Re: Is it ok to use a 65 amp Alternator in place of a 60 amp
[Re: 5thAve]
#3038965
05/02/22 12:25 AM
05/02/22 12:25 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
60 to 65 is no big deal. They usually upped the wire size when it was a fleet car with an HD alternator. Don't they all just regulate to 12v - 14v +/- a volt or two? Is there a heavy duty wiring harness, never heard of this???
[Re: A12]
#3039068
05/02/22 12:34 PM
05/02/22 12:34 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
60 to 65 is no big deal. They usually upped the wire size when it was a fleet car with an HD alternator. Don't they all just regulate to 12v - 14v +/- a volt or two? Is there a heavy duty wiring harness, never heard of this??? There definitely is a heavy duty wire harness, but I don't think it shows up until you get into the high amp alternators. Higher amps require larger gauge wires. The + battery wire is thicker gauge, and many have a ground for the alternator built in. As more electrical accessories that were added to the vehicle, higher charging system amperage was needed to keep the battery charged. Things like power seats, power windows, Ac, radios with power boosters, and additional lighting all added to the battery current draw, the charging systems had to be stepped up to carry the extra load. More electrical accessories added up pretty fast in the late 60s and early 70s, then when the on board computers of the mid to late 70s showed up, charging systems went crazy. 90 to 120 Amp charging systems was not uncommon. The old wiring harness could never have handled the power flow.
[Re: poorboy]
#3039113
05/02/22 03:01 PM
05/02/22 03:01 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
60 to 65 is no big deal. They usually upped the wire size when it was a fleet car with an HD alternator. Don't they all just regulate to 12v - 14v +/- a volt or two? Is there a heavy duty wiring harness, never heard of this??? There definitely is a heavy duty wire harness, but I don't think it shows up until you get into the high amp alternators. Higher amps require larger gauge wires. The + battery wire is thicker gauge, and many have a ground for the alternator built in. As more electrical accessories that were added to the vehicle, higher charging system amperage was needed to keep the battery charged. Things like power seats, power windows, Ac, radios with power boosters, and additional lighting all added to the battery current draw, the charging systems had to be stepped up to carry the extra load. More electrical accessories added up pretty fast in the late 60s and early 70s, then when the on board computers of the mid to late 70s showed up, charging systems went crazy. 90 to 120 Amp charging systems was not uncommon. The old wiring harness could never have handled the power flow. Wiring is stablished by the load requested by the system or device, not by the source. At you home you plug your cell phone charger on the same outlet than your iron. Source is the same outlet on wall, but iron get a thick wire, while cell phone is barelly some hair thick copper strands. Your starter motor gets a 2 or 4 gauge wire, while the other wire is 10 or 12 gauge. Both on same battery ( 450, 500, 700 amps battery )
[Re: NachoRT74]
#3039236
05/03/22 12:47 AM
05/03/22 12:47 AM
Posts: 4,145 Canada -- Posts: 4034 -Registe...
5thAve
60 to 65 is no big deal. They usually upped the wire size when it was a fleet car with an HD alternator. Don't they all just regulate to 12v - 14v +/- a volt or two? Is there a heavy duty wiring harness, never heard of this??? There definitely is a heavy duty wire harness, but I don't think it shows up until you get into the high amp alternators. Higher amps require larger gauge wires. The + battery wire is thicker gauge, and many have a ground for the alternator built in. As more electrical accessories that were added to the vehicle, higher charging system amperage was needed to keep the battery charged. Things like power seats, power windows, Ac, radios with power boosters, and additional lighting all added to the battery current draw, the charging systems had to be stepped up to carry the extra load. More electrical accessories added up pretty fast in the late 60s and early 70s, then when the on board computers of the mid to late 70s showed up, charging systems went crazy. 90 to 120 Amp charging systems was not uncommon. The old wiring harness could never have handled the power flow. Wiring is stablished by the load requested by the system or device, not by the source. At you home you plug your cell phone charger on the same outlet than your iron. Source is the same outlet on wall, but iron get a thick wire, while cell phone is barelly some hair thick copper strands. Your starter motor gets a 2 or 4 gauge wire, while the other wire is 10 or 12 gauge. Both on same battery ( 450, 500, 700 amps battery ) For that example the wiring on the device might be established by the device but the wiring to the plug is established by the system. If it's a 15A outlet you are using it doesn't matter if you're plugging in an iron or a cellphone the wiring to the outlet still needs to be sized for 15A. The positive wire for a 120 amp alternator is bigger then a 60A one because there is a potential of having more load on it.
