Re: 318 To 360 Swap
[Re: VL21]
#3025798
03/20/22 04:13 PM
03/20/22 04:13 PM
Posts: 989 Atlanta, GA
mgoblue9798
Atlanta, GA
I have a 78 Aspen wagon with a 318 and I am swapping it out for a fresh 360. I remember that the 318 and the 340/360 had a different mount on one side. I went on RockAuto's site and they are showing the same part numbers for both 318 and 360. What gives? Any input on this is greatly appreciated. The 360 was a factory option, someone surely has the bracket, if originality is a factor. Me, I would space it. Is the Rock auto part just the insert? That would make sense. Sniper posted a pic of drilling out the air injection port. The first set of headers i installed on a set of these heads made me ponder, until I realized they were completely blocked with carbon, so I just ignored them, and as long after that I knew of the where abouts of that car, it never was a problem. (next owner liked the car so much he kept it until rust killed it). All of the new type bolt through motor mounts on cars from about 73 on to late eighties have the oval bolt through mount isolators. This is what the parts stores sell as a motor mount. No brackets included. .
Re: 318 To 360 Swap
[Re: trw1982]
#3025835
03/20/22 06:35 PM
03/20/22 06:35 PM
Posts: 309 delhi,il
trw1982
delhi,il
after i looked at mounts at aap online, i got an email for 15% off. i called the store and was told that you get 25 % off if you come in, order parts and sign up for speed perks. i will go in tomorrow and order the mounts to put on shelf. here are pics of parts. sorry pics are sideways.
Re: 318 To 360 Swap
[Re: mgoblue9798]
#3025873
03/20/22 08:32 PM
03/20/22 08:32 PM
Posts: 9,546 Freeport IL USA
poorboy
Freeport IL USA
I've done several 360 swaps on late 60's and early 70's a-bodies. I had never done the swap on an f-body before. Will be running a 727 and already have the proper B+M flex plate. Will be using headers for the exhaust. I know the driveshaft will have to be shortened. Was just curious as to why RockAuto was showing the same numbers for complete mount assemblies on both engines. Guess I will shim the new mount. Thanks guys. Yes you'll have to shorten driveshaft. I've had several shortened on my M bodies. No local shops to balance them after shortening. The shop that shortened them insisted I did not have to have it balanced after shortening. I was skeptical but so far so good and I have not had a problem but I sure would prefer to have it re-balanced. I believe you'll need a different yoke as well. yoke on the 904 transmissions is smaller than the 727 I have had several drive shafts shortened without rebalancing. As long as the ends are clocked the same and the shaft is welded back up on the lathe while turning they have been fine with no ill effects. Bubba's booger welds would not work well though. I've shortened lots and lots of driveshafts without a lathe, and without rebalancing them. They have been in dirt track cars, 10 second drag cars, heavy duty work trucks and street cars. Correctly clocking the yokes and making sure they are straight in the shaft tube solves the balance issues, as long as the shaft wasn't bent to start with and the shaft doesn't have a rubber mounted core inside that is in the way of the new yoke position. The yoke also has to be the correct size for the tube used, sometimes shortening the shaft will encounter a change the diameter from where the yoke originally fit and where it ends up on the shortened tube. I won't shorten those shafts.
Re: 318 To 360 Swap
[Re: poorboy]
#3026531
03/22/22 07:06 PM
03/22/22 07:06 PM
Posts: 12,670 Central Florida
larrymopar360
I'm tired...Very tired.
Central Florida
Facts are stubborn things.
Re: 318 To 360 Swap
[Re: 5thAve]
#3026735
03/23/22 11:43 AM
03/23/22 11:43 AM
larrymopar360
Central Florida
Aftermarket got cheap and doesn't want to do two different mounts. When I had to replace my mount years ago they were still selling them with two different part numbers but it was the same 318 part in all the boxes. Figures. Reminds me of heater cores that don't fit in M bodies despite the aftermarket saying they do.
