Just installed a 1405 Edelbrock carburator on 440 7.3 mopar #3034577
04/18/22 01:45 AM
04/18/22 01:45 AM
Ogden
ahoffman33 Offline OP
Ogden
I'm having trouble with knowing where to put some of my vacuum lines on my carb and also where do you put the EGR valve hose?
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: ahoffman33] #3034675
04/18/22 01:34 PM
04/18/22 01:34 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Edelbrock markets this carb as a universal fit performance carb for small blocks and "some" big blocks. It is not a direct fit replacement carb for anything. As such the throttle linkage, throttle pressure linkage, emissions equipment, and vacuum nipples may not match your specific application. More information from you on the exact application would be necessary for anyone to offer real help. (this is probably the reason that you have had 180 views in 12 hours and no answers)
And welcome to Moparts. Hopefully someone here can be more helpful to you than me.
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: ahoffman33] #3034703
04/18/22 02:46 PM
04/18/22 02:46 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That's not an emissions carb, there is no EGR port.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: 3hundred] #3034706
04/18/22 02:51 PM
04/18/22 02:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What vacuum lines do you have? Most 440 cars are pretty basic and only have distributor and maybe an ac line that need vacuum. The distributor will go to ported and most cars have a vacuum tree to plug the rest in. You’d maybe have a pcv line that you are calling egr that will have a big port to go into at the carb base.
I want my fair share
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: SomeCarGuy] #3034762
04/18/22 05:13 PM
04/18/22 05:13 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You want ported vacuum for egr. Ported vacuum is not present at idle but is present shortly after the throttle blade starts to open. Reason for this is that EGR at idle makes it run rough, possibly stall. You also want it to go thru a thermal vacuum switch so that it doesn't apply with the engine cold, same reasons.
Basically, the same source at the distributor vacuum advance.
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: GomangoCuda] #3034831
04/18/22 08:36 PM
04/18/22 08:36 PM
Guitar Jones Offline
These are the kind of posts I see on FB. Ask a specific question but give little to no information. Anyone near Kansas have a transmission for my truck?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: Guitar Jones] #3034886
04/18/22 11:47 PM
04/18/22 11:47 PM
What color is the truck?
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: Sniper] #3035646
04/21/22 10:13 AM
04/21/22 10:13 AM
scratchnfotraction Offline
don't forget egr usually has a delay relay along with the thermo vac switch.
myself I remove all of the OEM crap when going to a edelbrock carb. I only use the dist vac advance on the ported side of eddy carb after installing a set of the MrGasket mopar mech advance springs, rear 3/8 vac/nipple to power brake booster, front 3/8 vac nipple to pcv valve.
I also suggest marking off the damper timing marks so you can set the timing @ 32* BTDC after recurving the dist mech advance.
I also suggest recalibrating the 1405 my 440 needed larger jets/needles/step up springs 2 stage rich on primary and 4 stages on secondary lighter step up spring (I have a big lumpy cam though) and the 600cfm feeds it just fine.
those 2 things woke my 78 MH 440 up on the street.
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: scratchnfotraction] #3035720
04/21/22 02:18 PM
04/21/22 02:18 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There are better choices than the CarterBrocks with their absolutely ancient calibrations. But all out of the box universal carbs will need some additional components and tuning. The key is to pick one that needs the least of both.
And a question for the OP; is the port needed for an EGR or for the PVC?
Master, again and still
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: ] #3035951
04/22/22 10:36 AM
04/22/22 10:36 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I just [censored] canned the FiTec on my 330 Desoto Hemi. Replaced it with an Edelbrock 1401. So far, runs great.
Abe Lincoln
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: dart4forte] #3036057
04/22/22 02:36 PM
04/22/22 02:36 PM
welcome aboard! the knowledge of the guys here is off the charts. RR
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: RapidRobert] #3036308
04/23/22 01:25 PM
04/23/22 01:25 PM
moparx Offline
moparx  Offline
i just wish i had a young buck here that could rattle loose the stuff i have forgotten over the years, and learn some of the stuff i still remember !
it's he77 gettin' old, and spiders make cobwebs in yer noggin while you sleep ! at least they do that to me ! biggrin
beer
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: moparx] #3036345
04/23/22 02:53 PM
04/23/22 02:53 PM
It'll get worse! (trust me) blush
Re: Just installed a 1405 Edelbrock carburator on 440 7.3 mopar [Re: ahoffman33] #3036693
04/24/22 07:50 PM
04/24/22 07:50 PM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
I'm wondering why you put this small of a carburetor on a 440? Also-do you have the 1481 Edelbrock Chrysler throttle adapter installed, if you don't-you better get one installed and adjust your kickdown likkage before you burn your transmission up. Someone else can explain how to set it up..
