Factory mopar nos lower ball joint stamps #3018565
02/24/22 05:14 PM
02/24/22 05:14 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
What stamps or numbers, if any, are stamped on original lower ball joints for an e body? I bought a set in original Chrysler boxes, however, I'm questioning if these were just stuck into original boxes and resold. I'll list a few pictures of the ones that I received.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Factory mopar nos lower ball joint stamps [Re: 73cuda340] #3018566
02/24/22 05:14 PM
02/24/22 05:14 PM
clarks summit pa
clarks summit pa
Re: Factory mopar nos lower ball joint stamps [Re: 73cuda340] #3018995
02/26/22 02:45 AM
02/26/22 02:45 AM
clarks summit pa
clarks summit pa
Does anyone have a picture of a set of originals and their #s?
Re: Factory mopar nos lower ball joint stamps [Re: 73cuda340] #3019001
02/26/22 05:55 AM
02/26/22 05:55 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I recently bought NOS lowers for 1969 A body, and they had:
knock-off zerks
tri-slot nuts (one phosphated, one zinc plated)
Chrysler part numbers on the boots, as well as a nylon insert in the top of the boots.
Re: Factory mopar nos lower ball joint stamps [Re: kentj340] #3019053
02/26/22 11:32 AM
02/26/22 11:32 AM
California
biggE Offline
biggE  Offline
California
I've had a few sets over the years that I used on previous restorations. I believe Moog was the supplier for the suspension parts 70-71. Those don't look correct to me.
Re: Factory mopar nos lower ball joint stamps [Re: biggE] #3019068
02/26/22 12:48 PM
02/26/22 12:48 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Every OE Chrysler ball joint that I have ever had had a 7-digit casting number on it. And as mentioned previously the boot would ale have the OE part number molded into the rubber. I only have one pic of the casting number on the arm, plus one of the boots.
Re: Factory mopar nos lower ball joint stamps [Re: twodoorpost] #3019072
02/26/22 01:07 PM
02/26/22 01:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I just ckd the lowers in my car. It had NOS ball joints put in it back when restored. And they both have the OE casting number on them and the pt number on the ring of the boots as well . And the 3 star castle nuts as opposed to the 6 star aftermkt versions
