15/22 01:42 PM
04/15/22 01:42 PM
Posts: 751 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Looking for a set of unused Mopar Performance 933 valve springs.
1972 Road Runner
1988 Shelby CSX-T
Re: Wanted solid lifter
[Re: burks340]
#3038056
04/28/22 09:29 PM
04/28/22 09:29 PM
Posts: 39,258 Bend,OR USA
Cab_Burge
Want to buy a stock dual point 1970 440 distributor with vacuum advance in good to excellent shape.  PM me on here or E mail me at cabburge@wans.net. Thanks: Cab
Re: Wanted - Budget Friendly 2x4 intake for RB
[Re: moparts]
#3044346
05/22/22 03:42 PM
05/22/22 03:42 PM
Posts: 15,954 north of coder
moparx
i'm looking for a Budget Friendly 2x4 inline Aluminum intake. that is, if something like this even exists. stripped threads, bad mating surfaces, cracks, are ok. PM me here or : moparxz "at" comcast "dot" net. a BIG thanks for the add Moparts !
Re: Wanted 383 parts
[Re: modelmakerinc]
#3045878
05/28/22 01:05 PM
05/28/22 01:05 PM
Posts: 700 SE Wisconsin, USA
RP's R/T's
SE Wisconsin, USA
Looking for a 2120510 spacer for a standard fan/22” radiator.
Also, a choke cup for a standard cast iron intake.---FOUND Both for 1970 383. Thanks PM me
Re: Wanted - Big Block Engine - 2nd Quarter
[Re: moparts]
#3048346
06/06/22 03:59 PM
06/06/22 03:59 PM
Posts: 170 Suburb of Chicago, IL
BCFKody
RB Mopar Performance single plane M-1 4150 1x4 intake wanted. Thanks! Bcfkody@comcast.net
Re: WTB...good 68-71 383 blocks
[Re: blue_stocker]
#3049155
06/09/22 03:53 PM
06/09/22 03:53 PM
Posts: 4,080 The Wet Coast, Canada
megajoltman
Try this again sorry if I didn’t reply but COVID BS
Looking for ATI BBM balance with chevy front bolt pattern or crank hub.
Thanks, Roger
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: moparts]
#3049970
06/12/22 03:46 PM
06/12/22 03:46 PM
Posts: 761 Maryville tn
67coronetman
Maryville tn
I am looking for a old school mopar cam.
I am wanting the Old school grind purple shaft cam 292/509 for a big block mopar.
PM me if you can help
Old car are me......
[Re: moparts]
#3049988
06/12/22 05:25 PM
06/12/22 05:25 PM
Posts: 290 Ohio
RT440Dodge
Ohio
***Wanted*** A new P4529071 >>> 69-71 Mopar 440 Magnum Air Cleaner Tin Insert with Orange Logo. 937-270-6120 or evanscr1964@gmail.com. Chris
[Re: moparts]
#3050018
06/12/22 07:58 PM
06/12/22 07:58 PM
Posts: 1,154 Out of the State of Confusion
blue_stocker
I am still looking for std bore 68-71 383 bare blocks, with or without main caps. Other than normal wear, no damage. PM me here if you have something I may be interested in within 230 miles of Savannah, Tenn. Thanks...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
[Re: blue_stocker]
#3050201
06/13/22 01:23 PM
06/13/22 01:23 PM
Posts: 43 Otsego, mi. by Martin 131 stri...
JT612GTX
Hello, looking for roller rockers for B-1 original heads, lead times for new T & Ds are 20 weeks out, thanks in advance!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left 71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning 70 Challenger - mild 440/727 - 3475lbs - 10.96 best 70 GTX - future quick 16? more $$$$$$
