1973 340 core engine $750
[Re: moparts]
#3034833
04/18/22 08:37 PM
04/18/22 08:37 PM
Posts: 5,293 NH USA
littleredcoffin
NH USA
1973 340.Core engine..Sitting decades in dry storage.Has Cast crank.Standard bore block.Crank has never been turned.Small valved heads.Has factory windage tray.Needs pan,distrib,1 rocker shaft assembly,and various odd and ends.Turns over when you put a socket and breaker bar to it.Calls only 603 209 1678.I WILL NOT SHIP THIS ENGINE..Pick up only.$750 Calls only 603 209 1678.Located in Keene NH.
90 degree oil filter adapters
[Re: littleredcoffin]
#3035384
04/20/22 04:18 PM
04/20/22 04:18 PM
Posts: 258 delhi,il
trw1982
delhi,il
SOLD1 alum, 1 cast iron. will take pp. usps med flate rate shipping from 62052/62035. pm determines buyers place in line. comes with bolts and gaskets. don't wait, won't last long. 96.00 each shipped to lower 48. will ship elsewhere for actual shipping. usps med flate rate box shipping is 16.10.SOLD
NOS PARTS
[Re: DusterKid]
#3036413
04/23/22 06:37 PM
04/23/22 06:37 PM
Posts: 1,978 Western,NY
JEJJ
Western,NY
More NOS parts: -NOS pistal grips part numbers 2996466 and 2996467...................$450/pr -NOS manual windshield squirt foot pump package # 2932868........$100 -NOS 1970 340 vacuum control assy......# 3438339.......................$100 -NOS 1970 A & E body 340 idle solenoid assy. metal stamped assembly line correct, DR1114442.(not ink stamped )...# 3514892.....$275 -NOS/mint used ? cassette cable approx 43-1/2" long...........$65
Thanks for the Ad Moparts!
716-997-0070
BAKURRUDA@AOL.COM
Re: Six Pack carbs 1970 340 Auto
[Re: Rocket]
#3036587
04/24/22 01:09 PM
04/24/22 01:09 PM
Posts: 1,060 Ill
SMILINJOE
Ill
1970 340 T/A AAR Center 4793 1038 Outboard 4790 2688 4790 2758 Purchased from a member who went EFI Carbs fuel lines linkage and gaskets included. $1750 plus shipping. Lower 48
Re: For Sale - Small Block Engine - 2nd Quarter
[Re: JRepucci]
#3037464
04/27/22 12:06 AM
04/27/22 12:06 AM
Posts: 140 San Diego
JP8
San Diego
For Sale. New in the box Scat 2-350-6125-2100A https://www.summitracing.com/parts/sca-6612521a$500 They retail for $695 so you're saving $200. I bought these for a 3.79" crank build. Plans were to use a Molnar crankshaft. Molnar also has a 4.00" crank that these would work with. These are NOT Chrysler spec rods. These are "Chevy" rods that are to be used with certain aftermarket Chrysler crankshafts. https://www.molnartechnologies.com/domestic-crank-shafts/ I will ship these for a flat rate of $25 to the lower 48. I will accept cash, check, money order, cashier's check, PayPal (Friends and Family), ... This weekend (4/30 - 5/01) I can deliver anywhere near an interstate in SoCal, AZ, NM, West TX, or OK as I am driving from San Diego to OKC.
Instagram : @5_points_racing
