Re: Octane boost
[Re: Twostick]
#3023069
03/11/22 10:29 PM
03/11/22 10:29 PM
Posts: 1,194 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Active ingredient in most of them is Toluene. If you can get your hands on that in quantity, you should save a bunch of $$$. Most rely heavily on MMT, which is the ingredient that leaves the "orange dust" coating on plugs and O2 sensors. FWIW, even if the product claims to be safe for use w/ oxygen sensors, use of MMT with them has been proven to reduce their service life. Brands that seem to offer at least some benefit, if using or blending "real" race fuel isn't an option, include Torco, Boostane and "Race Gas". Not saying others don't work, just that these have shown improvements in certain tests I've seen. I've used some boosters in the past and may still need to in the future. However, IMO they're at best a Band-Aid to get by on sub-optimal fuel.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Octane boost
[Re: Brad_Haak]
#3023072
03/11/22 10:43 PM
03/11/22 10:43 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
VP Octanium.....the best.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Octane boost
[Re: HDNMOPERS]
#3023265
03/12/22 03:19 PM
03/12/22 03:19 PM
Brad_Haak
Loudoun County, VA
Anyone who considers blending their own boosters / fuels needs to be aware of the health hazards associated with the chemicals used commonly in such activities. I'll throw this out for consideration and leave the rest of the research to the reader: https://medlineplus.gov/ency/article/002829.htm
Re: Octane boost
[Re: HDNMOPERS]
#3023290
03/12/22 04:35 PM
03/12/22 04:35 PM
Posts: 2,874 Pattison Texas
CSK
Pattison Texas
Kenne Bell recommends the Lucas product that I posted earlier for use with their Super Charged applications,
