Re: 383 mopar stroker kit needed...also rec's
[Re: merpar]
#3032574
04/11/22 11:55 AM
04/11/22 11:55 AM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
THE 3.9 CRANK IS WHAT I WOULD PREFER.. I HAVE A CRANE 270 -470 HYDRAULIC WANT SMOOTH IDLE.. PUMP GAS COMPRESSION.. JUST FIGURED GO STROKER SINCE IT NEEDS REBUILD ANYWAY
[Re: ph23vo]
#3032608
04/11/22 01:21 PM
04/11/22 01:21 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
Any time you improve the air and fuel amount into the motor it should go faster: up Same thing on making the motor bigger
[Re: ph23vo]
#3032782
04/12/22 01:21 AM
04/12/22 01:21 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Depends on the core shift of the individual heads. Also keep in mind that the addition of the bigger valves does nothing for performance unless the head is ported accordingly. The port will only move so much air, despite the valve size.
[Re: cudadoug]
#3032824
04/12/22 09:20 AM
04/12/22 09:20 AM
ph23vo
renton, Washington
Depends on the core shift of the individual heads. Also keep in mind that the addition of the bigger valves does nothing for performance unless the head is ported accordingly. The port will only move so much air, despite the valve size. yes i know..was thinking since i,m upping the cubes and have 2.14 1.81 new vales laying around here... wih the small cam it would be fine..still keep the velocity up a nd obv the heads would be be blended to support any work..
[Re: ph23vo]
#3032959
04/12/22 06:33 PM
04/12/22 06:33 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
I built one for a friend last year, 438" with a 3.75" crank, 1969 383 block. The rotating assembly and heads were 440 Source. Very mild combo Hughes 228/232 @ .050" hydraulic cam, low deck Performer RPM intake, Holley 750 and small dyno headers. It made around 450 hp and 475 lb. ft of torque and even went to 6,000 rpm. Built to cruise and have good vacuum for power brakes. The dyno headers probably cost a few HP so he went with 1 7/8" TTi headers for when it goes in the car. Not terribly expensive to build. We ran the cost both ways and turned to be only slightly more than a full rebuild with reconditioned, stock-stroke parts. [video:youtube] https://youtube.com/shorts/Ckfj4bhwOh8?feature=share[/video]
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#3033006
04/12/22 08:37 PM
04/12/22 08:37 PM
ph23vo
renton, Washington
I built one for a friend last year, 438" with a 3.75" crank, 1969 383 block. The rotating assembly and heads were 440 Source. Very mild combo Hughes 228/232 @ .050" hydraulic cam, low deck Performer RPM intake, Holley 750 and small dyno headers. It made around 450 hp and 475 lb. ft of torque and even went to 6,000 rpm. Built to cruise and have good vacuum for power brakes. The dyno headers probably cost a few HP so he went with 1 7/8" TTi headers for when it goes in the car. Not terribly expensive to build. We ran the cost both ways and turned to be only slightly more than a full rebuild with reconditioned, stock-stroke parts. [video:youtube] https://youtube.com/shorts/Ckfj4bhwOh8?feature=share[/video] EXACTLY WHY I WANT TO JUST GO STROKER..
[Re: ph23vo]
#3033044
04/12/22 11:45 PM
04/12/22 11:45 PM
Cab_Burge
I've had a lot of steel 440 cranks cut down on the mains to fit the B blocks and had the rod throw offset ground down to 2.20 BB Chevy rod size to make a cheap stroker years ago and even now I have two ocranks done for the 400 B blocks and one for a RB block 440 to make a 468 to 471 C.I. depending on where the bore size ends up being on the 440 block
