Re: Best Car Rotisserie for Money?
[Re: doctor_mopar]
#3019222
02/26/22 08:12 PM
02/26/22 08:12 PM
Posts: 16,012 Omaha Ne
TJP
Omaha Ne
Hi Ron I'm going to try attaching the files (3) but they may be to big or may not open correctly, If not PM me your email and I will send them one at a time. What I have is what I received with the unit and they appear to be copies as the picture quality is not the best. After scanning, it may be worse or about the same ;)
[Re: BryanRad]
#3019223
02/26/22 08:13 PM
02/26/22 08:13 PM
Posts: 7,545 Minnesota
Hemi_Joel
Minnesota
I like the whirly jig. It is a very well thought-out design. Here is the instruction video: https://youtu.be/B9Dh-qHVdqY
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TJP]
#3019372
02/27/22 11:30 AM
02/27/22 11:30 AM
Posts: 1,056 Slidell, La.
doctor_mopar
Slidell, La.
THANK YOU ! TJP Got the files downloaded . If I can ever be of help to you let me know ! Ron
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: TJP]
#3019458
02/27/22 04:39 PM
02/27/22 04:39 PM
Posts: 4,662 Motor City
6PKRTSE
Motor City
I built mine for my Challenger for less than $250.00. It has had my Challenger on it, a 68' Chevelle, a C10 truck cab and then the bed on it. Works great.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3019515
02/27/22 07:47 PM
02/27/22 07:47 PM
TJP
Omaha Ne
I built mine for my Challenger for less than $250.00. It has had my Challenger on it, a 68' Chevelle, a C10 truck cab and then the bed on it. Works great. No offense meant by this response but When was that? I built one off internet plans 20+ years ago. By the time the dust settled I had over 700 out in materials alone and a lot of time. I never used it as I was still employed and didn't have the time for the intended project. I got LAID off (political BS) in 2002 and decide to take the part time business Full time. At some point I sold the one I made for 1K as I recall. Also sold the intended car which I kick myself for now. 5 or so years ago the need came up for one business wise. I did some research and settled on the Whirly jig. So I am always curios when someone says they built one for that kind of $$. My brother in Ca. could have done so as he was a pipefitter and had access to all kinds of materials and supplies. I just looked online at a couple of suppliers and a 6ft piece of 2x2 x .125 wall box tube is running about 10.00 a foot + shipping. So even if one could buy it locally I don't think 250 is a realistic number especially in todays market. Again no offense meant but I sure as h-ll wouldn't have spent 2K plus when I bought the WJ if I could have built it for even 500.00. There have been some that have put units together using cheapo engine stands those are about 250 a pair by themselves right now. Add in additional materials and one would be easily over 500.00 and have a questionable setup. The WJ also have a lot of real nice features that would be hard to duplicate on a budget. Again I'm not challenging your statement but rather trying to clarify what one might cost today
[Re: etek]
#3019799
02/28/22 06:42 PM
02/28/22 06:42 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Very similar to what I am building. I have most of the steel, bought when it was a buck a pound. I use my cut off wheel to cut the material. I probably need to pick up a few more pieces of steel. And yes, there is some labor into it. But I think so far its less than $200 of materials. I will probably spend another $100 in materials. I also trash picked some carts I got the casters off of. A few minutes with a cut off wheel and they were liberated for this project. On a side note, I had a co-worker who built one out of pressure treated 4x4s and unistrut. Held his Nash Rambler body while he did all the work.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: TJP]
#3020830
03/04/22 02:34 PM
03/04/22 02:34 PM
6PKRTSE
Motor City
Steel place down the street has a bunch of cut off remnants. Almost every piece is 48" or under. (So basically all built out of scraps). It was $237.40 for the material and I had the casters off of a cart that I cut up. Knocks down to dozens of pieces. Oh, and a tip number all the pieces. Helps make it is easier to go back together.
[Re: MoparMike1974]
#3021412
03/06/22 10:31 PM
03/06/22 10:31 PM
Posts: 9,098 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
he had upgraded the head with bearings. Bearings ... Its not a goddam carnival ride!!
