Re: Which of these two 440 intakes would be best?
[Re: migsBIG]
#3033661
04/14/22 08:25 PM
04/14/22 08:25 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
I have dyno tested those two intakes and a Torker 2 on CA pump swill years ago with the same Holley List 80496 950 HP with no changes to the carb or tune up. The RPM was better on HP and torque below 5500 RPM at WOT: up: The Torker 2 was the worst: down: Most of the single plane intakes I've owned and driven on the street are pretty lazy to light throttle response below 2500 RPM The dual planes are way better below 2500 RPM at light part throttle driving on the street
[Re: elmor353]
#3033668
04/14/22 09:36 PM
04/14/22 09:36 PM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
The fuel injection system will like the single plane better.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: migsBIG]
#3033781
04/15/22 10:09 AM
04/15/22 10:09 AM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How important is throttle response? How tight is the converter? And what is the rear ratio? The dual plane will just plain respond and drive better in normal street driving with a tight street converter. It will probably give up some ponies up top. If the converter is looser than stock, or with lower rear gears, the extra RPM will dilute the advantages of the DP.
Master, again and still
[Re: 19swinger70]
#3033785
04/15/22 10:33 AM
04/15/22 10:33 AM
Posts: 2,254 IL
furious70
IL
The fuel injection system will like the single plane better. I've run an rpm perf on a efi turbocharged big block for a decade and had very good distribution and response. A friend of mine tried 4 different intakes, single and dual planes, and the DP's were the best. Not sure why this continues to be spread.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: AndyF]
#3033797
04/15/22 11:20 AM
04/15/22 11:20 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
I run an M1 on my 440 with a Dominator carb Steert driver.Even cold it fires up but with no choke you have to keep the idle up.I did run the Holley street dominator Its the best all around intake ever for BBs.Rocky
Chrysler Firepower
[Re: DaveRS23]
#3033846
04/15/22 03:21 PM
04/15/22 03:21 PM
Posts: 21,637 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
How important is throttle response? How tight is the converter? And what is the rear ratio? The dual plane will just plain respond and drive better in normal street driving with a tight street converter. It will probably give up some ponies up top. If the converter is looser than stock, or with lower rear gears, the extra RPM will dilute the advantages of the DP. Not sure on the converter specks as I got the transmission for the engine, but the trans was built for this engine and a 6apk intake. I would run either a 3:23 since the car is not a drag racer and stoplight duels are minimal because the police in my areas more abundant than taxes. Probably fun cruise nights, maybe once a year to track party. Still, thinking MI could be used for FI or maybe that new intake from Trickflow.
[Re: migsBIG]
#3033853
04/15/22 03:55 PM
04/15/22 03:55 PM
Posts: 74,947 U.S.S.A.
JohnRR
U.S.S.A.
How important is throttle response? How tight is the converter? And what is the rear ratio? The dual plane will just plain respond and drive better in normal street driving with a tight street converter. It will probably give up some ponies up top. If the converter is looser than stock, or with lower rear gears, the extra RPM will dilute the advantages of the DP. Not sure on the converter specks as I got the transmission for the engine, but the trans was built for this engine and a 6apk intake. I would run either a 3:23 since the car is not a drag racer and stoplight duels are minimal because the police in my areas more abundant than taxes. Probably fun cruise nights, maybe once a year to track party. Still, thinking MI could be used for FI or maybe that new intake from Trickflow. What type of fuel injection are you thinking of swapping to, port injection or a throttle body type ?
[Re: furious70]
#3033854
04/15/22 03:57 PM
04/15/22 03:57 PM
JohnRR
U.S.S.A.
The fuel injection system will like the single plane better. I've run an rpm perf on a efi turbocharged big block for a decade and had very good distribution and response. A friend of mine tried 4 different intakes, single and dual planes, and the DP's were the best. Not sure why this continues to be spread. Throttle body or port efi ?
[Re: JohnRR]
#3033863
04/15/22 04:24 PM
04/15/22 04:24 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
To many variables to pick which will work the best, each one will require a different set up
[Re: migsBIG]
#3033912
04/15/22 07:13 PM
04/15/22 07:13 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How important is throttle response? How tight is the converter? And what is the rear ratio? The dual plane will just plain respond and drive better in normal street driving with a tight street converter. It will probably give up some ponies up top. If the converter is looser than stock, or with lower rear gears, the extra RPM will dilute the advantages of the DP. Not sure on the converter specks as I got the transmission for the engine, but the trans was built for this engine and a 6apk intake. I would run either a 3:23 since the car is not a drag racer and stoplight duels are minimal because the police in my areas more abundant than taxes. Probably fun cruise nights, maybe once a year to track party. Still, thinking MI could be used for FI or maybe that new intake from Trickflow. Big block Mopar intakes are probably the easiest intakes there are to change. So when injection time comes, swapping them would be a snap. Having said that, with 3.23s and primarily street duty, for now I would run the dual plane.
[Re: migsBIG]
#3035002
04/19/22 11:56 AM
04/19/22 11:56 AM
JohnRR
U.S.S.A.
Throttle body. Sounds like the RPM is going to be perfered intake and if I decide to change to a single plane, then I’ll choose one from piles avalible instead of the cheapest manifold on Craigslist. Thank you all for responding, I appreciate the feedback. Throttle body is like using a carb so the RPM would be my choice on a street car.
[Re: migsBIG]
#3035007
04/19/22 12:07 PM
04/19/22 12:07 PM
Cab_Burge
On your deal I would run the RPM for the carb and switch to the MI when you change over to fuel injection. All the EFI motors I've built including direct port EFI as well as throttle body EFI installation instruction said to use a single plane intake, SB, BB and Hemiroid motors with two dry throttle bodies Good luck on your new venture
