ujoint travel smoothness #3028933
03/30/22 10:14 AM
03/30/22 10:14 AM
RapidRobert Offline OP
Happy Birthday RapidRobert  Offline OP
circle track app. I had my driveshaft shortened/balanced/new ujoints. the front yoke was smooth in one plane (the yoke plane) & rough/slightly binding along the travel on the driveshaft side. the other end was was way more rough/slightly binding in its plane of movement. I took it back & they said they helped it a bit but it is still as described & they said it is OK. I,m not comfortable with this, what do YOU guys think, is this a non issue? I'm thinking it should be smooth movement in all planes of movement. thank you for your time. RR
Re: ujoint travel smoothness [Re: RapidRobert] #3028938
03/30/22 10:27 AM
03/30/22 10:27 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
should be smooth on each plane.
Crunchy is bad. A little drag I can live with , but if it seems to be sticking in spots , I'd be concerned.
Re: ujoint travel smoothness [Re: tubtar] #3028943
03/30/22 10:55 AM
03/30/22 10:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
iagree They either bent the yokes installing them or got crud in there when putting them together. Should be smooth is all directions
Re: ujoint travel smoothness [Re: JohnRR] #3028966
03/30/22 12:00 PM
03/30/22 12:00 PM
not a crunch but not smooth across the plane, some spots are a bit significantly tighter than others. Alright I will try a better shop. thank you!
Re: ujoint travel smoothness [Re: RapidRobert] #3028967
03/30/22 12:05 PM
03/30/22 12:05 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I've seen it with the bent yokes. They can get pretty tight though mine were reasonably smooth. It was a street vehicle so I ran it. On a race car, I would fix it.
Re: ujoint travel smoothness [Re: BigBlockGTS] #3029231
03/31/22 02:38 PM
03/31/22 02:38 PM
moparx Offline
moparx  Offline
i would fix it no matter what application !
something isn't right as it is now.
possibly bent yoke, deformed cap or caps, crud inside with the bearings, the joint not centered in the yoke, etc.
as has been said, the joint needs to move smoothly in all directions.
beer
Re: ujoint travel smoothness [Re: moparx] #3029236
03/31/22 02:43 PM
03/31/22 02:43 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
^^^ Agree - a small problem like that can become a big problem, and never at an opportune time.
Re: ujoint travel smoothness [Re: RapidRobert] #3029277
03/31/22 04:53 PM
03/31/22 04:53 PM
Fix it now before it costs more money later work up
Re: ujoint travel smoothness [Re: Cab_Burge] #3029282
03/31/22 05:22 PM
03/31/22 05:22 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
How about the driveshaft place you had it shortened at. How good are they is it true. Anyone else near you to give there 2 cents in person. Maybe a new U Joint had a dry spot or been sitting and was dry in a spot but check how true everything is and see what seem to be wrong. I would not want to take it for a long drive and have it come home on the hook. You will aways be thinking about it when you go for a drive. If you are going to run the car at the track good enough is never good enough unless you have trailered it to the drag strip, even then it suck coming apart and having to fix something that should of been looked at.
1971 HEMI E BODY REGISTRY
Re: ujoint travel smoothness [Re: hemicar1971] #3029296
03/31/22 06:29 PM
03/31/22 06:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Caps need to be seated out against the clips after installing. Try that. Take it apart and look at it. Should be smooth. Not unusual to be "snug" when new, but not rough.
Re: ujoint travel smoothness [Re: CMcAllister] #3029452
04/01/22 09:26 AM
04/01/22 09:26 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What brand U-joints did you use?
Re: ujoint travel smoothness [Re: RapidRobert] #3029495
04/01/22 11:53 AM
04/01/22 11:53 AM
I would not use any part in any race car that I had any doubts about twocents work
Do you want to die whistling
AKA, it is talking to you saying "HELP, I'M broken and damaged" scope
if you can feel roughness and or binding it isn't perfect or correct work
