Mopar Differential For Sale - 2nd Quarter
#3029648
04/01/22 05:04 PM
04/01/22 05:04 PM
Posts: 15,154 Norwich CT USA
moparts
Norwich CT USA
Re: Mopar Differential For Sale - 2nd Quarter
[Re: moparts]
#3029680
04/01/22 05:36 PM
04/01/22 05:36 PM
Posts: 855 Edison, NJ 08817
budman1965
Edison, NJ 08817
Shock plates and U-bolts for 8 3/4 and Dana rears: Pair of shock plates for I believe 1970 E-bodies only SOLD! 2 pairs of shock plates SOLD! Set of 4 U-bolts with 8 nuts-painted $30 Set of 4 U-bolts with 4 nuts-rusty $25 Contact Bud: Kramden426 at aol.com
New 4.56 Gear Set for 9 -1/4"
[Re: moparts]
#3031126
04/06/22 07:36 AM
04/06/22 07:36 AM
Posts: 1,262 Oregon
earlymopar
New Richmond 4.56 Gear Set for 9 -1/4" = $200 + shipping (sells for $388 on Summit)
Please PM me here. Parts are located in Newberg, Oregon
[Re: moparts]
#3031356
04/06/22 06:52 PM
04/06/22 06:52 PM
Posts: 1,261 Way out in the sticks of Weste...
DusterDog
I have a set of Strange Engineering 35 spline axles that are in real nice shape. Screw in 3inch long 1/2 inch studs, with green bearings already on them. Axles measure 22 5/8, & 23 5/8. Splines are 3 1/4 long.
$225.00 for the pair plus actual shipping. PM me here (first preference), or e-mail me at duster doug at comcast dot net...
Thanks for the ad Moparts!!!
"I've upped my horsepower, so...... UP YOURS!!!"
Drive Shafts
[Re: Memongo]
#3032984
04/12/22 07:53 PM
04/12/22 07:53 PM
Posts: 221 Southwest Missouri
eenloe
Southwest Missouri
I have a collection of drive shafts for sale. See the list below for prices, sizes and applications based on available data. Please research your needed size as well before purchasing. Length dimensions are from center line of u joint to center line of u joint. All shafts are or will be cleaned, painted and have fully cleaned and greezed u joints installed. A couple of pictures attached to show condition. If you will let me know what size differential yoke you have, I can make sure the shaft has the correct U joint for direct installation right out of the box. PM me with your phone number so we can talk and get ship to address to get you a total price estimate. Thanks Moparts for the space. 1) 1967 - 1969 Dodge Dart with 727 auto or A-833 4 speed, big block and 8 3/4" differential. 51 1/2" CL to CL, 3 1/4" diameter, New 3 1/2" U joints. $450 obo 2) 1971 Plymouth Roadrunner / GTX / Satellite with big block / Hemi, 727 auto or A833 4 Speed, and 8 3/4" differential. 50 11/16" CL to CL, 3 1/4" Dia, 3 1/2" U joints, $450 obo 3) 1967 Plymouth Belvedere / Satellite / GTX with 727 auto or A833 4 speed, V8 and 8 3/4" differential. 51.03" CL to CL, 2 3/4" Dia, reonditioned 3" U joints. $250 obo 4) 1972 Plymouth Belvedere / Satellite / Roadrunner with slant 6 or low performance V8, 727 auto or A833 4 speed and 8 3/4" differential. 57.42" CL to CL, 2 3/4" Dia, 3" U joints. $100 obo 5) 1967-1976 Dodge Dart with 904 Auto or A233 3 speed, slant 6 or small V8 and 7 1/4" differential, 54.36" CL to CL, 3" Dia, reconditioned 3" U joints. $100 obo 6) 1966 Plymouth Belvedere / Satellite / Dodge Coronet and Charger with slant 6 or low performance V8, 727 auto or A833 4 speed and 8 3/4" differential, 55.42" CL to CL, 2 3/4" Dia, 3" U joints. $100 obo 7) 1974 Plymouth Challenger with slant 6 or small block low performance V8, 904 auto or A233 3 speed and 8 1/4" differential. 2 3/4" Dia, 3" U joints. $100 obo
[Re: dsd70bee]
#3034079
04/16/22 10:50 AM
04/16/22 10:50 AM
Posts: 11,703 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NOS 1828719 PINION SEAL,WILL FIT 8 3/4 DODGE 742 # CASE 1 3/4 PINION 65-68$30 mailed
cowgerwilliam035@gmail.com
[Re: moparts]
#3036045
04/22/22 01:51 PM
04/22/22 01:51 PM
Posts: 1,938 USA
Suregrip391
USA
This was custom built for a 68-70 B-body. 3.54 truck Dana with a 1969 clutch type Powr-Lok inside, all new bearings, seals, gaskets, factory 3.54 gears, new 1350 pinion yoke, snubber, all basically new and professionally built locally by a shop, never run….. $2300 picked up in Niagara Falls NY.
[Re: moparts]
#3040606
05/07/22 04:41 PM
05/07/22 04:41 PM
budman1965
Edison, NJ 08817
8 3/4 center section. Bare 489 case with hardware, bearing caps, screw adjusters, races etc. SOLD! Contact Bud Kramden426 at aol.com
[Re: cudaboy]
#3045561
05/27/22 09:09 AM
05/27/22 09:09 AM
Posts: 100 Malvern Pa
500ci barracuda
Malvern Pa
3.91 Getrag axle swap kit for 2005-2009 Chargers, Magnums, 300’s.
Diff, axle shafts, hubs, bolts.
New, never installed but has been in the garage for a few years.
$2300 or reasonable offer
Located in Bowling Green, KY.
No shipping but I can drive up to 100 miles to meet you with a small deposit.
When you say diff, is it a complete diff with a posi. Mark
