Page 1 of 3 1 2 3
Mopar Transmission For Sale - 2nd Quarter #3029649
04/01/22 05:05 PM
04/01/22 05:05 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Transmission For Sale - 2nd Quarter [Re: moparts] #3029690
04/01/22 05:57 PM
04/01/22 05:57 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
bigblock 727 out of a motorhome short tailshaft with a bolt on yoke,great option for a divoriced tcase,should be gone through as its been setting for several years $50,located in garnett ks,PM me here!
ok,ive jad this listed for a long time with no sale,is there something wrong with this listing,please PM me and let me know if there is!!
thanks!
Butch
my ladder of success is missing some rungs
Re: Mopar Transmission For Sale - 2nd Quarter [Re: moparts] #3029969
04/02/22 01:56 PM
04/02/22 01:56 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Sold
The only Carbs I care about are under the hood!
1964 big block pushbutton transmission [Re: Azzkikrcuda] #3030194
04/03/22 11:06 AM
04/03/22 11:06 AM
New Jersey
Dartforforty Offline
New Jersey
Selling as a core. Removed from a non-running 64 Fury with a 361.
I do not know anything about the internals, park cable is snapped off from shifter mount, other cable is good from what I see. $100.00 pick up in Millstone Twsp New Jersey.
PM me through the board for more details
3G Hemi bell crank [Re: Dartforforty] #3030374
04/03/22 07:42 PM
04/03/22 07:42 PM
BDW Online content
BDW  Online Content
Mopar 53032456AE Bell Crank, this is the part needed to convert manual gas pedal to drive by wire and maintain kick down functionality needed for the 904/727/518 transmissions behind a 3G Hemi.
Fully tested and functional, includes the wiring harness, $125 includes shipping to US
Also have just the sensors for $100, if you don't need the housing.
Here’s a link on how to set-up:
https://www.youtube.com/watch?v=5H6Jt6G5DcA&t=197s&ab_channel=DIYHEMI
Re: Mopar Transmission For Sale - 2nd Quarter [Re: moparts] #3030380
04/03/22 07:56 PM
04/03/22 07:56 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030383
04/03/22 07:58 PM
04/03/22 07:58 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
All parts layed out.jpg (1166 downloads)
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030384
04/03/22 08:00 PM
04/03/22 08:00 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
904 Rear Servo Kit.jpg (1163 downloads)
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030387
04/03/22 08:02 PM
04/03/22 08:02 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any Torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030389
04/03/22 08:04 PM
04/03/22 08:04 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030390
04/03/22 08:07 PM
04/03/22 08:07 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
BILLET 4.2 and 5.0 LEVERS
Billet steel 4.2 and 5.0 ratio front band apply levers for just about any Torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RH, 47RE, and 48RE. Almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These levers are CNC machined from solid billet steel. They are much stronger than the factory powdered metal forging levers, which are known for failing under the higher line pressures that performance transmissions run. The ratio is laser engraved into the tip of the lever in a large font size so it can be easily seen both in and out of the transmission. These are 100% made in the USA. $45 plus shipping. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030391
04/03/22 08:10 PM
04/03/22 08:10 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
SPEEDOMETER BLOCK OFF PLUGS
CNC machined billet aluminum speedometer hole block off plug. These will fit almost every rear wheel drive automatic and manual transmission from 1966 on up. Uses the factory bracket and bolt to secure it to the transmission. Includes a new o-ring. This is a direct bolt in replacement for the factory speedometer adapter, no modifications are necessary. 100% Made in the USA. $30 each plus shipping. If you have any questions or want to place an order email mrrandyj@aol.com
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030394
04/03/22 08:12 PM
04/03/22 08:12 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is zinc coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each plus shipping.
I also have the struts for a 904 transmission, same price
Email mrrandyj@aol.com
Re: Mopar Transmission For Sale - 2nd Quarter [Re: mrrandyj] #3030395
04/03/22 08:14 PM
04/03/22 08:14 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Reverse wound direct clutch pack spring for the 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE. The stock spring in the direct clutch drum loses its tension at high RPM and causes the direct clutches to drag in 1st gear. This spring is wound in the opposite direction which eliminates that problem and keeps the clutches from burning up and also helps eliminate 2-3 shift overlap. This spring should be used in any transmission that will see 5500 RPM or more. This is a direct replacement for the stock spring, no other parts or modifications are necessary. These springs have been through a shot peening process that drastically increases cycle life and they are 100% made in the USA. $30 plus shipping. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!
Clutch adj rod [Re: moparts] #3030974
04/05/22 03:29 PM
04/05/22 03:29 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
NOS MOPAR 2534240 clutch adjust rod
$40 plus ship
PM for more info
clutch adj rod 2534240.jpg (1145 downloads)
Remember when cars were FUN?
Original273 Bellhousing Inspection Cover [Re: roadntrack] #3030999
04/05/22 05:00 PM
04/05/22 05:00 PM
MD
floyd Offline
floyd  Offline
MD
Nice original inspection cover for 273 manual transmission 9.5” bellhousing. Should clean up nicely without any significant pitting. $80 plus shipping from Maryland.
SOLD
Thanks for the ad!
66-74 Auto Trans Floor Shift Lower Shifter Control Bracket [Re: Memongo] #3032354
04/10/22 02:53 PM
04/10/22 02:53 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
1966-74 Automatic Transmission Floor Shift Lower Shifter Control Bracket. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Torqueflite Automatic Transmission Flex Plate [Re: Memongo] #3032357
04/10/22 02:54 PM
04/10/22 02:54 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Torqueflite Automatic Transmission Flex Plate. Used, $35 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Clutch Linkage Fork Release Rod #3467235 [Re: Memongo] #3032358
04/10/22 02:56 PM
04/10/22 02:56 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Clutch Linkage Fork Release Rod #3467235. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
66-76 A B C E Body Speedometer Gear [Re: Memongo] #3032360
04/10/22 02:57 PM
04/10/22 02:57 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
66-76 A B C E Body Speedometer Gear 27 Teeth White. Fit 833, 904 and 727 Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
66-76 A B C E Body Speedometer Gear 34 Teeth Green. Fit 833, 904 and 727 Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Page 1 of 3 1 2 3
