Page 1 of 4 1 2 3 4
For Sale - Big Block Engine - 2nd Quarter #3029669
04/01/22 05:25 PM
04/01/22 05:25 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3029983
04/02/22 02:29 PM
04/02/22 02:29 PM
MI
6PAX Online content
6PAX  Online Content
MI
Used Crane cam #278-2. Cam only, no lifters. $50
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Big block chrome valley pan hold down rails & bolts. $35
Factory oil pressure sending unit. $10
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New exhaust manifold heat stove to air cleaner hose. $20
1970 Single nipple oil breather with hose. $30
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $65
Factory big block coil bracket. $10
New Mr. Gasket chrome oil filter cover. $12
137 Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
9 Chrome t-handle valve cover bolts. $10
2 Moroso chrome valve cover breathers. $20 for the pair.
NOS Cal Custom chrome dagger dipstick handle. $25
Brand new in the box Edelbrock 1403 500 cfm carb. with electric choke. Includes gasket, wiring, instructional dvd. $350
New Mopar Performance 5 blade radiator fan and clutch. $100
As-new never used Edelbrock STR-15 383-400 crossram intake manifold with linkage. $2500
1972 400 oil pump $5
4 Groove crank pulley from a 1972 400. $15
1972 400 spark plug shields $10 pair
5 Blade radiator cooling fan pt. #4266059. $40
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $225
New Mopar Performance chrome big block distributor holddown. $20
New MRE billet aluminum rear main seal retainer for all big blocks. $60
1975 Date coded alternator. Part #3874271. $25
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Alternator date coded 1965. $35
1969 B-body dual snorkel 4 bbl. air cleaner top, base & filter. Lip of base has been trimmed. $200
Prices do not include shipping. I am no longer accepting Paypal for payment.
gt340 @ yahoo.com
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3029993
04/02/22 02:55 PM
04/02/22 02:55 PM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
Pair of 906 big block heads. These were redone many years ago and left sitting on the shelf in the garage. The mice got in and made nests in some of the ports. Will need minor clean up. One stud broken on the exhaust side. Asking $125 for the pair. Contact Bud: Kramden426 at aol.com
1969 440 HP Fresh Rebuild / Just Broke In REDUCED [Re: budman1965] #3030036
04/02/22 06:05 PM
04/02/22 06:05 PM
Southwest Missouri
E
eenloe Offline
eenloe  Offline
E
Southwest Missouri
Here is a 1969 440 HP motor, compete and freshly rebuilt. New everything to stock specs for 1969 Charger track pack car with some modern upgrades. Bored 30" over, stock compression, hardened seats, Edelbrock carb, electronic ignition. It has been through the break in process and has less than 200 miles on it. Car owner changed mind and is going resto mod with Gen 3 Hemi. Complete from air cleaner to pan. Comes with the exhaust manifold extension pipes, radiator and shroud. This was a 4 speed car, so it has the pilot bushing in the crank. PM or call for more information and pictures. I have a video of the motor running in the car. I also have a complete 18 spline Hemi 4 speed set up with new flywheel, pressure plate and clutch if interested. Asking $6,500 OBO for the motor, $3,500 for the full 4 speed set up (Freshly rebuilt Trans, Bell, Flywheel, Clutch, PP Z bar, linkage etc. call Eric, Southwest Missouri. Area code is four, one, seven. Fist three digits are two, three, five. last four numbers are Six, Six, Nine, Three.
440 1.JPG (1932 downloads)
440 2.JPG (1931 downloads)
440 Crank [Re: eenloe] #3030103
04/02/22 10:16 PM
04/02/22 10:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
440 mopar Stock steel forge crank STD mains and Rods
$225.00 plus shipping . Best to pick it up. I know it won't be cheap to ship. SOLD !
B/RB Mopar valve covers [Re: VernMotor] #3030338
04/03/22 05:24 PM
04/03/22 05:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
SOLD
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3030348
04/03/22 06:11 PM
04/03/22 06:11 PM
Concord, CA
Clevj001 Offline
Clevj001  Offline
Concord, CA
Sold!!! 1965 383 complete engine
383 engine complete with 1965 date code.
My father in law purchased to put in his roadrunner but ended up going with something else.
The engine was bought as rebuilt but it was quite a time ago. There is a good story for why it wasn't used I will share with interested parties.
He was thinking SOLD. He is located in lake Havasu city az for pick up. Or I will be driving from lake Havasu to northern California if anyone along the way is interested.
