Re: 727 Aluminum drum vs. Billet steel drum- street driven
[Re: Dragula]
#3020198
03/02/22 12:36 PM
03/02/22 12:36 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I've heard some people say the aluminum drums need fluid changes more often and then some say they do nothing different for the aluminum drum. I have steel drums in mine so I can't say from personal experience.
[Re: an8sec70cuda]
#3020200
03/02/22 12:59 PM
03/02/22 12:59 PM
Posts: 11,501 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would not use an aluminum drum in a street transmission. It's main benefit is lighter weight, which equals quicker ETs. That's all. A good steel drum is fine for the street. Even an OE drum IF you aren't racing it.
[Re: CMcAllister]
#3020206
03/02/22 01:19 PM
03/02/22 01:19 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
I would not use an aluminum drum in a street transmission. It's main benefit is lighter weight, which equals quicker ETs. That's all. A good steel drum is fine for the street. Even an OE drum IF you aren't racing it. In general the failure mode of an aluminum drum is the eventual "wearing in" of the steel clutch plates to the flanks of the drum causing them to stick or worst case eventualy cut thoughteh flanks. This happpens to the steel drums as well but at a much slower rate resulting in a once in a life time purchase vs replacment due to wear.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3020213
03/02/22 01:38 PM
03/02/22 01:38 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I ran an aluminum drum for about 10 years. Always changed the fluid and filter ever 35 to 50 passes, fluid was always getting a silver color to it. Switched to a billet steel drum about 8 years ago. Car runs the same et, no change. The billet aluminum drum was not any faster... Now I change the fluid and filter once a year. Track car only...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: dvw]
#3020262
03/02/22 04:24 PM
03/02/22 04:24 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
My aluminum drum fluid change is about 100 passes. Zero issue on the 2/3 shift so I'd say the plates aren't hanging up either. The only thing I do see is the 1/2 shift takes more time to complete. Zero 1/2 shift flare. My bet is the coefficient of friction is not as great as a steel drum. So the shift light just gets set earlier. Going on year 9. Doug You shouldn't see a shift flare on the 1/2, all that is happening is the front band is stopping the spinning drum. Shift flare is something you see on the 2-3 , band releasing before the clutch pack is fully applied.
[Re: JohnRR]
#3020297
03/02/22 07:55 PM
03/02/22 07:55 PM
Posts: 9,815 MI, usa
dvw
MI, usa
[quote=dvw]My aluminum drum fluid change is about 100 passes. Zero issue on the 2/3 shift so I'd say the plates aren't hanging up either. The only thing I do see is the 1/2 shift takes more time to complete. Zero 1/2 shift flare. My bet is the coefficient of friction is not as great as a steel drum. So the shift light just gets set earlier. Going on year 9. Doug You shouldn't see a shift flare on the 1/2, all that is happening is the front band is stopping the spinning drum. Shift flare is something you see on the 2-3 , band releasing before the clutch pack is fully applied. It doesn't flare. It takes a longer time to complete the 1/2 shift. Part of this is the car is fairly quick so it gains more rpm in a given time frame. The shift time is a constant for a given valve body/drum/band/lever combo. In this case a Modified Turbo Action Chettah VB, 3.8 lever, aluminum drum, red lined hard band. The band has been in the car for close to 600 passes. Looks like it came out of the box. The only way I noticed it was on tach playback. Doug
[Re: hudsonhornet7x]
#3020301
03/02/22 08:21 PM
03/02/22 08:21 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I ran an A&A aluminum drum on the street for a quite a few years. Was warned by Rick at A&A that fluid will come out “silvery”. Also warned that having the pressure turned up to much would wear the drum in the ring/sealing area. This was before steel drums were available. At the time, he was thinking that they might try putting a steel insert into that area. Anyway, I ran that trans for five years before having a driveshaft yolk break. it bent the tailshaft housing. I took it back to A&A to have it repaired/ refreshed. He was glad to see it back because he was curious about how the drum held up under street conditions. He said it looked terrific, much better than expected. Asked about what fluid I ran. I always used “redline AT for towing” my friend was sponsored by redline so I got the fluid at a reduced cost. Anyway, I had no issues with the aluminum drum. That being said… The trans Im building now is getting a large piston steel drum. I see no reason to risk it with all the nice options we have now.
[Re: SportF]
#3020441
03/03/22 10:51 AM
03/03/22 10:51 AM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
IF you use a kevlar band fluid will turn gray (aluminum), need to use red band
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: TRENDZ]
#3020490
03/03/22 01:31 PM
03/03/22 01:31 PM
Posts: 1,961 Apollo, PA.
B1MAXX
Apollo, PA.
I ran an A&A aluminum drum on the street for a quite a few years. Was warned by Rick at A&A that fluid will come out “silvery”. Also warned that having the pressure turned up to much would wear the drum in the ring/sealing area. This was before steel drums were available. At the time, he was thinking that they might try putting a steel insert into that area. Anyway, I ran that trans for five years before having a driveshaft yolk break. it bent the tailshaft housing. I took it back to A&A to have it repaired/ refreshed. He was glad to see it back because he was curious about how the drum held up under street conditions. He said it looked terrific, much better than expected. Asked about what fluid I ran. I always used “redline AT for towing” my friend was sponsored by redline so I got the fluid at a reduced cost. Anyway, I had no issues with the aluminum drum. That being said… The trans Im building now is getting a large piston steel drum. I see no reason to risk it with all the nice options we have now. The aluminum drums I am used to have a bronze bushing for the sealing rings. That supposedly IF they wear grooves you can change the bushing.
