Burnt crankshaft
#3019617
02/28/22 10:08 AM
02/28/22 10:08 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I have 2 crankshafts that were stored in a building that burned to the ground. Both had been machined and were ready to use. Obviously they need cleaning, machined again, etc.
My question is are they useable if they can be turned again (not bent)? I'm no metallurgist, but would the heat from the fire have caused any irreparable damage? They are a forged 440 crank and an old crank from a mid/late '50s Chevy 283.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: Burnt crankshaft
[Re: HardcoreB]
#3019643
02/28/22 11:32 AM
02/28/22 11:32 AM
an8sec70cuda
I don't know how hot it got, but there was nothing left of that building but metal and concrete. Anything aluminum was reduced to a puddle on the floor. Guess I'll clean them up and see how they look.
[Re: tubtar]
#3019677
02/28/22 12:49 PM
02/28/22 12:49 PM
Posts: 10,091 MN
JERICOGTX
MN
Toss them in the scrap bin...
69 GTX
68 Road Runner
[Re: FastmOp]
#3019686
02/28/22 01:17 PM
02/28/22 01:17 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
Probably no good anymore. Sorry man.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3019699
02/28/22 01:44 PM
02/28/22 01:44 PM
an8sec70cuda
Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car...
[Re: an8sec70cuda]
#3019701
02/28/22 01:46 PM
02/28/22 01:46 PM
Posts: 10,091 MN
JERICOGTX
MN
Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car... Is that your car?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3019702
02/28/22 01:48 PM
02/28/22 01:48 PM
an8sec70cuda
Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car... Is that your car? Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive.
[Re: an8sec70cuda]
#3019730
02/28/22 03:02 PM
02/28/22 03:02 PM
ZIPPY
S.E. Michigan
Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car... Is that your car? Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive. That hurts. I'm so sorry that happened.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3019736
02/28/22 03:10 PM
02/28/22 03:10 PM
Posts: 10,091 MN
JERICOGTX
MN
Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car... Is that your car? Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive. That hurts. I'm so sorry that happened. Darn right that hurts. Chip i HOPE that is the only car damage you received? Demon, and Cuda good?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3019762
02/28/22 04:52 PM
02/28/22 04:52 PM
an8sec70cuda
Thanks yall. It could have been a LOT worse. My dad's house wasn't damaged at all. His '69 road runner (the 4 speed 6 pack car) was parked at his house, so it is fine. The cuda and the Demon were in the shop and they are perfectly fine...as is the shop. The fire burned around it...somehow. We had 3 trailers all parked side by side, right beside the shop. My enclosed car trailer only had one tire damaged by fire, my open car trailer burned completely (all 4 tires burned to the rim, leaf springs flattened, deck plates buckled, etc.), and my dads smaller utility trailer suffered the same fate. The '73 new yorker and the "old" '69 road runner were parked at the barn. The taillights will need replaced on both cars and the paint blistered on the road runner, but that's it.
Lawnmowers, three Honda 300 fourtrax 4 wheelers, and a bunch of car stuff got burnt up in the barn. Game room is a complete loss...pool table, weight set/workout equipment, more car stuff, etc. My old Ford tractor and Case backhoe are fine. One front tire burnt up on the backhoe.
Luckily a family friend saw it and called me at work. I had that big Duramax running down the highway that afternoon! I work about 25 miles from home and I'm not sure how I didn't get a speeding ticket. I saw the smoke from about 8 miles away and my heart sank. You can't imagine the relief I felt when I saw the shop was ok.
[Re: an8sec70cuda]
#3019771
02/28/22 05:29 PM
02/28/22 05:29 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
[quote=an8sec70cuda]Thanks yall, I'll scrap them along w/ everything else. Fires suck. Luckily this was the worst damage to a car... Is that your car? Yes. This is the first car my Dad and I fixed up. I put the old Indy headed motor that used to be in my cuda into it. Just never completely finished it to race, but it does run and drive. [/quote Tell the insurance company they were both Windbergs
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: dvw]
#3019834
02/28/22 09:52 PM
02/28/22 09:52 PM
Posts: 213 Illinois
gearhead01
Illinois
It does not take a lot of heat to warp a crank. I spun a rod bearing (#3) on my 440, which is close to the center main/thrust cap. Crank is discolored at this journal area.
In disassembling, there was a tight spot when rotating the crank. I pulled the center main cap, and the thrust bearing inserts. Tight spot when away.
I left the front and rear caps on, and put an indicator on the center crank journal. I had 0.010 run-out on the center journal.
I have not had it checked out yet, but my thought is it will probably take as much to fix it, than buy a new crank.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
[Re: B3422W5]
#3019895
03/01/22 09:35 AM
03/01/22 09:35 AM
an8sec70cuda
B3422W5...LOL, it's a shame my "spare" aluminum block was right beside these cranks and melted! DVW...possibly from a battery tender that was on a lawnmower. Gearhead...you're probably right. Cost prohibitive.
