NA Gen3 times #3008441
01/24/22 09:55 AM
01/24/22 09:55 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
This is some NA Gen3 times, I do not know the weight of these, just some good info
Re: NA Gen3 times [Re: CSK] #3008727
01/25/22 08:58 AM
01/25/22 08:58 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Would be interesting to know more details about the builds behind those times, especially since (other than some of the Drag Pak Stock Eliminator cars), all the G3 Hemis I recall seeing going 9s have been blown or nitrous cars. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: NA Gen3 times [Re: Brad_Haak] #3009053
01/26/22 12:43 AM
01/26/22 12:43 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Or both.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NA Gen3 times [Re: Brad_Haak] #3009105
01/26/22 09:45 AM
01/26/22 09:45 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Second on the list:
Engine, 434 displacement, Thitek heads, ported D.P. Intake, 2" Custom headers, 6.1 lifters, wet sump with Melling oil pump
connected to NAG1 transmission, +14:1 CR
Race weight 3135ibs
N/A: 1.28 60', 9.065, 152.95 MPH, DA +1900
He has a Dart chassis car now.
Re: NA Gen3 times [Re: RTSE4ME] #3009118
01/26/22 10:29 AM
01/26/22 10:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those all seem to be modern cars but Ray Meyers(Sixpackgut) was running 9.60s in 2016 with his G3 67 Barracuda.
68 Barracuda Formula S 340
Re: NA Gen3 times [Re: Bad340fish] #3009712
01/27/22 07:29 PM
01/27/22 07:29 PM
Renton Washington
Triple Threat Offline
Renton Washington
They're out there, Mine goes 9.70@137, 3250#, 67 dart, 5.7 392 NA and a powerglide.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: NA Gen3 times [Re: Brad_Haak] #3022084
03/08/22 08:55 PM
03/08/22 08:55 PM
SC304 Offline
SC304  Offline
I agree what details can be shared on these low ET’s.
The number one qualifier especially.
Re: NA Gen3 times [Re: SC304] #3027357
03/25/22 11:49 AM
03/25/22 11:49 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
A few months ago there was a guy at the Houston track (maybe the same Rick on the list) with a 1500 ram that went 9:55. I talked to him quite a bit. It is a 480 inch, max build. His truck has glass doors, etc., and weighs 3400 lbs.
Re: NA Gen3 times [Re: TheOtherDodge] #3027522
03/25/22 07:45 PM
03/25/22 07:45 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Yes thats him.
Re: NA Gen3 times [Re: TheOtherDodge] #3027790
03/26/22 03:42 PM
03/26/22 03:42 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
771 HP according to walace with those numbers, I bet it would be a bit higher in reality though because of the aerodynamics of a full size truck pushing through the atmosphere. What was the MPH?
Re: NA Gen3 times [Re: HotRodDave] #3028423
03/28/22 05:47 PM
03/28/22 05:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
[i][/i]
I know someone with a legit easy 9’s gen 3 complete engine he would sell. He sold the car it was in( drag pack) to go NSS racing.
Aluminum block, etc, etc.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: NA Gen3 times [Re: HotRodDave] #3029473
04/01/22 10:51 AM
04/01/22 10:51 AM
Houston, Texas
Houston, Texas
His MPH was pretty low for his ET, something around 135. He said he get's a lot of his ET with his 60ft (in low 1.3).
Re: NA Gen3 times [Re: CSK] #3062145
07/24/22 03:59 PM
07/24/22 03:59 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Went 9.40s back in 2021 in my 2009 Ram .with my 463G3BGE block (4.165X4.25) Apache heads,2.225X 6mm Intake valve 1.65X7mm Exhaust Valve. 905 Jesel Dog bone lifters and Harland sharp rockers .,LSM custom grind .700/.715 255/265. Intake manifold was made from 2 RO7 intake manifold...Lots of welding, the Fuel Injectors were 3 inches down from the "carb" mounting pad, Sony's TB
Truck uses a 2X3 Frame from Autoweld out of Danville Pa, the front clip is from art-fiberglass. truck weighs in at 3650. rest of the truck is OEM sheet metal,trans is a modified T56 Best pass was 9.40@ 148 . on the Dyno it made 845Hp@ 8200 , Wallace calc put's its on track hp#s about 20hp Higher then the dyno cell.
the Guy I bought the truck from, ran 9.80s@135 as far back as spring 2016 with a 460CI G3 , 4.20X4.20 (sleeved 6.1) , That combo had Thiket(SP) heads and big .700 lift Custom Comp cams bought through BES and a Dragpak intake, Jesel Lifters and Rockers.
My 488(4.25X4.30) that was built for my truck earlier this year, I got 3 passes on it in April at Island Dragway, 1st pass was 9.90@139 next pass it ran 9.19@150 .Last pass was 9.20 at 149.9. cam broke behind the 1st journal sheared right off.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
