Octane boost #3023007
03/11/22 07:14 PM
03/11/22 07:14 PM
florida dade
cesar perez Offline OP
florida dade
Any good additives out there
Re: Octane boost [Re: cesar perez] #3023009
03/11/22 07:26 PM
03/11/22 07:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Lucas has a good one
Re: Octane boost [Re: CSK] #3023020
03/11/22 07:59 PM
03/11/22 07:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Active ingredient in most of them is Toluene. If you can get your hands on that in quantity, you should save a bunch of $$$.
Kevin
Re: Octane boost [Re: Twostick] #3023022
03/11/22 08:06 PM
03/11/22 08:06 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Home Depot sells it by the gallon. You need to know the mix formula.
Re: Octane boost [Re: cesar perez] #3023043
03/11/22 09:17 PM
03/11/22 09:17 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Manhattan Oil "Liquid Horsepower"
Re: Octane boost [Re: Twostick] #3023069
03/11/22 10:29 PM
03/11/22 10:29 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Most rely heavily on MMT, which is the ingredient that leaves the "orange dust" coating on plugs and O2 sensors. FWIW, even if the product claims to be safe for use w/ oxygen sensors, use of MMT with them has been proven to reduce their service life.
Brands that seem to offer at least some benefit, if using or blending "real" race fuel isn't an option, include Torco, Boostane and "Race Gas". Not saying others don't work, just that these have shown improvements in certain tests I've seen.
I've used some boosters in the past and may still need to in the future. However, IMO they're at best a Band-Aid to get by on sub-optimal fuel.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Octane boost [Re: Brad_Haak] #3023072
03/11/22 10:43 PM
03/11/22 10:43 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
VP Octanium.....the best.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Octane boost [Re: cesar perez] #3023252
03/12/22 02:49 PM
03/12/22 02:49 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
This is from RB Racing site big Bonneville motorcycle guys
When Honda was spending 500 millions dollars a year on their V6 Formula 1 Turbo motors they ran a mixture containing 84% Toluene (114 Octane). It has excellent anti-detonation properties and increases your octane rating. If you are running 92 octane pump gasoline and you add this stuff, your octane rating will be changed by the formula:
[(Quarts Gas x 92) + (Quarts Toluene x 114)] / (Quarts Gasoline + Quarts Toluene).
For example, if you add one quart Toluene to four gallons of gasoline, your Octane will increase one point from 92 to 93. Add two quarts to four gallons and you get an Octane rating of 100. For you high boost junkies this is something to ponder. You can buy the product in hardware stores. Xylene has a higher flashpoint (less volatile) and has and octane rating of 117.
Re: Octane boost [Re: HDNMOPERS] #3023265
03/12/22 03:19 PM
03/12/22 03:19 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Anyone who considers blending their own boosters / fuels needs to be aware of the health hazards associated with the chemicals used commonly in such activities. I'll throw this out for consideration and leave the rest of the research to the reader: https://medlineplus.gov/ency/article/002829.htm
Re: Octane boost [Re: Brad_Haak] #3023281
03/12/22 04:10 PM
03/12/22 04:10 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Absolutely you could damage yourself. Probably easier than your engine pretty quick. Human organs are harder to get than Mopar parts. Just saying
Re: Octane boost [Re: HDNMOPERS] #3023290
03/12/22 04:35 PM
03/12/22 04:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Kenne Bell recommends the Lucas product that I posted earlier for use with their Super Charged applications,
