Wanted - Big Block Engine - 2nd Quarter #3029666
04/01/22 05:24 PM
04/01/22 05:24 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Mushroom lifter [Re: moparts] #3031881
04/08/22 03:03 PM
04/08/22 03:03 PM
Transman Offline
Transman  Offline
Looking for one or more Mopar mushroom lifters. Prefer the old Direct Connection P3690177 lifter.
PM me know if you can help.
wanted: 383 springs retainers and keepers [Re: Transman] #3032657
04/11/22 03:59 PM
04/11/22 03:59 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
FOR MY 68 383 .. CAM IS A 270-470 CRANE SO DON'T NEED EXOTIC STUFF.. JUST QUALITY NEW AFTERMARKET...[NO ALUMINUM RETAINERS..] PREFER MATCHING BRANDED STUFF.. BUT OPEN THANKS
wanted: 383-3.9 arm 450 stroker kit [Re: ph23vo] #3032660
04/11/22 04:00 PM
04/11/22 04:00 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
lmk what you have or know of..not afraid of good used stuff either but prefer new and quality..what ya got or know of? thanks dan
933 valve springs [Re: moparts] #3033832
04/15/22 01:42 PM
04/15/22 01:42 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Looking for a set of unused Mopar Performance 933 valve springs.
1972 Road Runner
1988 Shelby CSX-T
Wanted: 383 distributor [Re: racerx20] #3034176
04/16/22 05:29 PM
04/16/22 05:29 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
I need a points distributor, needs to be pretty clean, greasy is OK but not rusty.
With vaccuum advance.
Wanted Edelbrock Torker 383 [Re: hemienvy] #3035433
04/20/22 07:05 PM
04/20/22 07:05 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I am looking for a Edelbrock Torker 383 intake manifold. I need something that hasn't been modified, and would prefer something that hasn't been painted but that isn't a must. Please let me know if you have one. Shipping would be to 49079. Thanks!
Re: Wanted solid lifter [Re: IROC78] #3037243
04/26/22 01:07 PM
04/26/22 01:07 PM
alabama, usa
burks340 Offline
burks340  Offline
alabama, usa
i need 1 mopar solid lifter and 1 lunati solid lifter for BB phone me at 334-885-6498 jacky
Re: Wanted solid lifter [Re: burks340] #3038056
04/28/22 09:29 PM
04/28/22 09:29 PM
Want to buy a stock dual point 1970 440 distributor with vacuum advance in good to excellent shape. help
PM me on here or E mail me at cabburge@wans.net.
Thanks: Cab
440 Lean Burn Dual Pickup [Re: Cab_Burge] #3038179
04/29/22 10:22 AM
04/29/22 10:22 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
looking for a 440 lean burn Dual Pickup distributor in good to new condition.
Let me know what you have. Thanks
Re: Wanted - Budget Friendly 2x4 intake for RB [Re: moparts] #3044346
05/22/22 03:42 PM
05/22/22 03:42 PM
moparx Offline
moparx  Offline
i'm looking for a Budget Friendly 2x4 inline Aluminum intake. that is, if something like this even exists.
stripped threads, bad mating surfaces, cracks, are ok.
PM me here or : moparxz "at" comcast "dot" net.
a BIG thanks for the add Moparts ! up
beer
Wanted Water Pump Housing [Re: moparx] #3045537
05/27/22 07:12 AM
05/27/22 07:12 AM
west palm beach, florida
modelmakerinc Offline
I am looking for an Aluminum Water Pump housing with the passenger side inlet for a big block w150
Also a Eddy RPM intake for Lo Block. 383/400 pm here please cash waiting.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Wanted 383 parts [Re: modelmakerinc] #3045878
05/28/22 01:05 PM
05/28/22 01:05 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Looking for a 2120510 spacer for a standard fan/22” radiator.
Also, a choke cup for a standard cast iron intake.---FOUND
Both for 1970 383.
PM me
Wanted 440 block [Re: RP's R/T's] #3047760
06/03/22 10:18 PM
06/03/22 10:18 PM
Bethel, Ohio
70rrclone Offline
70rrclone  Offline
Bethel, Ohio
I am looking for a good used 440 block with main caps no more than .030 over. I don't need anything special. looking for something in the Louisville Ky area.
E-mail: 70rrclone@sbcglobal.net
or text or call 937-768-4211
Thanks Shane
Re: Wanted - Big Block Engine - 2nd Quarter [Re: moparts] #3048346
06/06/22 03:59 PM
06/06/22 03:59 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
RB Mopar Performance single plane M-1 4150 1x4 intake wanted. Thanks!
Bcfkody@comcast.net
Re: WTB...good 68-71 383 blocks [Re: blue_stocker] #3049155
06/09/22 03:53 PM
06/09/22 03:53 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Try this again sorry if I didn’t reply but COVID BS
Looking for ATI BBM balance with chevy front bolt pattern or crank hub.
Thanks, Roger
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Wanted - Big Block Engine - 2nd Quarter [Re: moparts] #3049970
06/12/22 03:46 PM
06/12/22 03:46 PM
Maryville tn
67coronetman Offline
Maryville tn
I am looking for a old school mopar cam.
I am wanting the Old school grind purple shaft cam
292/509 for a big block mopar.
PM me if you can help
Old car are me......
Re: Wanted - Big Block Engine - 2nd Quarter [Re: moparts] #3049988
06/12/22 05:25 PM
06/12/22 05:25 PM
Ohio
RT440Dodge Offline
RT440Dodge  Offline
Ohio
***Wanted*** A new P4529071 >>> 69-71 Mopar 440 Magnum Air Cleaner Tin Insert with Orange Logo. 937-270-6120 or evanscr1964@gmail.com. Chris
Re: Wanted - Big Block Engine - 2nd Quarter [Re: moparts] #3050018
06/12/22 07:58 PM
06/12/22 07:58 PM
Out of the State of Confusion
blue_stocker Offline
I am still looking for std bore 68-71 383 bare blocks, with or without main caps. Other than normal wear, no damage. PM me here if you have something I may be interested in within 230 miles of Savannah, Tenn. Thanks...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Re: Wanted - Big Block Engine - 2nd Quarter [Re: blue_stocker] #3050201
06/13/22 01:23 PM
06/13/22 01:23 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
Hello, looking for roller rockers for B-1 original heads, lead times for new T & Ds are 20 weeks out, thanks in advance!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