[Re: 5thAve]
#3039241
05/03/22 02:02 AM
05/03/22 02:02 AM
NachoRT74
Valencia, España
I minimized the example up to the last section. But think the outlet it comes from another network which also stablishes the load designed to hold along its own system and its own breaker. We can get up to the dam, or nuclear plant producing the energy. No need for that to ilustrate the point.
Of course in all the system there is a relationship between source and the device, but all in all the final destiny or device is what defines the need for the correct wire to be used. But even having a 500 amps alt, if your car will demand just for 70 amps tops you won't need EVER a 2:0 gauge wire, still having that 500 amps al because the system will never request that load.
Thinking on the breaker to protect the AC outlets... is conected maybe to a 120 amps system at home, but still the wall wiring would be maybe 14 gauge.
The home network is kinda "unpredictable" since will change day after day, at every sourcing point, but on our cars the load is more predictable since won't change its splitting/sourcing points like at home. The bigger sucking device will change the load needs is the battery capacity as far gets discharged and when is requesting its charge back.
[Re: NachoRT74]
#3039261
05/03/22 08:14 AM
05/03/22 08:14 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
This is correct. The circuit breaker required is determined by the smallest branch wire. When a branch has a 14 gage wire anywhere, it is supposed to have a 15 amp breaker. When a branch has only 12 gage wire, a 20 amp breaker may be used. Wall outlets generally get 12 gage wiring and 20 amp breakers. Outlets along kitchen counters and other locations must have at least two circuits because often many devices are used in kitchens these days. ------------------------------------------------------------------------------------------------------ As far as alternator amp ratings go, the aftermarket rates them however they feel like. When ordered on the car from Chrysler in the 60s and early 70s, the 65 amp alternators were different than the standard alternators. Best I've been able to tell The 60 amp was a Chrysler special order heavy duty alternator that had a matching heavy duty regulator to handle the higher field current. The car also got a revised wiring harness that split off the alternator output to the battery. The 65 amp alternator was a Leece-Neville special order heavy duty alternator that had a matching Leece-Veville regulatort. The car also got a revised wiring harness that split off the alternator output to the battery, plus wiring for the Leece Neville connections. There were some other less common alternators as well, including the "insulated field" alternators in 1969, and mentioned in the 1970 introductions to the isolated field alternators. Another thing I've noticed is in the sales books the higher amp alternators must be sold with a larger battery. Here's from the 1970 option special order Police package posted at Hamtramk Historical [img] https://www.forabodiesonly.com/mopar/attachments/upload_2021-5-19_8-37-49-png.1715739693/[/img]
[Re: Mattax]
#3039262
05/03/22 08:28 AM
05/03/22 08:28 AM
NachoRT74
Valencia, España
Hey!!! long time without talk!!! I have allways though the larger batt is more to hold the reserve time capacity matched with the car loads demand which usually is of course matched with the alt capacity, but is not a must when upgrading the alt on same specs car. In fact IMHO, a larger batt capacity increases the problem when gets more time to be recharged. Ppl tipically upgrades the car electrical capacity installing a larger batt load capacity before the alt, when should be made just right the opposite. A larger capacity batt with small capacity alt adds more stress to the charging system. Alt allways first!
[Re: Mattax]
#3039272
05/03/22 08:44 AM
05/03/22 08:44 AM
NachoRT74
Valencia, España
but recharge time increased on same recharge load? still being one a smaller fraction than the other,
dunno...
[Re: Mattax]
#3039277
05/03/22 08:50 AM
05/03/22 08:50 AM
NachoRT74
Valencia, España
dunno, I feel more nervous with more time the amm out of the zero reading, either D or C still with an small ammount of load, LOL
[Re: NachoRT74]
#3039329
05/03/22 11:53 AM
05/03/22 11:53 AM
Posts: 9,454 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Look up your wire harness PN, the bare bones will have the smaller lead for the 41 amp, the harness for the 50 and the HD65 have the heavier lead.
Even some of the most well optioned power everything premium cars didnt use the HD65 unless another option triggered it.
More then not you have the 50 amp harness with this lead.
STOP POTATO HATE!
[Re: mopars4ever]
#3039566
05/04/22 03:23 AM
05/04/22 03:23 AM
NachoRT74
Valencia, España
I brought it up because I did have a issue a while back with melting the blue wire in my harness on my other car not long after I put on a chrome Tuff stuff alternator. Not sure if that was what caused it to melt or not. I think that was a 75 amp IIRC. Just read this. If the blue wire got melted is because the alt was a dual field unit set up for a single field with a grounded brush and you connected a dual field setup on it, with the bad luck you connected the blue wire ( ign signal ) to the grounded brush. If the green wire was connected there nothing was melted but a full voltage output was obtained.
