Re wiring the Demon with M&H harness, and the original 5 wire ignition switch is being changed out as well as the ignition switch harness was cut.
While in the column, I noticed the key buzzer harness (two red wires) was also cut. Where does the two plug buzzer harness connect to please?
*** EDIT - got it solved. Plugs into the IGN. switch connector!
GY3 71 Demon 340
