Re: Botching my Cam Swap [Re: A39Coronet] #3025233
03/18/22 06:22 PM
03/18/22 06:22 PM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by A39Coronet
Originally Posted by MarkZ
Is this a brand new, flat tappet cam? How long have you been trying to start it? The break-in lube is probably gone at this point and firing it now would wipe the cam on break-in. Motor needs to fire almost immediately when breaking in a new flat tappet.
Ideally yes but I've had two instances where we spun the motor over for a heck of a lot.longer than OPs stated 60 seconds and both motors were fine. One is videoed on my YouTube channel where we were trying to do break in in cold weather. Both times the cam was fine and the car went on to make 100s of 1/4 mile hits without issue. I've had guys tell me "if it don't start on the third spin take the cam out it's junk". Doubtful.
Agreed. And being a 318, likely using mild valve springs which lessens the likelihood of s failure.
Re: Botching my Cam Swap [Re: A727Tflite] #3025461
03/19/22 02:30 PM
03/19/22 02:30 PM
Mid TN
2BblHarold Offline OP
Mid TN
Yay, success today! I redid the basics, confirming compression TDC on #1, and I got really nit-picky about the rotor position. I repositioned the intermediate gear untii I was able to get the rotor to point exaclty at the #1 terminal, not a ballpark as before. I think the trouble is that with the intake I'm running (LD4B) the 6 and 8 runners offer too much interference to the vacuum advance, eating up a range of sweepability of the distributor. For my previous attempts, I'm guessing I happened to have the shaft keyed to a spot that does not allow the sweep to be in the range I needed it.
Thanks fellers!
