Re: Piston Burn Pattern? [Re: GTX MATT] #1902861
08/31/15 12:26 AM
08/31/15 12:26 AM
Washington
madscientist Offline
Washington
Where the piston is CLEAN there is ZERO fuel.
Re: Piston Burn Pattern? [Re: GTX MATT] #1903498
08/31/15 10:13 PM
08/31/15 10:13 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
So what is causing that/how do I fix it? Current carb is an annular booser Holley, but Ive had a few carbs on it.
Re: Piston Burn Pattern? [Re: madscientist] #1903500
08/31/15 10:15 PM
08/31/15 10:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
Or it(the fuel mixtuure) is not hot enough to stick to the head or pistons during combustion work shruggy confused
Re: Piston Burn Pattern? [Re: GTX MATT] #1903655
09/01/15 01:57 AM
09/01/15 01:57 AM
Texas
ChevyTS Offline
ChevyTS  Offline
Texas
You don't fix it. wink keeping fuel suspended is one of the great challenges of performance engine building. Liquid weighs more than air. Air and fuel moving at high speed... air makes the turn and fuel doesn't. This causes the fuel to enter the chamber atomized and as a liquid. The results clearly seen in your pistons. You might experiment with carb spacers if you have room.
T & K Performance
Re: Piston Burn Pattern? [Re: ChevyTS] #1903665
09/01/15 02:30 AM
09/01/15 02:30 AM
Washington
Washington
^^^^^^^^^^^^^^^^^^YUP^^^^^^^^^
I would spend time on the flow bench with the head first and figure out why the port is charging the bore like that, and why the fuel is separating out. Despite what I read, I have never been able to get wet flow (fuel that has fallen out of suspension) back into airflow with surface preparation.
After I was happy with the port, I would put the intake on and figure out what changes with the intake.
After all that crap, you still need carb work
I can tell you for a fact that one well know NASCAR engine builder spent 98% of his time on carbs and intakes. He made a special fixture to tests carbs on the flow bench that simulates the intake manifold and it's adjustable. I can't wait to play with it.
There is way more to it than it may appear. But your pics show some issues. Fix them and you will pick up power everywhere.
Re: Piston Burn Pattern? [Re: GTX MATT] #1903669
09/01/15 02:33 AM
09/01/15 02:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By mr_340
I e-mailed some friends and one well know head porter said he thought it was too rich (already discussed) and too much timing. He thought the burn was finished before it got around to the far side away from the plug. So, something else to try.
Thanks, good to know, and I would agree that it has been too rich for sure.
Its rich... with that many miles it would have a tan color
over to the intake valve to get a full burn... its way rich
EDIT
The timing is starting too late to cause all the burn over
on the exhaust side(all the burn is over there)
wave
Re: Piston Burn Pattern? [Re: GTX MATT] #1904081
09/01/15 02:27 PM
09/01/15 02:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Matt , why did you pull the head ?
Re: Piston Burn Pattern? [Re: GTX MATT] #1904089
09/01/15 02:34 PM
09/01/15 02:34 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Long story short - engine performance is not where it should be, was re-checking cam phasing and my piston stop broke off in the #1 cylinder. Cam was degreed correctly.
Re: Piston Burn Pattern? [Re: ChevyTS] #3024204
03/15/22 01:02 PM
03/15/22 01:02 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by ChevyTS
Take a look at this video. You will notice that the pattern on your pistons kind of mirrors what is happing inside the chamber. https://www.youtube.com/watch?v=DCo_7Be_o3Y
Thank you!
Re: Piston Burn Pattern? [Re: mr_340] #3024206
03/15/22 01:04 PM
03/15/22 01:04 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Re: Piston Burn Pattern? [Re: GTX MATT] #3024245
03/15/22 02:32 PM
03/15/22 02:32 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I don't know if it's the jetting, the timing, the chamber design, or what... but that's not what I'd consider a good burn pattern. My understanding -- and it's pretty limited -- is you "should" see a more complete burn across the quench area and more uniform coloration of the chamber.
These pics aren't ideal, but show the burn pattern for this head & piston combo is spread out more. This is either a .040" or .045" quench height and the heads were pulled after about 25+ pulls on an engine dyno. Jetting was still being worked out, but tended towards the lean side. Ignition timing was 37*, IIRC. Fuel was a 50/50 blend of 110 leaded and 93 E10 unleaded.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Piston Burn Pattern? [Re: Brad_Haak] #3024258
03/15/22 03:08 PM
03/15/22 03:08 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This is good too, thanks for posting more pics. My heads are off and I'll be doing some minor tweeks here and there to the 'old' engine based on what i see in my 'chamber'. I was thinking of starting a new thread but this one has plenty of good in it already. From what I've seen, just like everything else comparatively, it has burn patterns similar to a SBC. Not that I'm disappointed in the past performance but, who's ok with leaving well-enough alone?
Re: Piston Burn Pattern? [Re: HardcoreB] #3024260
03/15/22 03:15 PM
03/15/22 03:15 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
One thing i will say is; I'll never have sharp edges in my 'chamber' lose compression or not. "Pretty" or not, flame travel must be important enough for cup teams to d.a. $5000 piston tops. So, it's good enough for me.
Re: Piston Burn Pattern? [Re: GTX MATT] #3024280
03/15/22 04:02 PM
03/15/22 04:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Originally Posted by GTX MATT
Does it mean anything? Can we learn anything from it? This one looks odd, what does it mean?
What I see is a lot of carbon on the exh side and that is where your fuel is collecting,Maybe on overlap,maybe small exh system.
Re: Piston Burn Pattern? [Re: Clanton] #3024379
03/15/22 08:22 PM
03/15/22 08:22 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
This is an old post guys - I did fight this car for a bit but finally got it running as strong as it should. The main issues were a vapor locking mechanical fuel pump, mufflers that were too restrictive, and very oddly the air cleaner made a big difference as well mostly on the low end & throttle response. It had a drop base on it and the lid was a bit close to the choke tower/bowl vents. A contoured moroso made a big difference in throttle response believe it or not, but the torque came from the mufflers and electric fuel pump. It made 479 RWHP on our local chassis dyno.
The burn pattern, as best I can tell, still is about the same. But the heads are coming off soon, so we’ll see if its changed at all. I think its from a rich t slot / ifr and the car mostly cruises on the t slots. I definitely have to fix that for this summer with the price of gas.
Re: Piston Burn Pattern? [Re: GTX MATT] #3024383
03/15/22 08:41 PM
03/15/22 08:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Look at your exh valve from the header side when it is off and see the buildup on the valve.
Re: Piston Burn Pattern? [Re: Clanton] #3024501
03/16/22 10:31 AM
03/16/22 10:31 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
chamber
Re: Piston Burn Pattern? [Re: HardcoreB] #3024502
03/16/22 10:33 AM
03/16/22 10:33 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Dishes
