Re: 360 cylinder head information
[Re: Locomotion]
#3020665
03/04/22 02:14 AM
03/04/22 02:14 AM
Posts: 53 The Summit
Phoenix
The Summit
Originally posted by Locomotion Yes, pretty much the same, accepting the same bolt-on stuff. Of course, truck/van oil pan is rear sump while car is more centered towards the front. Possible minor cam and/or compression differences. It's been suggested that they should be 'J' heads, is this likely?
[Re: Phoenix]
#3020667
03/04/22 02:27 AM
03/04/22 02:27 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Originally posted by Locomotion Yes, pretty much the same, accepting the same bolt-on stuff. Of course, truck/van oil pan is rear sump while car is more centered towards the front. Possible minor cam and/or compression differences. It's been suggested that they should be 'J' heads, is this likely? Not possible if still stock, to many years between the making of those vans ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#3020673
03/04/22 06:32 AM
03/04/22 06:32 AM
Phoenix
The Summit
I have no hesitation in saying they're still stock...
Both vans are the same, they've never been pulled apart until now.
What do you mean by 'too many years...'? They are only a couple of years apart, probably a '73 and a '75.
[Re: Cab_Burge]
#3021399
03/06/22 10:56 PM
03/06/22 10:56 PM
Phoenix
The Summit
Originally posted by Cab_Burge OP, the 915 heads came in two different versions in 1971 to 1973, big valves on the 1971 340 motors and with the smaller valves on the 1971 to the 1973 360 and the 1972 and 1973 340 heads..... Thanks for that... very helpful. .....they were not set up for non leaded gas also Lots of heads of that era weren't it's almost a matter of course to get hard valve seats fitted in anything that age here.
