Page 2 of 3 1 2 3
Valve Cover Oil Fill Caps [Re: Memongo] #3033244
04/13/22 04:49 PM
04/13/22 04:49 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Not sure!
2. 73-74 model (came of my 73 Cuda)
3. Mopar Preformance Chrome New!
Call Steve 810-629-1097
Note: Pick the one you want by photo 1-3
Oil Cap 2.jpg (1368 downloads)
Oil Cap 3.jpg (1370 downloads)
Oil Cap Chrome.jpg (1367 downloads)
Factory Carburetor 3.5 in" Stud With Wing Nut [Re: Memongo] #3033246
04/13/22 04:50 PM
04/13/22 04:50 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Carburetor 3.5 in" Stud With Wing Nut. Used, $15 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Water Pump To Fan Spacer 1.25 in' Thick [Re: Memongo] #3033247
04/13/22 04:51 PM
04/13/22 04:51 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Water Pump To Fan Spacer 1.25 in' Thick. Used $15 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Fan Spacer 1.25 in.jpg (1385 downloads)
Temperature, Oil Pressure Sending Unit [Re: Memongo] #3033251
04/13/22 04:54 PM
04/13/22 04:54 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
63-76 Temperature Sending Switch #2426458 Used $7.50 + Shipping
62-80 Oil Pressure Sending Unit For Models With Warning Light. Used, $7.50 + Shipping.
Big Block Distributor Hold Down Bracket [Re: Memongo] #3033252
04/13/22 04:56 PM
04/13/22 04:56 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Bracket. Used, $20 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Holley 4160 Carburetor Factory 383-440 [Re: Memongo] #3033257
04/13/22 05:00 PM
04/13/22 05:00 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Holley 4160 Carburetor Factory 383-440. Used, $150 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Note: Came off a 70 383 Challenger
Holley 4777 650 Double Pumper Carburetor Manual Choke [Re: Memongo] #3033261
04/13/22 05:03 PM
04/13/22 05:03 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Holley 4777 650 Double Pumper Carburetor Manual Choke. Used, $150 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: Should be gone through and set up for your application
1970 440 Magnum, rebuilt and ready to go. [Re: Memongo] #3033393
04/13/22 10:56 PM
04/13/22 10:56 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Here is a rebuilt 1970 440 HP engine, standard bore, 9.7-1 pistons, Ported 906 heads, Lunati Voodoo hydraulic cam with 494 lift and 271 duration, steel crank that's drilled for 4 speed with new standard size rod & main bearings, 3 bolt cam with double roller timing chain, Edelbrock Torker II intake manifold.Casting date is 5-19-1970, ID pad has F440, 7-21 HP, new water pump and new fuel pump. You can see this 440 running on youtube, just type in 1970 440 Magnum, rebuilt. Cam has been broken in and it's ready to go. $6,900, pick up in Cumberland, Md. 21502.detrick12220@atlanticbb.net
Re: 1969 440 HP Fresh Rebuild / Just Broke In [Re: dodgcharg] #3033770
04/15/22 09:34 AM
04/15/22 09:34 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1970-1971 Dodge, Plymouth, Chrysler B-E or C body 383-440 4 Bbl Choke, NOS in the box, never installed on a car, part number 2951653 $175.00 (708) 288-2879
parts 4-11-2022 035.JPG (1509 downloads)
parts 4-11-2022 034.JPG (1515 downloads)
parts 4-11-2022 039.JPG (1505 downloads)
parts 4-11-2022 040.JPG (1507 downloads)
Re: 1969 440 HP Fresh Rebuild / Just Broke In [Re: dodgcharg] #3033816
04/15/22 12:40 PM
04/15/22 12:40 PM
Originally Posted by dodgcharg
can you post the VIN on the side of the block or Pad numbers thanks
Here are the ID pad numbers.
Re: 1969 440 HP Fresh Rebuild / Just Broke In [Re: GODSCOUNTRY340] #3034080
04/16/22 10:53 AM
04/16/22 10:53 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS PRESTOLITE/AUTOLITE MADE IN THE USA DUAL POINT DISTRIBUTOR CAP IBK-1003 CAP WITH MADE IN U.S.A. ON TOP AND # INSIDE, ROTOR IBK-1016A
WILL FIT;
1958-1961 DESOTO IBS-DIST BIG BLOCKS&SMALL BLOCKS WITH AN CAST IRON PRESTOLITE,CHRYSLER DISTRIBUTOR
1958-1970 DODGE DUAL POINTS, BIG BLOCK &273,340 ALSO
1959-1960-1961-1962-1963-1964-1965 CHRYSLER 300 413
1958-1970 PLYMOUTH BIG BLOCKS, DUAL POINT, 273-340 ALSO
INCLUDES A NOS PRESTOLITE IBK-1003 HD RIBBED DISTRIBUTOR CAP, MADE IN U.S.A. ON TOP AND # INSIDE,,
NOS PRESTOLITE IBK-1016A ROTOR WITH #
DEPENDING ON YOUR DISTRIBUTOR # THIS SET UP WILL ALSO FIT CAST IRON SINGLE POINT DISTRIBUTORS USED FROM 1957-1963
PERFECT FOR YOUR PETRONIX EQUIPPED CAST IRON DUAL POINT $50
cowgerwilliam035@gmail.com
IBK-1016A 001.JPG (1458 downloads)
IBK-1016A 004.JPG (1460 downloads)
IBK-1016A 002.JPG (1458 downloads)
IBK-1016A 005.JPG (1461 downloads)
Re: 1969 440 HP Fresh Rebuild / Just Broke In [Re: Joesixpack] #3034082
04/16/22 10:56 AM
04/16/22 10:56 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS PRESTOLITE/AUTOLITE MADE IN THE USA TUNE UP KIT 1958-1963 BIG BLOCK DUAL POINT DISTRIBUTORS, 361-383-413 IBS PRESTOLITE/AUTOLITE
WILL FIT;
1958-1963 DODGE DUAL POINTS, BIG BLOCK IBS-4006B,6C,4009, IBS-4006D,E,F, IBS-4006G, IBS-4011A
1959-1960-1961-1962-1963 CHRYSLER 300, IBS-400G, IBS-4010B,11A, DUAL POINTS
1958-1963 PLYMOUTH BIG BLOCKS, DUAL POINTS# IBS-4006B, 6C,9, IBS-4006D,E,F, IBS-4006G,
INCLUDES A NOS PRESTOLITE IBK-1003 COPPER INSERT HD RIBBED DISTRIBUTOR CAP, MADE IN U.S.A. ON TOP AND # INSIDE,, AN NOS AUTOLITE IBK-1016 ROTOR, A SET OF NOS AUTOLITE IGW-3028JS DUAL POINTS, AND A NOS AUTOLITE STRAP STYLE CONDENSER& 3 INTERNAL CLOTH,SOLDERED,DISTRIBUTOR LEADS.
