Re: Hemi Vs 396 [Re: bigdad] #3031883
04/08/22 03:16 PM
04/08/22 03:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Royal Oak Pontiac supplied a fully-modified "stock" GTO, 2+2 etc. for many magazine comparisons. Everything visible looked correct, everything inside that could help was massaged (head mill, narrow valve seats, blocked heat riser, new ignition curve, jetting, port matched).
Boffin Emeritus
Re: Hemi Vs 396 [Re: DaveRS23] #3031889
04/08/22 03:34 PM
04/08/22 03:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by DaveRS23
Back when we were street racing, there weren't many BB Shivvies that were real competitive. And the ones that were, they couldn't keep together. Seems like they especially had problems with the valve train/rockers.
You name it, trans, driveshaft and spider gears in those 12 bolts. Before long they had Dana’s and 833s
Re: Hemi Vs 396 [Re: cudaman1969] #3031969
04/08/22 08:24 PM
04/08/22 08:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know Bob who owns the Cuda. Its scienced out pretty good. There have been quicker Hemis in pure stock. Tim Clary owns the Chevelle. His reputation among Pure stock guys is pretty good. My bet is it legal.
Doug
Re: Hemi Vs 396 [Re: dvw] #3031996
04/08/22 09:41 PM
04/08/22 09:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did a little math and think the hemi is probably going thru the traps at around 6200rpm. that would really wring out a stock street hemi from my back in the day experience. the chevelle was probably doing 7300rpm. the 375-396 in factory trim would do 6500rpm (basing this on a friends '68 375hp chevelle from back in the day). the 396 is making power thru rpm. keep in mind those BBC had big port big volume heads, more compression and cam than anything mopar had. i do think that power was close to the same for both. i estimate about 525hp which would be a big increase over true show room stock. as far as street racing went in the '60's those solid lifter BBC did run very good; especially in light novas and camaros.
Re: Hemi Vs 396 [Re: lewtot184] #3032032
04/09/22 03:15 AM
04/09/22 03:15 AM
Back in the days of those two combinations racing on the street tire (traction) were the limiting factor, not HP shruggy work
I remember helping some guys with a 440 HP Charger 727 racing a 1968 Nova SS 4 speed with a hydraulic cam 427 square port head that ran pretty well. He beat the Charger with slicks on the car but not on street tires the first race shruggy
I'm thinking the Charger had a set of L60x15 on ten inch rims, I don't remember which brand now blush
Re: Hemi Vs 396 [Re: crackedback] #3032046
04/09/22 08:38 AM
04/09/22 08:38 AM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by crackedback
Originally Posted by slantzilla
You mean like the Jenkins 396 in Super Stock that was really 488?
I too would like to hear more about the 488
That was in one of the magazines years ago. They had built a legal 68 Camaro SS396 and Jenkins swabbed the deck with them. They protested and he had a 480+ ci motor. The good old days...... boogie
I have read many stories of Ma Mopar and ringer cars too.
Same as the old days in Na$crap. The way it was supposed to happen, a tech inspector would tell you which spark plug to pull, at least for most teams it was that way. Some teams already had a plug pulled to check volume... and surprise, the engine was in spec/tolerance. That was the only cylinder that was in spec!
Most of the time the 396 chevies need deep gearing to run well.
So many things to miss - and most tech guys miss them all day long.
As for P & G, a well trained crew can get all the cylinders to pass tech.
Re: Hemi Vs 396 [Re: lewtot184] #3032051
04/09/22 08:43 AM
04/09/22 08:43 AM
Chrysler dyno tests showed a blueprinted street Hemi to make 480 HP, back in 1966/67.
Trick ring pack, cam, oil pan mods, intake tweaks, coated piston skirts, lighter internals, minimum of 50 horse increase.
I agree with you, making at least 525.
