Page 2 of 8 1 2 3 4 5 6 7 8
Re: 572 all aluminum headed to dyno [Re: fbs63] #3012429
02/05/22 11:50 AM
02/05/22 11:50 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looking forward to the results.
69 GTX 68 Road Runner
Re: 572 all aluminum headed to dyno [Re: CokeBottleKid] #3012543
02/05/22 06:17 PM
02/05/22 06:17 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Originally Posted by CokeBottleKid
Interested in the dry sump setup, any lifter valley scavenging?
iagree Any more pictures/details on the oiling system?
Awesome engine!
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 572 all aluminum headed to dyno [Re: fbs63] #3012599
02/05/22 09:12 PM
02/05/22 09:12 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Originally Posted by fbs63
[quote=B3422W5]Who specc’ed the cam?
If Best Machine built it I'm betting they came up with the cam grind. [/quote
I have had them do a motor and had the cam for it elsewhere... which I why I ask
In my case I took Dwaynes recommendation
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 572 all aluminum headed to dyno [Re: metallicareload] #3012610
02/05/22 09:46 PM
02/05/22 09:46 PM
AndyF Online content OP
AndyF  Online Content OP
Awesome engine!
Nothing special in the oiling system, mostly off the shelf parts. Aviaid billet pan and a Peterson R4 pump. Here is a link to the pan: https://www.aviaid.com/shopsite_sc/store/html/mopar-oilpans.htm
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012712
02/06/22 11:59 AM
02/06/22 11:59 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Did the heads get 2.25” intake valves installed?
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3012719
02/06/22 12:20 PM
02/06/22 12:20 PM
Yes, heads were reworked to match this shortblock. Chambers opened up for the 4.50 bore size, 2.25 valves, etc.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012859
02/06/22 08:11 PM
02/06/22 08:11 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
It seems like a small head for what otherwise seems a pretty aggressive setup, any reason why? S/F....Ken M
Re: 572 all aluminum headed to dyno [Re: EchoSixMike] #3012869
02/06/22 08:55 PM
02/06/22 08:55 PM
It is what the customer wanted to do. It makes sense based on the customer's plan for his car.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012912
02/06/22 11:15 PM
02/06/22 11:15 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I've not seen a duration split like that on a Big block, it's pretty common on high HP small blocks though.
Will be interesting to see the results
Alan Jones
Re: 572 all aluminum headed to dyno [Re: LA360] #3012915
02/06/22 11:21 PM
02/06/22 11:21 PM
Some LS engines come from the factory with 20 degrees more exhaust duration. I don't know why they do that but they do. I think the LS7 engine has about 20 degrees more duration on the exhaust than on the intake and that is a production engine right off the showroom floor.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3012951
02/07/22 07:27 AM
02/07/22 07:27 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
When is dyno day?
Re: 572 all aluminum headed to dyno [Re: JERICOGTX] #3013024
02/07/22 01:30 PM
02/07/22 01:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have run exhaust splits that far many times on a BB. We have run as much as 16 degrees more on the exhaust side. Be screwing a new Predator together here soon and based on past experience it will have at least a 10 degree split(cam is the only thing we have not decided on yet). Expecting to to make 1130-40 with a very bracket friendly single 4 combo for stop racing.
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3013056
02/07/22 02:49 PM
02/07/22 02:49 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by 440Jim
Originally Posted by AndyF
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive.
Is it too early for me to guess 920 HP? But the small headers may reduce peak HP.
Any other guesses?
For the record, using those small headers I am subtracting 30hp. 890 HP with the peak below 7,000 rpm.
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3013061
02/07/22 03:00 PM
02/07/22 03:00 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Any other guesses?
I'll guess 904hp. Peak around 6700.
Re: 572 all aluminum headed to dyno [Re: LA360] #3013086
02/07/22 03:46 PM
02/07/22 03:46 PM
gregsdart Offline
gregsdart  Offline
Indys suggestion to me for a 572-13 head on 550 cubes was 285/305/112 in at 108. Considering those heads come with a 1.88 exhaust valve, i was surprised . They also said max lift of . 825. I will make due with my 284/296/114 with . 868 gross intake lift. Considering lash etc i will be below . 848 net lift intake.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3013112
02/07/22 05:11 PM
02/07/22 05:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sounds like a beast.
Rich H.
Esse Quam Videri
Re: 572 all aluminum headed to dyno [Re: JERICOGTX] #3013134
02/07/22 06:31 PM
02/07/22 06:31 PM
Any other guesses?
PipeMax says 904 hp too.
Re: 572 all aluminum headed to dyno [Re: 440Jim] #3013550
02/08/22 10:36 PM
02/08/22 10:36 PM
Any other guesses?
We made a few pulls today. It made 870 power at 6800 and 760 torque at 5400. Found a few items to work on. Not sure if we'll put it back on the dyno or just make the changes and put it in the car. Depends on what the owner wants to do. No doubt in my mind that it would easily make 900 hp with some minor changes.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3013552
02/08/22 10:39 PM
02/08/22 10:39 PM
Used the clear valve cover to verify top end oiling. Everything looked great. This engine uses pushrod oiling with the T&D rocker arms. The engine ran great, no leaks and only a tiny bit of aluminum trash in the pre-filter. We cleaned the filter after each dyno pull and by the third pull the filter was spotless.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3013557
02/08/22 10:52 PM
02/08/22 10:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
very nice
