Re: Predator builds
[Re: HardcoreB]
#3017687
02/22/22 01:25 PM
02/22/22 01:25 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Following. Of note I don't think you can get Predator heads for a 4.840 B/S anymore (at least for a wedge block) ???
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Predator builds
[Re: HardcoreB]
#3017696
02/22/22 01:39 PM
02/22/22 01:39 PM
Posts: 910 West Virginia
B1Frank
West Virginia
Ran 4.80 in the 1/8 with a 572 B1 engine with a Pro charger #4 PSI like to build a predator engine for sure
Re: Predator builds
[Re: B1Frank]
#3017785
02/22/22 05:39 PM
02/22/22 05:39 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Ran 4.80 in the 1/4 with a 572 B1 engine with a Pro charger #4 PSI like to build a predator engine for sure
Re: Predator builds
[Re: CSK]
#3017795
02/22/22 06:25 PM
02/22/22 06:25 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
On my third Predator build now, just a bracket .90 deal but it will make some steam..
Oh yeah went 4.50's with my last one. Just a lowly NA 604" Predator.
You know my feelings on building one for smaller cubes. Seems like the perfect place for them
They only build Predator heads for 4.80" bore space block. FWIW we run a B1, Predator and a 600-13(on a 4.84" block) now.
Re: Predator builds
[Re: John Burdine]
#3018135
02/23/22 05:17 PM
02/23/22 05:17 PM
Al_Alguire
Las Vegas
Zero reason a smaller cube predator cannot work. I would think they would actually shine in such an application for oh lets say a smaller big block heads up style deal..
Re: Predator builds
[Re: John Burdine]
#3018155
02/23/22 05:49 PM
02/23/22 05:49 PM
Posts: 4,035 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I seem to remember DTHemi built a few. Paging: DTHemi lol I haven't measured the exh port area yet but, based on Al's feedback I may start the primaries at 2.125
Re: Predator builds
[Re: HardcoreB]
#3018414
02/24/22 11:41 AM
02/24/22 11:41 AM
Tig
A shed in England
So I layed these two side by side because a picture says 1000 words. While I had them out I did a quick gage of the L W and radius of each at the port opening so I could calculate the cross-section. This is a 460 Predator beside a 440-1 Indy cnc'd by Modern. At the opening the MW has a larger area! 3.36" versus 3.16" Obviously it doesn't tell the whole story. Look at the different routes the air takes, much straighter shot to the valve for the Predators. I need some
Re: Predator builds
[Re: Al_Alguire]
#3018444
02/24/22 12:43 PM
02/24/22 12:43 PM
Posts: 4,671 On the parachute mount
n20mstr
There is a reason that as most are ported make for very good power adder pieces makes you wonder....why is an SR20 head ok, but a Predator is not?? At least i beat them up for two years on the rules and got the weight dropped for BB Mopar. IF anyone wanted to race a BB Mopar in Ultra or NMCA Extreme Street...2022 is the time
....BAD A$$ STREET CAR.....
Re: Predator builds
[Re: HardcoreB]
#3018445
02/24/22 12:43 PM
02/24/22 12:43 PM
Posts: 16,923 NC
440Jim
NC
While I had them out I did a quick gage of the L W and radius of each at the port opening so I could calculate the cross-section. This is a 460 Predator beside a 440-1 Indy cnc'd by Modern. At the opening the MW has a larger area! 3.36" versus 3.16" Obviously it doesn't tell the whole story. Can you share the quick dimensions? I had a pair of Indy 440-1 CNC 345 (Indy's CNC porting), and for comparison they were: Intake_ Width Height Area Opening 1.375 2.650 3.644 Exhaust Width Height Area Opening 1.960 1.550 3.038 The area calcs don't account for the corner radius, just LxW
Re: Predator builds
[Re: 440Jim]
#3018457
02/24/22 12:57 PM
02/24/22 12:57 PM
HardcoreB
Shelby Twp. Mi
While I had them out I did a quick gage of the L W and radius of each at the port opening so I could calculate the cross-section. This is a 460 Predator beside a 440-1 Indy cnc'd by Modern. At the opening the MW has a larger area! 3.36" versus 3.16" Obviously it doesn't tell the whole story. Can you share the quick dimensions? I had a pair of Indy 440-1 CNC 345 (Indy's CNC porting), and for comparison they were: Intake_ Width Height Area Opening 1.375 2.650 3.644 The area calcs don't account for the corner radius, just LxW MW 2.68x1.38 R .625" Pred 2.46x1.95 R 1.38"