Re: Hemi Vs 396 [Re: A727Tflite] #3032062
04/09/22 10:49 AM
04/09/22 10:49 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you look at the mopar/direct connection engine books they say a street hemi was 390-410hp. i'm sure that number is engine in chassis and all accessories and factory exhaust; not engine dyno number. those type of numbers is what i always look at in a street car. naturally a modified street hemi can easily up the power. after all they were moderate compression and cam. back when i fooled with this stuff the thought was pistons and cam was all the street hemi needed. unfortunately they were crippled with heavy cars which a BBC Camaro wasn't. it's very difficult to power thru a 500+lb weight disadvantage.
Re: Hemi Vs 396 [Re: lewtot184] #3032102
04/09/22 01:20 PM
04/09/22 01:20 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
FWIW the 396 L78 was rated from the factory @ 425 HP in the one year only 1965 Corvette.
I have owned a couple L78 powered cars and I never raced a 426 Hemi powered car, but had success against 440 powered cars on more than one occasion including an A12 that belonged to a friend.
Neither my car or the others were stock though. Stock bottom end .
The L78 from the factory had forged 11-1 pistons, solid lifter cam, 4 bolt block, steel crank, dimple rods, rectangle port heads, high rise alum. intake Holley 3310 .
Gears and headers made a huge difference in performance.
Don't flame me , I don't own any Chevys now !
The engine pictured is my 69 Chevelle. I did not race this car. The car I raced with was a 68 Camaro.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi Vs 396 [Re: Hemi Allstate] #3032128
04/09/22 02:46 PM
04/09/22 02:46 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Good close racing, fun to watch. I know these 2 racers enough to trust that their cars are legal. They have been at it for decades, their cars are very well scienced out. They definitely know how to make them run. Both the Hemi and the BBC are great engines with phenomenal capability in the right hands.
But don't believe anything you see, hear, or read when it comes to these pure stock cars. Some of the players are masters of subterfuge, as well as exploiting the grey areas of the rule book. I know that guys have run roller cams, high compression, trick converters and transmissions, ported heads, etc. and got away with it. And that is how F.A.S.T. was born: Pure Stock drags where cheating is legal.
When trying to compare brands using the Pure Stock drags as a yardstick, keep in mind that the rules greatly favor GM. Many of Mopars advantages in true pure stock form are allowed for the GM cars too at the PSMCDR. Like Mopar had better exhaust with crossovers and dual point ignition systems. Take away the MSD and put that Chev back on its single point ignition and see how it does. And take away the modifications to the upper rear control arms. The GM 4 link rear suspension is hard to beat in stock tire racing when they are allowed "no-hop" bars. The mopars have to run stock leaf setups with no add ons.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Vs 396 [Re: Hemi_Joel] #3032131
04/09/22 02:54 PM
04/09/22 02:54 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
HO Racing out of Hawthorn, California reported on a '69 GTO with a dead stock 350hp 400 engine that had only the suspension modified, it was running 12.75's. eek IIRC, MPH was in the high 90's. HO Racing sold a number of suspension tweaks.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Hemi Vs 396 [Re: lewtot184] #3032148
04/09/22 04:20 PM
04/09/22 04:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Didn’t really know the guy well but I know what he did to his 71 4 speed Hemi Charger. 12.5 pistons better flat rapper cam and 5.13 gears and 11” slicks that fit the wheel well. 10.60s In the mid to lates 70s and most defiantly turned it higher than 6000. I think it had a Rat Roaster to. In a fellow racers 64 lightweight Dodge he turned 8500 with a 5.57 gear. I drove it ONE time and hit the rev limiter second and third, I was used to my slow reving Max Wedge lol. A little tune and Hemis were NOT dogs.
