Re: Crank tight [Re: B1MAXX] #3033620
04/14/22 05:16 PM
04/14/22 05:16 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by B1MAXX
Bore gauge the torqued mains I bet you find out of round. A line hone will fix it up right. I had a 396 one time that the # 5 was almost .009 too wide at one position. You probably have a tight one.
Without bearings.
Re: Crank tight [Re: B1MAXX] #3033621
04/14/22 05:31 PM
04/14/22 05:31 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
But why would it show up now vs previously?
Just being devils advocate!!!!
Re: Crank tight [Re: Wirenut] #3033631
04/14/22 06:08 PM
04/14/22 06:08 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
Did you change from bolts to studs ??? sometimes a bolt or stud will mess things up.
Re: Crank tight [Re: johnzgarage] #3033632
04/14/22 06:09 PM
04/14/22 06:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
And if so are the studs tight in the main caps.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Crank tight [Re: pittsburghracer] #3033663
04/14/22 08:34 PM
04/14/22 08:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Heat cycling over time can move and the old bearings wear. At same time. Then new bearings in old bore = oval
iagree
Re: Crank tight [Re: FastmOp] #3033717
04/15/22 07:21 AM
04/15/22 07:21 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
studs can definitely change cap location vs factory type bolts. do check the bore sizes. it's a real "educational opportunity"; whistling.
Re: Crank tight [Re: Wirenut] #3033721
04/15/22 07:47 AM
04/15/22 07:47 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Because your main clearance wasn't at .002 with the old bearing/set-up. If your clearance was 1 or 2 thou. more you wouldn't have even noticed it. I'm not suggesting you do this but I bet if scotch-brite the tight but turn-able bearings it would go away.
Re: Crank tight [Re: B1MAXX] #3033735
04/15/22 08:48 AM
04/15/22 08:48 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
I think your right on here . I think this block may have had main bore alignment issues . As I mentioned it was hard on bearings until I went to a standard x then it all went away .
We did measure the bores without bearings and they were spot on spec .
Studs in 1 and 5 bolts in the rest and always has been .
Called a local shop that can line bore and they can’t take it for a month. I have one more I can try .
Thanks for all of the ideas. Just wanted to make sure I wasn’t missing something stupid .
Re: Crank tight [Re: Wirenut] #3034075
04/16/22 10:21 AM
04/16/22 10:21 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I bet the original line bore was done with some very expensive equipment too. (just a follow up comment on another post,sorry) It must not be straight, since the bores are round.
Re: Crank tight [Re: B1MAXX] #3034090
04/16/22 11:48 AM
04/16/22 11:48 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I suspect that the fore/aft location of the newly ground thrust journal on the crankshaft is off. So the crank is moved further forward or further rearward in the block than it is supposed to be. So the bearing shell is getting into the radius on the #2 crank journal causing the binding. You could put a very thin coat of Permatex Prussian blue on the radiuses of the #2 journal, making sure to not go past the radius with it. Then assemble it, and look for witness marks from the bearing hitting the radius.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Crank tight [Re: Hemi_Joel] #3034097
04/16/22 12:17 PM
04/16/22 12:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d be looking for a shop with a “line hone”.
Re: Crank tight [Re: Hemi_Joel] #3034114
04/16/22 12:46 PM
04/16/22 12:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree I would also double check the radius on each journal. You might find #2 bearing will require some carving of the radius contact area. Something to check with an easy fix shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Crank tight [Re: fourgearsavoy] #3034157
04/16/22 04:37 PM
04/16/22 04:37 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Yeah, first thing is check radius on the bearings. And then a line hone is definitely the choice, over a line bore and then hone. Unless you changed maincaps, there should be no need for a line bore. S/F....Ken M
Re: Crank tight [Re: Hemi_Joel] #3034408
04/17/22 02:10 PM
04/17/22 02:10 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
I thought about this as well. So I put it all together without the upper or lower thrust bearing . Same result when torquing #2 . Didn’t use the dye . Maybe I should look closer at it .
Re: Crank tight [Re: fast68plymouth] #3034409
04/17/22 02:11 PM
04/17/22 02:11 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Yes, trying . Not many around and so far the two I spoke to can’t take it for a month or more .
Re: Crank tight [Re: Wirenut] #3034412
04/17/22 02:18 PM
04/17/22 02:18 PM
There is a reason it is tight, it's up to you to find out exactly what it is so you can have it fixed CORRECTLY: work: upscope
Do you have a set of good mikes, inside and outside, or a good dial bore gauge? If so on either one I would check the inside diameter of that main bore torque down and again with a main bearing torque down in it and see if you determine where exactly THAT problem is wrench scope up twocents
Good luck, you can find and have it fix up
