Re: Unused Caddy STS - What should I look for?
[Re: Faust]
#3038091
04/29/22 12:02 AM
04/29/22 12:02 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
2006 was the year they fixed the head gasket problems.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Faust]
#3038125
04/29/22 03:33 AM
04/29/22 03:33 AM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I’ve heard that oil pumps can be a problem on these things Good luck!
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3038137
04/29/22 07:12 AM
04/29/22 07:12 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I think your biggest issue might be the fuel injectors being possibly gummed up. Beyond that I would get as much gas out as you can and put some fresh fuel in and fire it up. If the injectors are fine and rodents haven't eaten any wires it will likely start up like you turned it off yesterday. I would expect some tapping for a little bit but I bet it doesn't last long.
68 Barracuda Formula S 340
[Re: 70Duster]
#3038141
04/29/22 07:53 AM
04/29/22 07:53 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Fire it up and see what happens🤔 You may get lucky..
China is the enemy.
[Re: 1972CudaV21]
#3038149
04/29/22 08:36 AM
04/29/22 08:36 AM
Posts: 5,469 Michigan
oldjonny
Don't argue with me.
Knowing its a GM was all I needed to know. The rest does not matter.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#3038322
04/29/22 07:21 PM
04/29/22 07:21 PM
Posts: 10,596 Freeport IL USA
poorboy
Freeport IL USA
Knowing its a GM was all I needed to know. The rest does not matter. Knowing its a Caddy STS is all I needed to hear. It looks really good sitting where it is, from here. The good news is IF it still has converters on it, they could be worth some pretty big bucks scrap value.
[Re: Faust]
#3038408
04/30/22 07:12 AM
04/30/22 07:12 AM
Posts: 3,208 Md.
carnut68
Md.
The starter is under the intake. Head gasket problems. Heater core problems. I would take it if was free.
America First!
