5.7 stroked 397 Hemi. How much HP
#3031705
04/07/22 09:51 PM
04/07/22 09:51 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Hi sorry if this has been asked before. But I will be building my first gen3 hemi stroker motor. The stroker kit is a k1 crank and Rod kit with wisco pistions. The kit came from CNC motor sports. The info says it will have 11.1 compression with my Eagle heads. I have not bought the cam yet. But will have over 600 lift. Intake will be a ported Ritter intake. For now a holley 800 DP carburetor. I have to build them first, but headers will be 2 inch tube 3.5 collectors. I was really wanting to build a 14.1 compression stroker 5.7. But every body around me wants 1000-1500 for a early 5.7 hemi that needs rebuilt. I am buying the stroker kit and a machined block ready to build for $2500. This engine will be going in my race 91/96 Dakota sport race truck. Which has a 904 transmission with a 8 inch 5500 stall coan converter. Rearend is a 8.8 ford with 4.30 gears and MT 28.5x10.5 pro bracket radial tire. My goal is to run 10 flat to mid 9 in the 1/4. Which i don't know if thsts doable or not
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: 5.7 stroked 397 Hemi. How much HP
[Re: mopar65]
#3031885
04/08/22 03:24 PM
04/08/22 03:24 PM
Triple Threat
Renton Washington
You can search here for my posts, but my 13.5:1 5.7/392 with the same parts you're talking about has been 9.74@137 in a 3400# car with a 727 and more recently 9.70 with a powerglide at 3300#.
I'd say 10.0 shouldn't be a problem if the truck works well
[Re: Dart 500]
#3032003
04/08/22 10:18 PM
04/08/22 10:18 PM
mopar65
Cool thank you for answering my post
support our troops
[Re: Triple Threat]
#3032004
04/08/22 10:21 PM
04/08/22 10:21 PM
mopar65
I'd say 10.0 shouldn't be a problem if the truck works well wow thats very nice. I woukd be happy if I ran that fast. My dakota has been 11.24 at 116 so far with my warmed over junk yard 360 magnum engine in it. Also I am guessing my dakota is around 3400/3500 with me in it. My dakota will be raced with a 904.
support our troops
[Re: cagebob1]
#3032162
04/09/22 05:05 PM
04/09/22 05:05 PM
mopar65
Wow very nice. Can you tell me about your build.
support our troops
[Re: cagebob1]
#3032503
04/11/22 01:57 AM
04/11/22 01:57 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
My pump gas BB 505 C.I. stroker motor made around 12 HP less on E85 than it did on Oregon 92 octane pump swill but it made 44 Ft.Lbs. more torque on that pump E85 on a DTS engine dyno by changing the fuel and carb. made for E85 My current S/P bracket car runs on straight pump E85 and it is the best thing I've done to any car I have race for bracket racing, deadly consistent from the 1st run in the morning to the last run in the late afternoons, no guessing on how much to change for the D.A.. It will run within .001 to .005 all day long: boogie: Torque moves the mass, not HP
[Re: mopar65]
#3032606
04/11/22 01:17 PM
04/11/22 01:17 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
Well I wouldn't be afraid in the least to run a 950HP style carb, that is a decent size motor and is going to want a lot of air at higher RPM. Are the heads going to be ported or left stock?
Are you running a VVT block or early block? That will affect the cam recommendation a little.
[Re: HotRodDave]
#3032613
04/11/22 01:37 PM
04/11/22 01:37 PM
mopar65
I am wanting to run this engine on E85 so will be buying a E85 950 carb for it. The block is a early hemi, I think 06 block. The heads will be run stock for now. Will be getting them CNC ported latter
support our troops
[Re: mopar65]
#3032616
04/11/22 01:57 PM
04/11/22 01:57 PM
HotRodDave
Kalispell Mt.
If it was me I would just get BGE heads right now, they are much cheaper than getting your eagle heads ported and have even more potential down the road. I would never spend money getting eagles ported, they are awesome as is but the BGE is even more better.
Either way you could still take about .030 off those heads without getting too close to the valve seat and if you are gonna run E-85 get as much compression as you can for sure.
[Re: HotRodDave]
#3034073
04/16/22 10:05 AM
04/16/22 10:05 AM
mopar65
Either way you could still take about .030 off those heads without getting too close to the valve seat and if you are gonna run E-85 get as much compression as you can for sure. i would like to get some BGE heads latter on. But for now I am going to have to use my eagle heads..
support our troops
[Re: cagebob1]
#3034074
04/16/22 10:06 AM
04/16/22 10:06 AM
mopar65
The engine was done by IMM machine in Indio CA. It's about 12 to 1 compression with the cam speced by Brian at IMM. Stock hydraulic lifters and rocker arms helped to keep the cost "reasonable" Contact Brian at IMM for more info ... he's easy to deal with.. Thanks for the info. I will have to send him a message
support our troops
[Re: gremlinsteve]
#3050801
06/15/22 06:46 PM
06/15/22 06:46 PM
mopar65
I havent got that far. That was going to be my next question. Lol
support our troops
[Re: mopar65]
#3062045
07/24/22 11:13 AM
07/24/22 11:13 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Hi sorry if this has been asked before. But I will be building my first gen3 hemi stroker motor. The stroker kit is a k1 crank and Rod kit with wisco pistions. The kit came from CNC motor sports. The info says it will have 11.1 compression with my Eagle heads. I have not bought the cam yet. But will have over 600 lift. Intake will be a ported Ritter intake. For now a holley 800 DP carburetor. I have to build them first, but headers will be 2 inch tube 3.5 collectors. I was really wanting to build a 14.1 compression stroker 5.7. But every body around me wants 1000-1500 for a early 5.7 hemi that needs rebuilt. I am buying the stroker kit and a machined block ready to build for $2500. This engine will be going in my race 91/96 Dakota sport race truck. Which has a 904 transmission with a 8 inch 5500 stall coan converter. Rearend is a 8.8 ford with 4.30 gears and MT 28.5x10.5 pro bracket radial tire. My goal is to run 10 flat to mid 9 in the 1/4. Which i don't know if thsts doable or not SgtMiller ,Thank you for your service. The Guy who built all my G3 toys , did a 394(3.922X4.08) Icon Pistons, 14+cc dome ,(comp is 11.75 to 1) Eagle heads, 2.125 In take 1.625 Ex , Chambers were softened , they measure 72ccs ports are relatively stock, they were treated to a burr finish porting , cleaned the bowls to use the 2.125 Intake valve. didn't raise the floor lower the celling , no vanes, no push rod tubes. off the shelf Comp Cams HRT specs are some where in the high.59X for lift and 240@.050dur , Not sure haven't looked them up lately. Ritter Intake Wilson Elbow Hellcat TB and a Durango PCM The truck it's in is a 97DakotaRC 4X2 with a TKO600 behind it, 4.88s in the 9.1/4 rear. The Dak runs 9.80s @ 136-139mph, goes through the traps at 7400 RPMS , makes 720hp on the dyno , and MPH /Weight says it's roughly 650 at the wheels .........again it's a 97 Dakota and the PCM is out of an 04 Durango. ...the TKO600 is probly the biggest set back on this truck, they are not know for shifting nicely over 7k , He had an A833 in it it at one point., the A833 did it's typical 3rd gear spread and break. so there where no runs with it, truck has been together since 2017, has about 120 passes on it. mostly Mid Atlantic tracks. 390-400Ci G3s with stock Eagle heads 10-11.5 to 1 Comp .590-600 lift cams. 565 HPmin the better the Intake and the Higher the RPMS the More HP. RPMs seam to be a catch 22 for the G3 ,
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
