Re: V6 to V8 swap?
[Re: RapidusMaximus]
#3067280
08/12/22 09:43 AM
08/12/22 09:43 AM
Posts: 7,828 east side of Ohio
basketcase
east side of Ohio
This '88 I had was the V6 5 speed. I swapped the 318 auto from an '86. Unplugged the wiring at the firewall, and did the swap. The only thing I ran into was the driver's side motor mount did line up on the crossmember. Had to fab the mount. Was only off an inch or so. Other than that it was a direct swap.
1981 Dodge D150 360 auto
Re: V6 to V8 swap?
[Re: cudaman1969]
#3067456
08/12/22 08:13 PM
08/12/22 08:13 PM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
Been looking to do this swap in my 05 Dak v6 to 5.7 but way to manny questions. You could buy a factory optioned Durango with a 5.7 after 04. Should be able to source everything you would need, I would expect.
Re: V6 to V8 swap?
[Re: poorboy]
#3067546
08/13/22 09:01 AM
08/13/22 09:01 AM
Posts: 2,406 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Wow, lol, this thread went silent back in March and then poof, it’s back. I ended up passing on the V6 truck because I just couldn’t find enough information on the mess I might be walking into. On the flip side…I ended up buying a 2001 Standard cab short bed Dakota…4cyl 5 speed, barely has enough power to merge into traffic but gets 20 something mpg, it’s rust free but high mileage, so…let’s now change the question a little bit , 5.2 magnum swap where a 4 cyl 5 speed was once sitting, what say yee
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: V6 to V8 swap?
[Re: theraif]
#3095663
11/20/22 01:07 AM
11/20/22 01:07 AM
poorboy
Freeport IL USA
For whatever its worth, the later versions of the 5.9 compared to the later versions of a 5.2 doesn't impress me much. The Magnum was designed as a 5.2, but opened it up to a 5.9 to sound more impressive. The difference between those two does not compare like the difference between the LA 318 and the LA 360. The 360 LA motors had heads with bigger ports, larger valves, and a block with a longer stroke and a bigger cam then the 318 LA version. From what I've read, the Magnums have the same heads, same block, and nearly the same cam profile. The magnum 5.2 has nearly the same output as the 360 LA.
As far as the pictured Dakota, locate a V8 truck for parts, everything should bolt up, and you have the wire harness if you need it (throttle body = probably not, switching to port injection = probably yes). Differences being motor mounts (at least the part bolted to the frame), radiator, possible wiring, computer (V6 to V8), and odds & ends.
Re: V6 to V8 swap?
[Re: poorboy]
#3095699
11/20/22 09:11 AM
11/20/22 09:11 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
For whatever its worth, the later versions of the 5.9 compared to the later versions of a 5.2 doesn't impress me much. The Magnum was designed as a 5.2, but opened it up to a 5.9 to sound more impressive. The difference between those two does not compare like the difference between the LA 318 and the LA 360. I agree. I wish that Chrysler had just held off on introducing the Magnum 5.9 a few years, and created it as an 8 cylinder version of the iron truck V10. Cylinder head combustion chamber of the V10 is superior. Dual resonant intake manifold of the V10 is superior. For the 1993-1994 years Chrysler should have simply put a 4.00 inch crank and lower compression height piston in a 5.2 as a towing engine with more cubic inches upgrade.
