383 mopar stroker kit needed...also rec's #3032546
04/11/22 10:18 AM
04/11/22 10:18 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
anyone have a good setup..new or used is fine.. street compression, 030-040 over using stock 906 heads... just a street car....any recommendations from anyone would be great thanks
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032547
04/11/22 10:25 AM
04/11/22 10:25 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032553
04/11/22 10:33 AM
04/11/22 10:33 AM
Nevada
merpar Offline
merpar  Offline
Nevada
I built one for a friend last year. I got the crank and rods from 440 source. Made it a 457 3.900 stroke and .060 over and Trick Flow 240 heads. He hasn't cut it loose yet. It's in a 68 Plymouth station wagon it's a great combo. Just be careful and don't put too much cam in it for the street . His cam is about .560 lift and around 240 duration, flat tappet hydraulic. From Hughes. Nasty!
Re: 383 mopar stroker kit needed...also rec's [Re: merpar] #3032574
04/11/22 11:55 AM
04/11/22 11:55 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
THE 3.9 CRANK IS WHAT I WOULD PREFER.. I HAVE A CRANE 270 -470 HYDRAULIC WANT SMOOTH IDLE.. PUMP GAS COMPRESSION.. JUST FIGURED GO STROKER SINCE IT NEEDS REBUILD ANYWAY
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032576
04/11/22 12:08 PM
04/11/22 12:08 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
also would it be worth the upgrade to 2,14 1,81 valves since i need new ones anyways? since cam is small... i have access to a set is why thanks
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032608
04/11/22 01:21 PM
04/11/22 01:21 PM
Any time you improve the air and fuel amount into the motor it should go faster: up
Same thing on making the motor bigger up
Re: 383 mopar stroker kit needed...also rec's [Re: Cab_Burge] #3032623
04/11/22 02:12 PM
04/11/22 02:12 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Icon makes a piston for the 4.15 crank, might as well go for more cubes. They keep changing their site and making it worse and worse, else I would give you the part number. The same piston is available from 440 source. S/F..Ken M
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032737
04/11/22 08:10 PM
04/11/22 08:10 PM
You might want to set a head on your block with the bigger valves in it first to make sure those valves will work on the smaller 4.250 or 4.280 bore without hitting the cylinder walls scope
Way better to be safe now than wish you had checked before having the heads modified with the bigger valves twocents scope
i need to do the same thing on my 1969 dart GTS 383 motor after I have it bored to find out what size it will clean up at luck Luckily I have two sets of 906 heads to pick from, one with stock size valves and one with the bigger 2.14 and 1.81 valves luck
Re: 383 mopar stroker kit needed...also rec's [Re: Cab_Burge] #3032757
04/11/22 10:01 PM
04/11/22 10:01 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
wish i could cab..engine still in car...cam is small 270-470..never heard of a 383 with the bigger valves having issues.. surely it would be known widely by now?.. found a link says they clear no sweat
https://www.forbbodiesonly.com/moparforum/threads/when-to-notch-the-bore-on-a-383.64508/
appr the input dan
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032782
04/12/22 01:21 AM
04/12/22 01:21 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
appr the input dan
Depends on the core shift of the individual heads.
Also keep in mind that the addition of the bigger valves does nothing for performance unless the head is ported accordingly. The port will only move so much air, despite the valve size.
Re: 383 mopar stroker kit needed...also rec's [Re: cudadoug] #3032824
04/12/22 09:20 AM
04/12/22 09:20 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
appr the input dan
yes i know..was thinking since i,m upping the cubes and have 2.14 1.81 new vales laying around here... wih the small cam it would be fine..still keep the velocity up a
nd obv the heads would be be blended to support any work..
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3032959
04/12/22 06:33 PM
04/12/22 06:33 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I built one for a friend last year, 438" with a 3.75" crank, 1969 383 block. The rotating assembly and heads were 440 Source. Very mild combo Hughes 228/232 @ .050" hydraulic cam, low deck Performer RPM intake, Holley 750 and small dyno headers. It made around 450 hp and 475 lb. ft of torque and even went to 6,000 rpm. Built to cruise and have good vacuum for power brakes. The dyno headers probably cost a few HP so he went with 1 7/8" TTi headers for when it goes in the car.
Not terribly expensive to build. We ran the cost both ways and turned to be only slightly more than a full rebuild with reconditioned, stock-stroke parts.
[video:youtube]https://youtube.com/shorts/Ckfj4bhwOh8?feature=share[/video]
'71 Duster
'72 Challenger
'17 Ram 1500
Re: 383 mopar stroker kit needed...also rec's [Re: RMCHRGR] #3032992
04/12/22 08:12 PM
04/12/22 08:12 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think the old Max Wedges had notches in the bore to clear the big valves. Same bore size as 383 0n the 426. Something to think about. work
Re: 383 mopar stroker kit needed...also rec's [Re: RMCHRGR] #3033006
04/12/22 08:37 PM
04/12/22 08:37 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
EXACTLY WHY I WANT TO JUST GO STROKER..
Re: 383 mopar stroker kit needed...also rec's [Re: ph23vo] #3033044
04/12/22 11:45 PM
04/12/22 11:45 PM
I've had a lot of steel 440 cranks cut down on the mains to fit the B blocks and had the rod throw offset ground down to 2.20 BB Chevy rod size to make a cheap stroker years ago and even now up
I have two ocranks done for the 400 B blocks and one for a RB block 440 to make a 468 to 471 C.I. depending on where the bore size ends up being on the 440 block wrench