Re: Hemi Vs 396 [Re: polyspheric] #3032780
04/12/22 01:06 AM
04/12/22 01:06 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
I recall an internet story from what seems like eons ago. The fellow who claimed to have owned the 1973 SD455 Trans Am that went 13's for Car& Driver chimed in. His story was that car was a ringer. When they tore the engine down, it had low drag oil rings, the heads had been cut to bring the chambers to blueprint spec CC, and the intake had been port matched. There was even machinist's blue on the intake flange and intake side of the head. His story was that this was discovered on the engine's one and only tear down. True? Who knows. IIRC, there was some credibility, as he wasn't using a screen name, or there was another commenter who vouched.
Re: Hemi Vs 396 [Re: Greenwood] #3032827
04/12/22 09:27 AM
04/12/22 09:27 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yeah, there have been a number of stories and magazine articles over the years that touched on the various manufacturers prepping their test cars "above and beyond" what a legit showroom unit could run. Super Stock & Drag Illustrated even ran a follow up story about the Ronnie Sox A12 440 6-BBL Road Runner test that became the basis for Plymouth's ad campaign.
The great conditions at Cecil County the day of the test weren't enough to account for the 4-5 MPH advantage that particular car had over the other A12 drag tests of the time, which SS&DI believed were due to it being a pre-production car with higher compression and a slightly hotter cam that had been considered for production before the build specs were finalized. Oh, the carbs had been stolen off the car before the test and the replacements didn't come from the parts division, they came from the engineering department. Read into that what you will.
FWIW, the follow up article was written by Ro McGonigel, one of the two SS&DI staff who participated in the testing with Ronnie Sox. He's a way more believable source than some of these kinds of stories have.
EDIT: Not sure where the rest of the story can be found, but here's the part that talks about what I mentioned above (and in more detail). LINK
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hemi Vs 396 [Re: Greenwood] #3032831
04/12/22 09:43 AM
04/12/22 09:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Was that the car that belonged to Wangers at Pontiac? He was a engineer or some wheel at Pontiac. IIRC.
Re: Hemi Vs 396 [Re: justinp61] #3032847
04/12/22 10:39 AM
04/12/22 10:39 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Wangers was in marketing.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Hemi Vs 396 [Re: Brad_Haak] #3032878
04/12/22 12:29 PM
04/12/22 12:29 PM
i remember hearing of a Mopar especially prepared 1970 Hemi Cuda 4 speed car with 4.10 gears in the Dana 60 that Mopar marketing had hidden in L.A. waiting for a phone call from Petersen publishing wanting to test a new hem powered E body for one of their magazines in the fall of 1969. That car was a ringer and Mopar didn't want the magazine to know that car was specialshruggy whistling haha
That was brought up at one of the drag racing seminars in either 1976 or 1978 at one of the seminars in CA back then by Larry Shepard or Tom Hoover devil
Re: Hemi Vs 396 [Re: Cab_Burge] #3033269
04/13/22 05:26 PM
04/13/22 05:26 PM
New Jersey
Qwik426 Offline
Qwik426  Offline
New Jersey
Originally Posted by Cab_Burge
i remember hearing of al Mopa especially prepared 1970 Hemi Cuda 4 speed car with 4.10 gears in the Dana 60 that Mopar marketing had hidden in L.A. waiting for a phone call from Petersen publishing wanting to test a new hem powered E body for one of their magazines in the fall of 1969. That car was a ringer and Mopar didn't want the magazine to know that car was specialshruggy whistling haha
It's a good possibility it was this Hemi 'Cuda. This photo is after Car Craft Magazine did its initial testing then later turned it into a drag car (Project Hemi Cuda).
Funny car driver Pat Minick (Chi-Town Hustler) behind the wheel on this run.
Same car, new owner.
Re: Hemi Vs 396 [Re: Qwik426] #3034023
04/16/22 07:36 AM
04/16/22 07:36 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
It all depends on who's working on it and how "Talented" they are and how much money you're willing to throw at it.
A bone stock street Hemi with 10.25-1 compression and stock valve job with manifolds on could make 480-490 hp. They did make 425 hp@5000, the 480-490 was achieved at 5900-6100 rpm.
