Re: Indy 400-I4 t ram mod
[Re: mopar dave]
#3030838
04/05/22 09:11 AM
04/05/22 09:11 AM
Posts: 12,642 Marion, South Carolina [><]
an8sec70cuda
Always heard the Indy hemi tunnelrams had very small plenums and almost all combos benefit from a 1/2" or taller plenum spacer. I imagine the wedge tunnelrams are in the same boat.
CHIP '70 hemicuda...8 sec street car '69 road runner 440 w/ Indy SRs '69 road runner 440-6, 4 speed...Dad's ride '71 Demon 340 resto project '73 Chrysler New Yorker '06 GMC 2500HD LBZ Duramax...toy hauler
[Re: an8sec70cuda]
#3030859
04/05/22 10:20 AM
04/05/22 10:20 AM
Posts: 2,560 A shed in England
Tig
A shed in England
Going to try this, having a 9/16 phenolic spacer machined up very soon.
'74 Challenger..9.46 and 145.9 so far. 4023lb!!!# N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 4:10's and 10.5s. . 9.51 @142.4 with our old mule 580 wedge RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3030894
04/05/22 12:15 PM
04/05/22 12:15 PM
Posts: 3,917 Motor City
6PKRTSE
Motor City
Going to try this, having a 9/16 phenolic spacer machined up very soon. I fabbed up some 1/2" thick anti-reverson plates for under my carbs and also 1/2" thick delrin/nylon insulator/spacer for my tunnel ram. If you look closely it is the white portion between the intake and top plate. I made several and tried none and up to 4 spacers on dyno with no significant power or torque improvements over not having any. Choose to just use the one to help keep the top plate and carbs cooler.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3030917
04/05/22 01:10 PM
04/05/22 01:10 PM
Posts: 39,264 Bend,OR USA
Cab_Burge
What does that manifold look like inside? How big is the plenum? What size carbs did they use?
[Re: mopar dave]
#3030987
04/05/22 03:49 PM
04/05/22 03:49 PM
Posts: 252 PA
Harry's Taxi 2
PA
I removed mine as shown here. I didn't remove as much as I originally intended due to my lack of welding skills causing repeated cracks when cooling. The divider is hollow and requires about 1 1/2" of fill weld. (I'd suggest finding a good welder)
As for how much it helped or hurt, I have no idea as this is a new build waiting on parts.
I also made a 1/2 nylon spacer with a flat 3/8 top plate so the carbs could be shifted forward a little.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: rebel]
#3031012
04/05/22 06:08 PM
04/05/22 06:08 PM
Posts: 252 PA
Harry's Taxi 2
PA
I've seen some older ones that don't have the divider. They also seem to have more symmetrical runners...although that may be at the expense of throttle bore to runner entrance alignment.
Do you have a side view or down runner picture?
[Re: Harry's Taxi 2]
#3031112
04/06/22 04:44 AM
04/06/22 04:44 AM
Tig
A shed in England
No divider on mine (IIRC)
[Re: mopar dave]
#3031116
04/06/22 06:12 AM
04/06/22 06:12 AM
Posts: 252 PA
Harry's Taxi 2
PA
That's what mine looked like before. I'd like to see that view from rebel's
#3031134
04/06/22 08:53 AM
04/06/22 08:53 AM
Tig
A shed in England
It seems Indy re-designed them. Not exactly sure which way round chronologically, I think maybe the later T/R's have less bolts for the top ?. It seems my memory is incorrect, mine DOES have a divider. Date on the photo's are from roughly when it was purchased and kindly sent by Todd Marsh (Sasquatch) many moons ago. Going to try this, having a 9/16 phenolic spacer machined up very soon. I fabbed up some 1/2" thick anti-reverson plates for under my carbs and also 1/2" thick delrin/nylon insulator/spacer for my tunnel ram. If you look closely it is the white portion between the intake and top plate. I made several and tried none and up to 4 spacers on dyno with no significant power or torque improvements over not having any. Choose to just use the one to help keep the top plate and carbs cooler. Hmmm....useful to know. Probably won't make any difference then, my carbs are hanging in the breeze anyway. ![[Linked Image]](http://i.imgur.com/5KFh3IA.jpg) ![[Linked Image]](http://i.imgur.com/AEcXtSn.jpg)
[Re: rebel]
#3031212
04/06/22 12:12 PM
04/06/22 12:12 PM
Posts: 252 PA
Harry's Taxi 2
PA
This is mine as cast. I measured the port from the point it starts to form the port, to the size at the flange base, its 3x larger at the plenum. Those runners look quite a bit different than newer models. It would be interesting to hear Indy's thinking on what the various changes were intended for.
[Re: mopar dave]
#3031219
04/06/22 12:19 PM
04/06/22 12:19 PM
Posts: 252 PA
Harry's Taxi 2
PA
I will talk to Indy today to get their opinion as well. I need to order the spacer from them anyway. If i cant find a professional welder for this, can i just epoxy it? I don't think I'd trust epoxy. it would be solid epoxy for about a 2-3" span between the groups of runner. There would be pretty substantial expansion and contraction with different materials during heating and cooling i would think. an interesting thing i learned was that the plenum volume (poured) was approx. 20+ cu.in. more in the M1 tunnel ram intake i'm using on my current engine vs. the modified Indy intake.
[Re: mopar dave]
#3031602
04/07/22 02:59 PM
04/07/22 02:59 PM
Cab_Burge