Probably not reasonable to ship but can try if needed.
Let me know if any questions. Willing to make a deal for the right person.
Justin
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3030445
04/03/22 10:57 PM
04/03/22 10:57 PM
montana
BANDIT Offline
BANDIT  Offline
montana
FOR SALE;
3 sets of big block engine mounts for B-engine. You clean and paint them. $45.00 a pair for the ones with bolts, $35.00 for the pair without bolts. Shipping extra. " SOLD "
Also, have a nice pair of 1969 Plymouth Road Runner hood hinges. $50.00. shipping extra.
Still have a lot of 1960's to late 70's heads, intake manifolds, exhaust manifolds, water pump housings, and other engine parts. Call or PM with needs.
PM me or call/text me at 406-489-3534. Thanks, Moparts! Jim SOLD
Hood Hinges.jpg (1739 downloads)
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.50@162. 4900 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.70@ 200mph
383 Block/Crank/Heads FOR SALE [Re: BANDIT] #3030496
04/04/22 09:12 AM
04/04/22 09:12 AM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
For Sale: 1965 383 block, crank, caps, water pump housing, distributor shaft gear and 906 heads.
Crank is still in block with original caps. Check out the pics in the link for the condition.
Please ask all questions before purchase. All sales final.
Located in NE PA.
$500
PM me here.
383 Pics
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
1969 1/2 440 Six Pack/Barrel Edelbrock Intake [Re: moparts] #3030532
04/04/22 11:13 AM
04/04/22 11:13 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I bought this intake with intentions of building a 440 6 pack for a project but now I have too many irons in the fire. $1200 obo.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Fluidamper big block [Re: blue_stocker] #3031755
04/08/22 02:59 AM
04/08/22 02:59 AM
Victorville California
70N96 Offline
70N96  Offline
Used fluidamper for big blocks. Minor scuff marks $ 150. Thx call or text 615-829-9664
WATER PUMP ASSY [Re: moparts] #3031805
04/08/22 11:10 AM
04/08/22 11:10 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Water pump assy from 1969
$70 plus ship
PM for info
1969 water pump housing.jpg (1591 downloads)
Remember when cars were FUN?
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3032303
04/10/22 11:35 AM
04/10/22 11:35 AM
cali
68mannix Offline
68mannix  Offline
cali
440 6pk balancer and rods came out of stock engine good shape but balancer has small dent on back side 575obo located in lake isabella ca 93240 or can deliver to spring fling ion april 23 if payed for
Big Block 383-400 A/C Brackets [Re: moparts] #3033231
04/13/22 04:36 PM
04/13/22 04:36 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block 383-400 A/C Brackets, Used, $80 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
Big Block Spark Plug Wire Bracket [Re: Memongo] #3033234
04/13/22 04:40 PM
04/13/22 04:40 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Spark Plug Wire Bracket. Used, Payment via US Postal Money Order Only!. Shipping: US Address Only!
1. $10 + Shipping
2. $20 + Shipping
3. $10 + Shipping
Wire Loom Brackets 1.jpg (1196 downloads)
Wire Loom Brackets 2.jpg (1191 downloads)
Wire Loom Brackets 3.jpg (1190 downloads)
Big Block Timing Chain Cover [Re: Memongo] #3033235
04/13/22 04:41 PM
04/13/22 04:41 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Timing Chain Cover. Used, $40 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Big Block Water Pump With Water Pump Housing [Re: Memongo] #3033237
04/13/22 04:44 PM
04/13/22 04:44 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Water Pump With Water Pump Housing. Used, $100 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Note: Came off a 1970 383 motor!
Water Pump with Housing.jpg (1227 downloads)
68-69 440 Air Cleaner With K&N Filter [Re: Memongo] #3033239
04/13/22 04:45 PM
04/13/22 04:45 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
68-69 440 Air Cleaner With K&N Filter. Used, $300 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
68-69 Air Cleaner.jpg (1366 downloads)
73-74 Electric Choke #3656730 All Models [Re: Memongo] #3033241
04/13/22 04:47 PM
04/13/22 04:47 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
73-74 Electric Choke #3656730 All Models, Used, $35 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Electric Choke Thermostat 360 400 2 Or 4 Barrel [Re: Memongo] #3033243
04/13/22 04:48 PM
04/13/22 04:48 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Electric Choke Thermostat 360 400 2 Or 4 Barrel. Used, $20 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Page 1 of 4 1 2 3 4
