Re: E-body front sway bar choices
[Re: hemienvy]
#3025471
03/19/22 03:27 PM
03/19/22 03:27 PM
Posts: 27,451 So Cal
autoxcuda
So Cal
Hellwig hollow/tubular is best value for front. The Ebody bars are very simple all brands will function same. Hotchkis is best fine detail and fine quality. Do you need the added roll resistance of the 1 1/4” vs the hellwig 1 1/8” ? The Hotchkis comes with weld on tabs that look sorta stock. But if you already have tabbed lower control arms, that’s irrelevant. Sounds like a aggressive street driven car… I think Hellwiig would be appropriate
[Re: hemienvy]
#3026051
03/21/22 02:05 PM
03/21/22 02:05 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Go with the 1.25" hollow front sway bar... multiple distributors not just Hotchkis... FF also sells it (and at a lower cost).
For the rear, request FF to make you a larger than stock (3/4" solid rear bar)... ask them to make you at least 7/8" or better yet 1". I have a 1" stock shaped rear solid bar... far better than the skinny factory 3/4" rear bar. I suggest this because our E-bodies are nose-heavy, even with a small block, worse with a BB. A larger rear bar, such as 1" diameter, will much better reduce the common understeer that our E-bodies have, and... it is not overly large in comparison to the factory 3/4" rear bar. You will only say.. wow... a 1" rear bar (with a 1.25" front bar) is THE BETTER SETUP. Its much better balanced setup.
Or else, get a low-cost (with high quality, IMO) HELWIG rear bar.. measures 7/8" diameter, easily mounts to the differential and is 3-step adjustable... set it at the third step of maximum stiffness.
By the way, the FF front hollow 1,25" bar actually measures at 1-5/16" (per my caliper measuring). Also...... be certain to check the front sway bar end-link area.. it may require slight radius grinding to better clear the LCA.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