DEPENDING ON YOUR DISTRIBUTOR # THIS KIT MAY FIT 1964 MODELS$100
ibgtukdp 001.JPG (1457 downloads)
ibgtukdp 002.JPG (1460 downloads)
ibgtukdp 007.JPG (1460 downloads)
ibgtukdp 011.JPG (1460 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3034922
04/19/22 07:43 AM
04/19/22 07:43 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Holley 850 Double pumper, list #4781, just removed from a running 440 engine, nice used condition $225.00 (708) 288-2879
parts 3-30-2022 009.JPG (1284 downloads)
parts 3-30-2022 014.JPG (1281 downloads)
parts 3-30-2022 011.JPG (1284 downloads)
parts 3-30-2022 018.JPG (1281 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3034925
04/19/22 07:54 AM
04/19/22 07:54 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Edelbrock CH4B intake manifold for RB 440 engine, excellent used condition $475.00 (708) 288-2879
parts 3-30-2022 001.JPG (1283 downloads)
parts 3-30-2022 003.JPG (1282 downloads)
parts 3-30-2022 005.JPG (1278 downloads)
parts 3-30-2022 008.JPG (1277 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3036237
04/23/22 09:41 AM
04/23/22 09:41 AM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
NOS 1971 1972 440 HP 440-6 PACK 426 HEMI FUEL VAPOR SEPARATOR pn 3577867.......$250.........**reduced $200.00**....same as 1970 if you remove the bracket.
Thanks for the Ad Moparts!
716-997-0070
BAKURRUDA@AOL.COM
vapor separator.jpg (1074 downloads)
vapor separator....jpg (1073 downloads)
vapor separator...jpg (1074 downloads)
vapor separator..jpg (1074 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: JEJJ] #3036428
04/23/22 07:21 PM
04/23/22 07:21 PM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
-NOS #2808897 1966-70 426 Hemi Vacuum Advance............Box dated 670, has 10 stamped on arm.....$250
-NOS #3514332 late 1970-1971 440 6 DISTRIBUTOR VACUUM ADVANCE.............................................$400
-NOS #3514330 1970-71 383 440 HP DISTRIBUTOR VACUUM ADVANCE...............................................$250
-NOS #3514333 late 1970-1971 440 6 DISTRIBUTOR BREAKER PLATE DUAL POINT................................$200
-NOS #2585162 1965-71 HEMI 413 426 440 Dual Point Breaker Plate...................................................$175..........................*sold*
-NOS FACTORY ORIGINAL HEMI / MAX WEDGE DISTRIBUTOR Clamp.....................................................$150
-NOS 1970-71 383-440 heat riser kit.................................................................................................$225
716-997-0070
BAKURRUDA@AOL.COM
nos parts.........jpg (1022 downloads)
Re: Edelbrock 2475 Six Pack [Re: JEJJ] #3036596
04/24/22 01:18 PM
04/24/22 01:18 PM
Ill
SMILINJOE Online content
SMILINJOE  Online Content
Ill
Edelbrock 2475 intake New painted with POR 15 Street Hemi Orange never bolted on engine.
Mopar Performance Holley 97 Choke
Throttle bracket return spring and bracket coil bracket.
$685 plus shipping. Lower 48
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3037790
04/27/22 10:00 PM
04/27/22 10:00 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Edelbrock 440 SIX PACK aluminum intake manifold, correct for 1969 1/2 A12 cars $1250.00 (708) 288-2879
parts 03-07-2021 013.JPG (979 downloads)
parts 03-07-2021 015.JPG (977 downloads)
parts 03-07-2021 017.JPG (977 downloads)
parts 03-07-2021 023.JPG (978 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3037956
04/28/22 12:46 PM
04/28/22 12:46 PM
cali
68mannix Offline
68mannix  Offline
cali
carb 4968 clean carb for 1971 440 auto hp been sitting for long time so would probably need rebuild kit not frozen at all moves very freely 225 obo best offer pick up ca 93240 or around 25 bucks usps flat rate box cont.us
carb 1.jpg (908 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: 68mannix] #3038168
04/29/22 09:50 AM
04/29/22 09:50 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1971 440 SIX PACK center carb, this a newer over the counter carb, as you can see in the pictures someone has removed the choke parts, recently removed from an engine $425.00 (708) 288-2879
parts 4-28-2022 076.JPG (2273 downloads)
parts 4-28-2022 072.JPG (2273 downloads)
parts 4-28-2022 075.JPG (2263 downloads)
parts 4-28-2022 078.JPG (2265 downloads)
Page 2 of 3 1 2 3
