Re: Gas going to $9 in Cali, need fuel injection choices.
[Re: migsBIG]
#3022176
03/09/22 12:55 AM
03/09/22 12:55 AM
Posts: 31,105 Oregon
AndyF
Do you just want efi in general? Unless you daily a car it will be a long time before you recoup the cost, even at 9 bucks a gallon. Might be just as well to save the coins for gas. to be honest, I am terrible with carbs due to hearing problems which prevent me from doing a proper tune by ear. Also, the improved driving response, slight improved mileage and better starting in different weather conditions makes it a plus upgrade. When I drive my mopes, I drove them alot to relax and can easily put 1-3 tanks worth of fuel a week during summer. Holley Sniper with the Hyperspark distributor is the best deal. Not a simple install on a Mopar, you'll need some tech help with the wiring. Holley has drop in fuel pump modules for a bunch of musclecars, look on their website to see if your car is on the list. If so, then that is the easy way to go. Probably looking at $2000 by the time you buy and install everything. You will get a lot of benefits but not so sure you'll see a financial payback on the investment. Rich at FAST Man EFI is the best resource in the business. If you want to buy a system get in touch with him and have him put together a quote for you. I added the digital dash to my setup but that adds a bunch more money. I like having all the information on the dash but most people wouldn't want it. https://www.youtube.com/watch?v=64DrLMCLULA
[Re: Keith Richards]
#3024215
03/15/22 01:41 PM
03/15/22 01:41 PM
Posts: 15,952 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Just as I'm talking about not having issues with the FCC center for awhile now on my FiTech the car petered out on my yesterday and I strongly think it's the efi pump in the FCC AGAIN. Not had one problem with anything else but this high pressure pump. The throttle body has been good but this will be the third pump now if it's bad again. Car had to sit for three days and then finally started after leaving me stranded but still running like crap and smells like it's flooding.
If it's that FCC again I'm cutting my losses and going back to carb with little kicker electric pump to fill bowls. Then I'll put the throttle body for sale cheap. If only I could've gotten a in tank pump for this car.
Facts are stubborn things.
[Re: larrymopar360]
#3025409
03/19/22 12:17 PM
03/19/22 12:17 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
On that Fitech FCC issue, many people have solved their problems by running a vent line back to the fuel tank. Fitch says it isn't necessary but plenty of users find it helpful. Also keep in mind that fuel problems are regional and can even affect modern vehicles. My 2013 Mercedes CL65 doesn't like the winter blend fuels on warm days. On warm restarts the fuel can boil in the fuel rail, making the engine stumble for a couple seconds. That's on a high tech turbo V12 with a PWM controlled in tank fuel pump. Luckily, it clears up almost immediately. Nothing like jumping in a (formerly) $218,000 car and having it die on a restart.
[Re: feets]
#3025421
03/19/22 12:52 PM
03/19/22 12:52 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
On that Fitech FCC issue, many people have solved their problems by running a vent line back to the fuel tank. Fitch says it isn't necessary but plenty of users find it helpful. Also keep in mind that fuel problems are regional and can even affect modern vehicles. My 2013 Mercedes CL65 doesn't like the winter blend fuels on warm days. On warm restarts the fuel can boil in the fuel rail, making the engine stumble for a couple seconds. That's on a high tech turbo V12 with a PWM controlled in tank fuel pump. Luckily, it clears up almost immediately. Nothing like jumping in a (formerly) $218,000 car and having it die on a restart. feets, thanks for that suggestion and it's something I've been reading about with a search. So much out there to read on these. I haven't had a lot of time to play with it lately but it looks like the mechanical pump feeding my FCC is working properly with proper pressure. Now I have to see if I have the constant 58 psi FiTech requires. The two gauges on FCC are at flat zero all the time and I don't know if they are bad. I've already had to replace one of them about a year ago. I did get car running again but crappy and sputtering.
