Taking 1320 back to track on Sunday
#3020777
03/04/22 12:50 PM
03/04/22 12:50 PM
Posts: 485 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Headed to MIR as long as the weather holds. It's going to be unseasonably warm around here and get into the mid-70s, but some chance of rain still in the forecast. The only changes expected since going to Capitol a few weeks ago would be showing up w/ about 1/2 tank less fuel (~ 1/4 full) and, maybe, dropping in a Hellcat air filter element to replace the more restrictive OEM 392 filter. I expect the car will be slower in this weather and might be a long shot to see another 11-sec ET slip. However, what I'm hoping is that MIR's track prep is better and I can get some consistent passes this time. Capitol was simply hit-or-miss on the car hooking up with the factory 275/40R20 drag radials.
Re: Taking 1320 back to track on Sunday
[Re: Brad_Haak]
#3020786
03/04/22 01:16 PM
03/04/22 01:16 PM
Posts: 2,579 Pattison Texas
csk
Pattison Texas
I hope you get to go !!!! most important is to just have fun
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
[Re: csk]
#3020788
03/04/22 01:27 PM
03/04/22 01:27 PM
Posts: 1,395 Michigan
Kiddart
will you be leaving on Trans brake?
Also I did the Hellcat air intake and dropped the intake temps on average 10 degrees. when its cooler out the average is greater.
I actually want to find a kit that combines both headlight inlets to one tube then into intake it might help.
Good luck and keep us posted
Thank you Kiddart
[Re: ZIPPY]
#3020795
03/04/22 01:41 PM
03/04/22 01:41 PM
Kiddart
hi Zippy,
I know or think you are joking but the factory actually wants the 1320 taken to the track. they want you to join forums and talk about the performance. when I bought mine it came with a one year ihra subscription and some other stuff I never used.
its crazy to wrap your hands around "they want you to race them at the track and report on there blogs.."
Crazy world
Thank you Kiddart
[Re: Kiddart]
#3020807
03/04/22 01:59 PM
03/04/22 01:59 PM
Posts: 17,268 S.E. Michigan
ZIPPY
S.E. Michigan
Yes, I was kidding around. Customer word of mouth and forum posts are better marketing than anything from corporate!
Rich H.
[Re: ZIPPY]
#3020848
03/04/22 05:06 PM
03/04/22 05:06 PM
Posts: 3,238 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Yes, I was kidding around. Customer word of mouth and forum posts are better marketing than anything from corporate! Yep, a local guy here drove his Hellcat into the dealership on slicks with burnout rubber on the rear quarter panels. They replaced the blower on it under warranty.
[Re: ZIPPY]
#3020856
03/04/22 05:28 PM
03/04/22 05:28 PM
Kiddart
Yes, I was kidding around. Customer word of mouth and forum posts are better marketing than anything from corporate! I figured you were, you are one of the good guys on here...
Thank you Kiddart
[Re: Brad_Haak]
#3021220
03/06/22 10:54 AM
03/06/22 10:54 AM
Posts: 259 Nor here, Nor there
Dart 500
Nor here, Nor there
I don't believe that's a problem for a 1320 in Drag Mode. My burnouts go way past 4500 RPM and I didn't see any difference between runs, except the one time I didn't realize I had taken it out of Drag Mode by accident. The shift point RPM dropped significantly and the shifts themselves were noticeably softer resulting in the MPH dropping off compared to other passes. Its been years now, I think it was actually hitting the rev limiter by accident during the burnout that retarded the timing enough to ruin your run. I'll have to dig back in the archives to see what it was exactly, it was found out by a viper tech that had one of the quickest 392 cars after they had just come out.
[Re: Dart 500]
#3021258
03/06/22 01:08 PM
03/06/22 01:08 PM
Posts: 4,712 new jersey usa
11secdart
new jersey usa
Good Luck .... I still find the fact that you can buy a new car drive it to the track and run that fast fascinating .. the fact its a Mopar is the best!
68 Dart 367/904 92 D150 original owner 21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4 20 Acura RDX 16 Honda HRV
[Re: Dart 500]
#3021385
03/06/22 10:01 PM
03/06/22 10:01 PM
Brad_Haak
Loudoun County, VA
I don't believe that's a problem for a 1320 in Drag Mode. My burnouts go way past 4500 RPM and I didn't see any difference between runs, except the one time I didn't realize I had taken it out of Drag Mode by accident. The shift point RPM dropped significantly and the shifts themselves were noticeably softer resulting in the MPH dropping off compared to other passes. Its been years now, I think it was actually hitting the rev limiter by accident during the burnout that retarded the timing enough to ruin your run. I'll have to dig back in the archives to see what it was exactly, it was found out by a viper tech that had one of the quickest 392 cars after they had just come out. You may be on to something; more later when I get a chance to post today's results. Thx
