trying to find torsion bars #3016003
02/16/22 02:05 PM
02/16/22 02:05 PM
coquille oregon
1savoyracer Offline OP
coquille oregon
Been looking for a set of torsion bars for my 1963 Plymouth Savoy drag car, [mine are bent]............The bars I am looking for are 30 degree offset, 41 inches long, and .860 diameter........I have looked at firm feel, and wildcat, with no luck, I am hoping someone in here might know where i can find a set...........thanks Tom
Re: trying to find torsion bars [Re: 1savoyracer] #3016027
02/16/22 02:48 PM
02/16/22 02:48 PM
AndyF Offline
AndyF  Offline
I have some used 0.860 bars on the shelf if you want to make the drive up from Coquille.
Re: trying to find torsion bars [Re: AndyF] #3016028
02/16/22 02:53 PM
02/16/22 02:53 PM
coquille oregon
coquille oregon
30 degree, 41 " long?...........heck yes...........my email is jarvisroads@msn.com.............name is Tom Jarvis............send me your address, phone number and how much you want for them. I can be there tomorrow, friday, or sunday
Re: trying to find torsion bars [Re: 1savoyracer] #3016032
02/16/22 03:12 PM
02/16/22 03:12 PM
AndyF Offline
AndyF  Offline
Yes I have three sets of the 0.860 bars sitting here, a couple sets of 0.880 and some 0.900 bars. I'm in Wilsonville so a bit of a long drive for you up from Coquille. These are all original bars pulled out of cars over the years. Most still have the original paint and the original paint splotch ID marks.
Re: trying to find torsion bars [Re: 1savoyracer] #3016088
02/16/22 05:53 PM
02/16/22 05:53 PM
A727Tflite Offline
A727Tflite  Offline
What do you mean by 30 degree offset? The amount the ends have regarding twist ?
Re: trying to find torsion bars [Re: A727Tflite] #3016226
02/17/22 08:47 AM
02/17/22 08:47 AM
coquille oregon
coquille oregon
I believe that is correct.....hopefully someone in here can clarify that, I am just trying to find what i was told.
Re: trying to find torsion bars [Re: 1savoyracer] #3016267
02/17/22 12:20 PM
02/17/22 12:20 PM
AndyF Offline
AndyF  Offline
That is correct, factory bars are pre-stressed half a flat against the load. Twisting them half a flat works out to be 30 degrees of pre-stress.
Re: trying to find torsion bars [Re: 1savoyracer] #3024491
03/16/22 09:57 AM
03/16/22 09:57 AM
Cumming Georgia
cspracer Offline
cspracer  Offline
Cumming Georgia
Did you get the bars you needed? I just got a set of the 1857775/1857774 from Bluestarperformance. They are a sponsor on here and the fellow was very good to work with. He even called me up to say they could not find the original set he had a picture of and wanted to make sure I did not care about the date code on them. Ended up shipping me a set that were the same part number and will work well for my application. Shipped to my home in just a couple of days.
Now my question to the group is this, why do I want these bars, .86 diameter for drag racing? It seems a bit counter intuitive to me that I would want the light weight bars, (I do not think it is about saving weight is it?). I would have thought you needed a heavier bar to help transfer weight back to the rear of the car on launch vs the lighter weight. Does the light weight flex more and improve the distribution front to back?
I just know the set that was in my car is mismatched and since the car launches with an extreme twist, I feel like these bars will help. I am just not exactly sure why!
1968 - 383 Roadrunner 4 speed street car, Dad bought new
1970 - 440 Roadrunner drag footbrake car 6.99 1/8th
2016 - Hemi RAM 1500 - Hauls all the toys
North Georgia / Central NC
Re: trying to find torsion bars [Re: cspracer] #3024541
03/16/22 12:31 PM
03/16/22 12:31 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
It’s about weight transfer, light bars let the front rise so the weight transfers to the rear. Now if you have a lot of power and traction they can be too light for a specific application.
Re: trying to find torsion bars [Re: cspracer] #3024629
03/16/22 05:17 PM
03/16/22 05:17 PM
CA
crackedback Offline
crackedback  Offline
CA
Think about two wound springs, one heavy the other light. Put enough pressure, say 5lbs, on the light one to compress it fully and let it loose, it's likely going to fly because the stored energy is high. Apply the same 5lbs pressure to a heavy spring, it won't compress as far and won't fly like the lighter spring when released.
It's the stored/potential energy that matters in the transfer of weight situation.
Re: trying to find torsion bars [Re: crackedback] #3024734
03/16/22 11:44 PM
03/16/22 11:44 PM
New York, USA
Chargerfan68 Offline
New York, USA
That’s a very good analogy. I knew this already, but it sure gives a sensible, visual understanding.
