Page 1 of 5 1 2 3 4 5
Road Runner updates #3036799
04/25/22 07:33 AM
04/25/22 07:33 AM
MN
JERICOGTX Offline OP
MN
The weather here in Minnesota has been brutal this year, and refuses to warm up, but this last weekend, I've finally been able to get some work done on the Road Runner. As most know, I broke a rod in my 499 last year, and it pretty much destroyed everything in the short block, and kept the damage to the heads to a minimum. I was already in the process of getting things together for a new engine, and things are finally moving forward with that. With the new engine the old Jerico DR4 would be on borrowed time, so I sold that, and bought a new Liberty Equalizer Extreme 4 speed. Doing so, means the car needs some modifications to fit the new trans. Waiting for parts has been a huge issue, as most know, but with some luck, I have almost everything I need to finish the new to me 563ci engine. A huge thanks to Chuck Millan of Best machine, with help ordering the ATI Dampener shell with integrated Crank trigger magnets.
69 GTX 68 Road Runner
Re: Road Runner updates [Re: JERICOGTX] #3036805
04/25/22 07:40 AM
04/25/22 07:40 AM
MN
MN
With a spare 440 block for mock up, I've been able to make stuff like a new throttle cable, and fuel lines, while I wait for my engine. I bought a used/damaged INDY block. it needed to be fixed by the pan rail, and have 3 new sleeves installed. All that has been done now. The car also needs a rear gear change. I'm going from a 4.88 rear gear, to a 4.56. Liberty wants a 4.30 in the car, but no one makes a 4.30 Pro gear for a Dana 60 anymore.
Re: Road Runner updates [Re: JERICOGTX] #3036807
04/25/22 07:45 AM
04/25/22 07:45 AM
MN
MN
This next step hurt a little. I spent a lot of time making the floors in the car nice, and clean. To take a cutoff wheel to them, ALMOST had me installing a automatic in the car... I traced the Liberty trans on a piece of plywood, then cut it out. With a template, I was able to determine what needed to be cut a way. The trans now fits, and I need to make a removable tunnel for the car.
Re: Road Runner updates [Re: JERICOGTX] #3036814
04/25/22 08:10 AM
04/25/22 08:10 AM
tboomer Offline
tboomer  Offline
Looks nice Jeff! You do good work! What switch panel is that? wave
Re: Road Runner updates [Re: tboomer] #3036815
04/25/22 08:15 AM
04/25/22 08:15 AM
MN
MN
It's the stock dash filler panel. Switches are from Waytek Wire. I made my own wiring harness for the car.
Re: Road Runner updates [Re: JERICOGTX] #3036819
04/25/22 08:35 AM
04/25/22 08:35 AM
an8sec70cuda Offline
Very nice! up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Road Runner updates [Re: JERICOGTX] #3036820
04/25/22 08:37 AM
04/25/22 08:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Beautiful work and car Jeff. Looking forward to it running good #'s soon. If you're running an aluminum rod, check one for fit in the piston. Apparently, it's a more common oversight than I thought.
Re: Road Runner updates [Re: JERICOGTX] #3036823
04/25/22 08:43 AM
04/25/22 08:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have a US gear Pro gear 4.30 in my Dana. Part number 05-997430
Doug
Re: Road Runner updates [Re: HardcoreB] #3036826
04/25/22 08:48 AM
04/25/22 08:48 AM
MN
MN
I'm using Molnar 7.100 steel rods.
Re: Road Runner updates [Re: dvw] #3036827
04/25/22 08:49 AM
04/25/22 08:49 AM
MN
MN
Doug
THANKS Doug! I'll look into it. What spool are you running? 4.10 or 4.56?
Re: Road Runner updates [Re: JERICOGTX] #3036834
04/25/22 09:08 AM
04/25/22 09:08 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have 4.30 pro gears in the 67 ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Road Runner updates [Re: bigdad] #3036846
04/25/22 09:31 AM
04/25/22 09:31 AM
MN
MN
Every place I have looked says no longer available. I called Nitro Gear, as they listed them about a year ago, and had them on their website. No longer available, was what I got when I called them directly. The US gear number Doug gave me, is turning up the same way. maybe they will have one in stock?
Re: Road Runner updates [Re: JERICOGTX] #3036855
04/25/22 09:52 AM
04/25/22 09:52 AM
tboomer Offline
tboomer  Offline
Re: Road Runner updates [Re: tboomer] #3036862
04/25/22 10:16 AM
04/25/22 10:16 AM
MN
MN
Just got off the phone with US Gear, and they are no longer supporting Dana 60 parts.
I called the link you posted Ted, and they do not have one on the shelf, and Nitro gear will no longer be making a 4.30 Pro gear either... I'll stick with the 4.56's, and if it's too much, I'll make the switch to 4.10's next year I guess.
Re: Road Runner updates [Re: JERICOGTX] #3036877
04/25/22 10:49 AM
04/25/22 10:49 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks awesome Jeff! I could see the anxiety behind cutting on that thing but lets be real, we all know you would never put an automatic in it lol.
68 Barracuda Formula S 340
Re: Road Runner updates [Re: JERICOGTX] #3036881
04/25/22 10:52 AM
04/25/22 10:52 AM
tboomer Offline
tboomer  Offline
Good luck Jeff! up
Re: Road Runner updates [Re: Bad340fish] #3036882
04/25/22 10:53 AM
04/25/22 10:53 AM
MN
MN
You have no idea how close I was to going that route. Cutting the car was a HUGE factor. The many hours spent with Joel during our Drag Week travels, convinced me to keep the manual, and order the Liberty. I ordered it a week after we got back.
Re: Road Runner updates [Re: JERICOGTX] #3036935
04/25/22 12:36 PM
04/25/22 12:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Love that car !
I understand the floor thing, but it's never going back to stock, right ?
Re: Road Runner updates [Re: topside] #3036941
04/25/22 12:55 PM
04/25/22 12:55 PM
MN
MN
Originally Posted by topside
Love that car !
There is zero chance of that ever happening.
Re: Road Runner updates [Re: JERICOGTX] #3036979
04/25/22 02:40 PM
04/25/22 02:40 PM
Love that car !
The only person it should really matter to what it looks like is YOU up twocents grin Frick the rest of them, huh whistling devil haha
