Re: '69 RR, #s
[Re: topside]
#3027266
03/24/22 11:58 PM
03/24/22 11:58 PM
Posts: 9,373 Someplace you aren't
SomeCarGuy
I really wish somebody made the magnums with trim rings in 15s. Would simplify my life for sure.
Check out the commentary at the bottom about the dash. Lol
I want my fair share
Re: '69 RR, #s
[Re: topside]
#3027281
03/25/22 04:05 AM
03/25/22 04:05 AM
Posts: 5,463 Germany
fc7_plumcrazy
Germany
The problem with "wrong" Magnums is this: If you want to fill up the wheelwells with a 15" wheel & tire but want an OEM look, it's about impossible as far as I can tell. Main problem is no accurate-looking 15" trim rings. I used to run 14x7 Magnums with Ford trim rings on my '69-up B-bodies when there were a lot of 14" tire sizes. Looked pretty good on a B-body with 225/70 & 235/70 tires, and handled better. Apparently, there are no "recall" wheels on the horizon, so options in the "middle ground" so to speak are very restricted. all the needed 14" tires are available at kelseytires  Carsten
Re: '69 RR, #s
[Re: blewbyu]
#3027312
03/25/22 09:40 AM
03/25/22 09:40 AM
69x
of course it has incorrect wheels as most 69's do. But an inprovement over the 14' with trim rings if you ask me. Hardley, and not asking you
Re: '69 RR, #s
[Re: blewbyu]
#3027334
03/25/22 10:49 AM
03/25/22 10:49 AM
Posts: 20,230 It's a dry heat
gtx6970
It's a dry heat
of course it has incorrect wheels as most 69's do. But an inprovement over the 14' with trim rings if you ask me. Agreed, There aint a 14" tire out there made that will fill up the wheel house either from the side AND the rear like a 15" tire can
